RE: Hi Perf Russian 10cc at a bargain price!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Hi Perf Russian 10cc at a bargain price!
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: Hi Perf Russian 10cc at a bargain price! - 2/25/2008 7:33:39 PM
MJD
Status: offline
quote:
ORIGINAL: bob27s
any chance they chose to use a bearing retaining compound for some reason ??
How did things fit up after reassembly ?
I have the same suspicion that they use an anaerobic compound on the bearings. Seeing as QC and/or the perception thereof is certainly a factor in the make or break of a product, and often the first thing that pops to mind with products from some areas of the world especially, they either (a) do it as standard practice, or (b) have some concern over production fits.
I know we know they are meant for low nitro, but just as a reminder I don't think you should exceed 5% with these. An MDS .48 was the first engine I had run - in the usual .25-.61 sport engine range - that showed immediate obvious signs of displeasure in stock head trim with 15%. So methinks MDS engines are not conservative in the compression ratio department.
MJD
(in reply to bob27s)
       Post #: 176
RE: Hi Perf Russian 10cc at a bargain price! - 2/25/2008 8:09:24 PM
daven
Status: offline
I added 2 additional head shims (they came with the motor) making it 3 total. I didn't mic them, but they appeared to be some where around .005 each. I only run one fuel, and thats Powermaster 15% NITRO, so we'll see how it does with that. If I have to raise the head more, I will.
_____________________________
Dave Norman
klasskote.com
supertrc.com
(in reply to MJD)
       Post #: 177
RE: Hi Perf Russian 10cc at a bargain price! - 2/25/2008 10:10:13 PM
Flyboy Dave
Status: offline
If the engine is designed to run on zero nitro, it's probably a high-comp engine. I think
I would have put all the shims in. The high-comp and the possible questionable metallurgy
may be responsible for the broken rods and crankshafts in the early MDS engines. I use
15% PM fuel for the most part as well, but I also use 5% in the Rossi's and 20/20 in the
YS engines....all PowerMaster.
The figures Kmot got were not impressive, but he had the makeshift exhaust on it.
You really have to run it open pipe to see what you have.
FBD.
< Message edited by Flyboy Dave -- 2/25/2008 10:11:07 PM >
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
(in reply to daven)
       Post #: 178
RE: Hi Perf Russian 10cc at a bargain price! - 2/26/2008 12:47:51 AM
Kmot
Status: offline
Also, it is far from being broken in. It only has 20 minutes on it so far. I expect the power will increase a tad as it get more and more broken in.
DRILL BABY DRILL!!!
(in reply to Flyboy Dave)
       Post #: 179
RE: Hi Perf Russian 10cc at a bargain price! - 2/26/2008 2:45:04 AM
daven
Status: offline
I also thought the exhaust was constrictive, as well as running it rich with 80/20 fuel.
I think this motor has potential, just not sure it will be consistent from motor to motor.
Dave Norman
klasskote.com
supertrc.com
(in reply to Kmot)
       Post #: 180
RE: Hi Perf Russian 10cc at a bargain price! - 2/26/2008 3:02:41 AM
daven
Status: offline
Found a spinner nut for it today. 8mm x 1.25 from Dubro in Black.
Fits nice, and should do a good job.
Weighed the motor tonight, and it came in at 20.4 oz as it looks in the picture with prop nut and prop.
Click to see fullsize image.
Click for fullsize
Dave Norman
klasskote.com
supertrc.com
(in reply to daven)
       Post #: 181
RE: Hi Perf Russian 10cc at a bargain price! - 2/26/2008 3:32:57 AM
Kmot
Status: offline
I like that prop nut, it looks really good! Pricey little sucker though!
DRILL BABY DRILL!!!
(in reply to daven)
       Post #: 182
RE: Hi Perf Russian 10cc at a bargain price! - 2/26/2008 3:40:33 AM
rainedave
Status: online
FYI, Sheldon's is selling off a bunch of their NOS Mac's headers and pipes you-know-where. Some of the Mac's 10cc RE headers are as little as $9.99 Buy Now. I'm sure there's one in there that will fit this engine.
http://stores.ebay.com/SheldonsHobbies_HEADERS-PIPES-MUFFLERS_W0QQcolZ4QQdirZ1QQfsubZ18531897QQftidZ2QQtZkm
David
< Message edited by rainedave -- 2/26/2008 3:43:09 AM >
(in reply to Kmot)
       Post #: 183
RE: Hi Perf Russian 10cc at a bargain price! - 2/26/2008 1:46:45 PM
MJD
Status: offline
quote:
ORIGINAL: rainedave
David
Mine came with a stub adapter with internal o-ring groove, and only need a header/riser tube. Did this one have one?
RD - good link/tip, thanks!
(in reply to rainedave)
       Post #: 184
RE: Hi Perf Russian 10cc at a bargain price! - 2/26/2008 4:19:11 PM
Kmot
Status: offline
Yes MJD, these come with the stub designed for internal header tube.
I looked over the Sheldons 'blow out' and did not find anything that was a particularly good deal. The pricing is just about normal everyday prices on the various headers.
DRILL BABY DRILL!!!
(in reply to MJD)
       Post #: 185
RE: Hi Perf Russian 10cc at a bargain price! - 2/26/2008 4:23:24 PM
daven
Status: offline
Yeah, things are adding up:
39.99 motor
10.00 shipping
9.20 spinner nut
2 cans of brake cleaner at $3.19 each
sub total of $65.57 and I still need a pipe/header.
I didn't see any great deals at the "blow out" either.
Dave Norman
klasskote.com
supertrc.com
(in reply to Kmot)
       Post #: 186
RE: Hi Perf Russian 10cc at a bargain price! - 2/26/2008 4:33:51 PM
Flyboy Dave
Status: offline
....these are good deals....
http://cgi.ebay.com/MACS-1460-10-CC-HELO-MUFFLED-PIPE_W0QQitemZ200201284666QQihZ010QQcategoryZ34056QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
http://cgi.ebay.com/MACS-1920-61-SIZE-ENGINE-11-7-40-45-10-6-25-8-6_W0QQitemZ200194450873QQihZ010QQcategoryZ34056QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262#ebayphotohosting
http://cgi.ebay.com/Macs-Helo-Quiet-PIPE-1701-10-cc_W0QQitemZ200194453264QQihZ010QQcategoryZ34056QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
Revver Bro #4.
(in reply to daven)
       Post #: 187
RE: Hi Perf Russian 10cc at a bargain price! - 2/26/2008 10:19:33 PM
daven
Status: offline
Well I bought the 3rd one you listed Dave.
Mac's Helo Quiet PIPE #1701 10.cc
Not sure I can get away with the muffled or straight tuned pipe at my field.
Anyone know a cheap header for that pipe?
I'm up to $89 now, and not finished....
Dave Norman
klasskote.com
supertrc.com
       Post #: 188
RE: Hi Perf Russian 10cc at a bargain price! - 2/26/2008 10:26:35 PM
XJet
Status: online
quote:
ORIGINAL: daven
Still a bargain (if it runs reliably and strongly enough).
Even a Thunder Tiger 61GP is $89 and they only last "so long" when you thrash the snot out of them (I posted the pictures elsewhere to show what happens ;-)
If these Russian engines provide as much fun as my 61GP did then they'll be a real bargain, even after you've added a pipe, etc.
Why did you go for a spinner-nut anyway, what was wrong with the stock nut?
When I'm not here, I'm at RCModelReviews
(in reply to daven)
       Post #: 189
