*CA Glue, Will It Work*
Tower Hobbies
Logged in as Guest
  Printable Version
Garage Sale Ad!!
Seller:  tripnik5
Details:   $1,500.00   |  7/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Off Topic Forum - Planes/Helis >> *CA Glue, Will It Work*
Page: [1]
Login
*CA Glue, Will It Work* - 2/8/2008 11:42:24 PM
Zippi
Status: online
I have a vinyl air mattress that has a small hole. Will CA glue work to patch the small hole or will it eat the vinyl?
_____________________________
"It Ain''t Lookin Good"
http://zippi.50webs.com/index.htm
       Post #: 1
RE: *CA Glue, Will It Work* - 2/8/2008 11:44:04 PM
Tired Old Man
Status: offline
It won't stick well. The ca is stiff, the vinyl is flexible. The glue will just peel away.
If you can''t fix it with a hammer, you have an electrical problem.
(in reply to Zippi)
       Post #: 2
RE: *CA Glue, Will It Work* - 2/8/2008 11:48:02 PM
Zippi
Status: online
Pat Roy,
Thanks for the info. But will it harm the vinyl ?????
Update,
Just used some Medium ZAP CA after sanding the area a little and let it set for about 10 min. I aired the mattress up and it seems fine ever after bouncing up and down on the mattress.
< Message edited by Zippi -- 2/9/2008 12:23:54 AM >
(in reply to Tired Old Man)
       Post #: 3
RE: *CA Glue, Will It Work* - 2/9/2008 4:55:38 AM
MinnFlyer
Status: offline
I will work for a little while - how long is the question
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
(in reply to Zippi)
       Post #: 4
RE: *CA Glue, Will It Work* - 2/9/2008 9:10:04 AM
Tired Old Man
Status: offline
Hopefully you're not on the bottom when it let's go
(in reply to MinnFlyer)
       Post #: 5
RE: *CA Glue, Will It Work* - 2/9/2008 5:34:36 PM
Deadeye
Status: offline
I bet canopy glue and an oversized patch would work well. Wiegh down till dry.
The USA is not a free country anymore
       Post #: 6
RE: *CA Glue, Will It Work* - 2/9/2008 6:39:31 PM
Lomcevak Duck
Status: offline
Epoxy should work even better if used with a small patch.
When someone loses a plane in the pits, you do a lomcevak duck.
(in reply to Deadeye)
       Post #: 7
RE: *CA Glue, Will It Work* - 2/11/2008 12:56:13 PM
ED STEFAN
Status: offline
I just patched one using "Goop" and a small patch cut from a heavy duty plastic bag. I used a gallon sized glad bag for the patch material.
ED -- AMA 20464 -- A plane is 1000+ different parts all flying in very close formation.
(in reply to Lomcevak Duck)
       Post #: 8
RE: *CA Glue, Will It Work* - 2/11/2008 1:48:26 PM
venom290
Status: offline
What size engine on it????
venom
Hey guys, watch this.
A.M.A 846735
(in reply to ED STEFAN)
       Post #: 9
RE: *CA Glue, Will It Work* - 2/12/2008 5:52:22 AM
ClemenTang
Status: offline
Use cloroform or plumber's glue
(in reply to venom290)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
