mvvs 58
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> mvvs 58
Page: [1]
Login
mvvs 58 - 2/10/2008 2:58:15 PM
MatriX40
Status: offline
i have a mvvs 58, could it fly a 35% edge 540 with a canister exuast, what wieght range will this engine fly, as well as what prop, at what rpms.
       Post #: 1
RE: mvvs 58 - 2/10/2008 5:04:21 PM
janch
Status: offline
http://mvvs-canada.com/images/Video/58-film.mpeg
You can see here my plain 104 "
(in reply to MatriX40)
       Post #: 2
RE: mvvs 58 - 2/10/2008 5:53:39 PM
Miketc
Status: offline
Hi Janch, great video, thanks for sharing it with all of us.
Tell me about your setup;
1) What prop are you using on the MVVS 58?
2) what exhaust system do you have in this plane?
3) who is the manufacture of this plane?
4) what position is your engine sitting, horizontal of inverted?
I'm assembling a composite.afr 2.3 with a MVVS 58 with a internal canister set-up.
I have been at it forever, not enough time, I need to get my act together and finish this plane, any input would be most welcome.
R, Mike
(in reply to janch)
       Post #: 3
RE: mvvs 58 - 2/10/2008 9:27:18 PM
MatriX40
Status: offline
awsome video janch, please a little more info on your set up: prop size, prop rpm, plane wieght, ect.
       Post #: 4
RE: mvvs 58 - 2/10/2008 10:15:28 PM
pe reivers
Status: online
Mike,
I just finished a series of tests on my standard 58cc, using several canisters and the new MTW tuned pipe.
The tuned pipe I have now set up uses a 450mm long header, and runs best with a 24x10 prop at ~6350rpm. More power than your plane can probably handle.
Edit:
Images and prop data added.
For 450mm header length :
Mejzlik 22x10x3 6750 rpm
3W wood 24x8 6700 rpm
3W wood 24x10 6350 rpm
menz-S 24x12 6150 rpm
This is the prefered header length with stable running for all except the 24x12 prop, wich sagged when the pipe got hot (pipe tuned rpm shift off the prop power requirements)
< Message edited by pe reivers -- 2/11/2008 4:38:18 PM >
_____________________________
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl
There is sanctuary in analisys.
(in reply to Miketc)
       Post #: 5
RE: mvvs 58 - 2/11/2008 6:53:12 AM
janch
Status: offline
Hi Mike,
It is many Years ago.
1/ Prop is mejzlik 26/10 N
2/ Exhaust system is original from MVVS 3204
3/ They stoped production
4/ http://poletovani.webzdarma.cz/edge540.htm
12,5 kg ?
< Message edited by janch -- 2/13/2008 8:08:27 PM >
       Post #: 6
RE: mvvs 58 - 2/11/2008 5:04:50 PM
Miketc
Status: offline
Thanks Pe & Janch, I will take a look at your stats on the link.
My set up includes a Krumscheid 511 Custom setup for ARF-Composite Extra 2,3 m, for engine MVVS 58, Engine lies on it's side
The canisters I'm using is the 94 VS-4 R with the smoke pipe outlet
Have not selected a prop, but probably a Mejzlik ???
(in reply to pe reivers)
       Post #: 7
RE: mvvs 58 - 2/11/2008 5:14:37 PM
pe reivers
Status: online
The 23x10 or 24x10 would be nice combined with the KS 94 muffler (see data above)
       Post #: 8
RE: mvvs 58 - 2/12/2008 4:02:30 PM
Miketc
Status: offline
Pe, I have a Mejzlik 23 x 8 in the bottom draw. Is this an option? I would not like to drill it for the MVS 58, unless I'm confident that this will work.
The prop was acquired for the MVS 45 set-up on my H9 260. Is the prop pitch too small for this engine and set up?
I'm not a hot shot 3D flyer, I don't get enough air time to master the art...
       Post #: 9
RE: mvvs 58 - 2/12/2008 4:17:26 PM
pe reivers
Status: online
That prop will turn between 7000 and 7500 rpm. The engine can handle that, but it will get noisy.
       Post #: 10
RE: mvvs 58 - 2/13/2008 7:48:31 PM
Miketc
Status: offline
Thanks Pe, what about a 24 x 8, reason I ask, my LMS, has run out of 23 or 24 or 26 x 10 Mejzlik props, will it make that much of a difference, will the average model flyer really notice the difference? Alternately I will need to place an order on-line..
       Post #: 11
RE: mvvs 58 - 2/13/2008 10:14:28 PM
pe reivers
Status: online
The problem with 8" pitch is, that the larger the prop, the less efficient it becomes. For low speed flight, the prop pitch should be nearer to 1/2 times the diameter, like 23x10 to 24x10 or 22x10x3.
       Post #: 12
RE: mvvs 58 - 2/14/2008 10:35:45 AM
BaldEagel
Status: offline
Pe advised me to put a 22x10x3 on my 58 pro to keep things in check, due to ground clearance problems I could not go bigger in dia, this combination worked very well, keeps the revs in check and provides insane power on a 15.5lb plane, recommended, the good thing about this combination is that flying around on half throttle most of the time keeps the noise down considerably, this will prop hang at about 15% butterfly opening, would like to try and get it even less noisy, but have limited room inside the fus, at present the MTW 75K is up against the wing tube with a piece of silicon tubing wrapped around it to stop it burning through.
Mike
No matter what anyone says 100% is the maximum you can get.
       Post #: 13
RE: mvvs 58 - 5/28/2008 4:37:44 AM
ws61000hp
Status: offline
Pe, I have a pau 36% edge 540 and a mvvs 58 I would love to put that combo together. Do you think the 58 would be enough to fly it well including hovering and other 3d. If so what tuned pipe or canister and prop combo do you recommend? Any other options or advice welcome. thanx
''''''''second place is first loser!''''''''
(in reply to BaldEagel)
       Post #: 14
RE: mvvs 58 - 5/28/2008 11:25:08 AM
BaldEagel
Status: offline
A bit more information would be nice:
Wing span?
Weight?
Ground clearance for prop size?
Cannister ready? Internally? externally?
This would help Pe to give any advise and inform us of what is possible.
Mike
(in reply to ws61000hp)
       Post #: 15
RE: mvvs 58 - 5/28/2008 1:35:47 PM
pe reivers
Status: online
quote:
ORIGINAL: ws61000hp
For all-out 3D you need 2 times the plane weight for thrust
For just being able to 3D you need 1.5 times the plane weight.
With the data provided above, you can check out your exhaust system and expected prop rpm
http://www.mvvs.nl/prop-power-calculator.xls
Using my prop calculator you then can estimate the thrust you can expect. This calculator is slightly pessimistic. Thrust will probably be a tad more than calculated.
       Post #: 16
RE: mvvs 58 - 5/29/2008 2:12:43 AM
