DustyDoug
Joined: 1/22/2008 From: Souderton, PA, USA Status: offline
quote:
ORIGINAL: tokenring Hay Tokenring, see my notes below... Hey DustyDoug!! Are you supposed to reach a 5:1 ratio with a brushless and brushed system... or just the brushless. I'm not sure about brushless and gearing, I'm still learning about the brushless systems. When I have it all figured out I will be going brushless. I saw that you said you couldn't reach the ratio even at 64/14 which is really close, so you went to brushed. I agree with you. I have 64/17 gearing, 17d Venom Fireball with a 8.4 nimh battery. This thing cooks! Is your motor holding up? Mine melted the plastic bell compleatly on two different motors! Even with lower 16/64 gearing. Note, I am running monster truck tires on my truggie, same tires as your truck had stock. when I had the 7.2 V battery on with the same setup, I used to try this move in the underground parking. Where you drive backwards, turn quickly and drive off forward. Looks like that cop move in the movies. Now when I do it with the 8.4 in, it does a 1080 when I do the quick turn before it drives off... it's crazy. I think for sure it goes 30 mph with crazy torque. Sounds like fun! The 8.4v's have a lot of punch! When I say 64T for the standard gear, I am guessing. Is that what comes stock for the 1/10 Dynamite EP?? What does pitch mean??? Loooking in my manual the monster truck, your Dynamite, stock is 17/64. 64 tooth is the stock driven gear 17 is the one on the motor. I'm not sure if that helps??? Pitch is the angle each gear is cut. It's the angle of the teeth and valleys looking at the gear from the side. Because of different pitch a gear of the same number of teeth can be different sizes. Got it? Dusty AB
_____________________________
Happy Motoring!
