High idle with brake on throttle back    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> High idle with brake on throttle back
Page: [1]
Login
High idle with brake on throttle back - 2/10/2008 3:54 AM
Shindermouse
Score: 100
Last Login: 12/20/2010
Status: offline
i have a redcat volcano 5v pro for some reason it idles extremely high when throttled back and brake on. linkage isnt hitting pull start handle. when observing carb it is not sticking in position. problem first started half way through a run. now it just idles high right off the bat. i tried adjusting idle to no avail. please help any suggestions apreciated.
Hide Signatures
       Post #: 1
RE: High idle with brake on throttle back - 2/10/2008 3:57 AM
vtrebel
Score: 100
Last Login: 4/11/2008
Status: offline
how big is your carb opening?
Hide Signatures
(in reply to Shindermouse)
       Post #: 2
RE: High idle with brake on throttle back - 2/10/2008 8:19 AM
Shindermouse
Score: 100
Status: offline
the inside diameter is 8mm and the outside is 12mm
Hide Signatures
(in reply to vtrebel)
       Post #: 3
RE: High idle with brake on throttle back - 2/10/2008 8:44 AM
hummerman
Score: 100
Last Login: 3/10/2008
Status: offline
My revo did that after breakin
had to richen up low needle to get idle right.
Hide Signatures
       Post #: 4
RE: High idle with brake on throttle back - 2/10/2008 8:50 PM
Shindermouse
Score: 100
Status: offline
thanks i will give that a try
Hide Signatures
(in reply to hummerman)
       Post #: 5
RE: High idle with brake on throttle back - 2/10/2008 8:52 PM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: Shindermouse
check and see if you idle is set to high for some reason, pull the air filter off and hit the brake and see where the car is set to, should be 1mm open,
if its a high/uneven sounding idle it could be your low end needle is too lean.
_____________________________
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
       Post #: 6
RE: High idle with brake on throttle back - 2/10/2008 11:01 PM
Shindermouse
Score: 100
Status: offline
thanks for your reply - throttle looks like it is open at least 2-3 mm - will adjust it. Also I have been told gas is only good for 3-4 weeks - is this true?
Hide Signatures
(in reply to ehroof)
       Post #: 7
RE: High idle with brake on throttle back - 2/10/2008 11:13 PM
ehroof
Score: 105
Status: offline
no, fuel is good for alot longer if you keep it closed and in a cool, out of the sun place
Hide Signatures
       Post #: 8
RE: High idle with brake on throttle back - 2/10/2008 11:17 PM
Shindermouse
Score: 100
Status: offline
thats good news about the fuel. Should have asked before - how do you adjust throttle to close the gap ?
Hide Signatures
       Post #: 9
RE: High idle with brake on throttle back - 2/10/2008 11:21 PM
ehroof
Score: 105
Status: offline
idle screw, counterclockwise to lower the idle
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 10
RE: High idle with brake on throttle back - 2/10/2008 11:56 PM
Shindermouse
Score: 100
Status: offline
thanks for picture - looks exactly the same as mine. I have tried turning idle screw counterclockwise still runs fast - is their a way to close gap in throttle. Looks like it rotates inside carb and there is still a 2-3mm opening when throttle fully backed off.
Hide Signatures
       Post #: 11
RE: High idle with brake on throttle back - 2/11/2008 12:02 AM
ehroof
Score: 105
Status: offline
the trim knob on the radio may be set too high, its the small knob with th on top of it.
Hide Signatures
       Post #: 12
RE: High idle with brake on throttle back - 2/11/2008 12:14 AM
Shindermouse
Score: 100
Status: offline
have set trim and there is still gap 2-3 mm in carb. can this gap be reset? does it need to be dismantled? really appreciate your help
Hide Signatures
       Post #: 13
RE: High idle with brake on throttle back - 2/11/2008 12:49 AM
ehroof
Score: 105
Status: offline
when you hit the brake, does it close? if not you have to turn the idle crew counterclockwise more.
Hide Signatures
       Post #: 14
RE: High idle with brake on throttle back - 2/11/2008 1:59 AM
Shindermouse
Score: 100
Status: offline
It worked ! (turning idle screw counterclockwise to close gap) truck runs better than ever now. Thanks very much for your help. You made my son's and my day!
Hide Signatures
       Post #: 15
RE: High idle with brake on throttle back - 2/11/2008 2:00 AM
ehroof
Score: 105
Status: offline
excellent bro, i am glad it worked out and i was able to help you, now go have some fun with your son.
Hide Signatures
       Post #: 16
RE: High idle with brake on throttle back - 2/11/2008 2:03 AM
Shockdriver
Score: 100
Last Login: 5/14/2013
Status: offline
how do you measure the gap in the carb
Hide Signatures
       Post #: 17
RE: High idle with brake on throttle back - 2/11/2008 2:06 AM
ehroof
Score: 105
Status: offline
by eye
Hide Signatures
(in reply to Shockdriver)
       Post #: 18
RE: High idle with brake on throttle back - 2/11/2008 4:40 AM
hummerman
Score: 100
Status: offline
ehroof,
Do the redcats have a stop so you if you unscrew the idle screw the slide wont close all the way?
my revo does and not sure if my redcat does or not?
Hide Signatures
       Post #: 19
RE: High idle with brake on throttle back - 2/11/2008 4:50 AM
ehroof
Score: 105
Status: offline
no, it will close all the way.
Hide Signatures
       Post #: 20
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
