alan0899
Joined: 4/17/2006 From: Cundletown, NSW, AUSTRALIA Status: online
G'day Mate, It's a thing called adverse yaw, down going aileron produces more drag, than the up aileron, so with right aileron, the plane yaws left, & visa versa. There are a couple of ways to fix it, 1) use co-ordinated rudder, when you turn, so left aileron & some left rudder, same with right turns, that will help with your turns. 2) Differential in your ailerons, more up than down. And 3) if you have a computer radio, aileron & rudder mix, saves you doing the co-ordinated rudder.
_____________________________
Good Flyin Mate. Keep Thyne Airspeed up, lest the ground arise & smite thee, Allan.
