XJet
Joined: 3/31/2003 From: Tokoroa, NEW ZEALAND Status: offline
Well I fired up the MDS today and it started first flip. I just guessed at the needle setting and was half a turn on the rich side. It seemed to run pretty good right from the get-go, except that it does have some wicked-bad vibes at about half throttle. I couldn't get the MCP mounted properly on this plane so I just threw the pipe on and I estimate the ground RPMs with a 11x7 MAS Scimitar prop was about 12,500-13,000 -- which didn't impress me very much, it obviously wasn't "on the pipe". However, once I got it in the air you could hear it step up onto the pipe and it suddenly gained (best guess) about 1,000-1,200 RPMs. It's definitely putting out good power -- and I haven't even started tuning the pipe yet (in fact it may be a little short for this 11x7 prop - I'll have to see if I've got a 11x6 or maybe try the 10x8 I've got here somewhere. No attempt was made to set the idle mixture (remembering that I stripped the carby down and simply used "a good guess" for the initial settings. Despite that it idles *very* nicely -- albeit the transition is quite fat (but no worse than your average Super Tiger) -- which I expected. This was never designed to be a 3D engine :-) The first run was with some hi-castor (20%) fuel with just 5% nitro. I fitted a single head-shim just to avoid detonation -- incase this pipe wasn't well suited to the engine. I'll tach the engine on the weekend and see what I can do to get rid of the really bad vibes. Oh, and I was using a really crappy old glowplug (which I always do when breaking in any engine, since the microscopic metal particles released during break-in often foul the filament. After the first flight the exhaust oil was the typical mid-brown color you expect from a castor fuel when used with a pipe. By Monday I'll have more data and know whether I'm going to snap up some more of these engines while they last ;-)
_____________________________
When I'm not here, I'm at RCModelReviews
