Accidentally Poked Hole in CompArf Wing
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Accidentally Poked Hole in CompArf Wing Page: [1]
Login
Accidentally Poked Hole in CompArf Wing - 2/8/2008 8:13:23 PM
buszz
Status: offline
I was drilling in the servo arm bay of my comparf extra 2.6M and accidentally poked my drill bit all the way through the top of the wing (from the bottom).
What's the best way to patch this? Microbubbles and epoxy and sand smooth?
       Post #: 1
RE: Accidentally Poked Hole in CompArf Wing - 2/8/2008 9:08:38 PM
rmenke
Status: offline
Buszz:
Sort of depends on the size of the hole? If you can get a small piece of 1/16 backing inside, would be best. Then use 5 min.epoxie or sim., fill the hole area, scrape off excess with playing card, and remove any excess with alchol and Q tip, cover with wax paper and let cure. Toutch up with kids crayon when well set. If you get a little dimple in the repair, simply add another light coat of epoxie and repeat process. You can add some ballons if needed, or wanted. ENJOY
< Message edited by rmenke -- 2/8/2008 9:09:01 PM >
(in reply to buszz)
       Post #: 2
RE: Accidentally Poked Hole in CompArf Wing - 2/8/2008 9:57:59 PM
HighPlains
Status: offline
Epoxy and micro-ballons mix.
Fill the hole and cover with a piece of clear plastic tape (to make sure there are no bubbles). Let it cure with the tape on the underside of the wing so it forms over the hole inside the wing.
_____________________________
In politics if you want anything said, ask a man. If you want anything done, ask a woman - Margaret Thatcher
(in reply to rmenke)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.265RCU1
