RE: Tamjet EDF F-16 with P60SE DONE!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Tamjet EDF F-16 with P60SE DONE!!!
Page: <<   < prev  1 2 [3]
Login
RE: Tamjet EDF F-16 with P60SE DONE!!! - 2/21/2008 5:09:51 PM
i3dm
Status: offline
quote:
ORIGINAL: drdoom
My .02 ,To watch it, it almost looks like you are on the verge of beeing at the Aft limit of the CG.
I agree !
_____________________________
www.liorzahavi.com
my Jet gallery: http://www.runryder.com/helicopter/gallery/7681/?script=jets
(in reply to drdoom)
       Post #: 51
RE: Tamjet EDF F-16 with P60SE DONE!!! - 2/21/2008 5:14:20 PM
Reverend Russ
Status: offline
I balanced it with the UAT full exactly where Tam balances the EDF version. Being there is always fuel in it...it is more nose heavy than the EDF version. Still, you can throw the nose up in the air and putt around. It's loads of fun!
Russ
       Post #: 52
RE: Tamjet EDF F-16 with P60SE DONE!!! - 4/10/2008 7:05:19 AM
Reverend Russ
Status: offline
Here are the new alluminum wheels...disc brakes are on the way from Tam! The issue with brakes on these lightweight jets is they are just too strong. I had to separate the brake air system from the rectracts and pump it only to 30 psi. Tam's new disc brake system will fix this problem so you can use only one air tank and be able to run the brakes on 100 psi. These new alluminum wheels work great with the o-ring style brakes for now but will be used with the new disc brakes.
(in reply to Reverend Russ)
       Post #: 53
RE: Tamjet EDF F-16 with P60SE DONE!!! - 4/10/2008 7:07:18 AM
Reverend Russ
Status: offline
pics
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 54
RE: Tamjet EDF F-16 with P60SE DONE!!! - 4/10/2008 7:10:55 AM
Reverend Russ
Status: offline
more pics
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 55
RE: Tamjet EDF F-16 with P60SE DONE!!! - 5/5/2008 5:16:44 PM
michaelrc
Status: offline
Any room in this thing for a smoke system or am I being silly?
       Post #: 56
RE: Tamjet EDF F-16 with P60SE DONE!!! - 5/5/2008 5:24:23 PM
tamjets
Status: offline
quote:
ORIGINAL: michaelrc
Nothing is impossible. But had to be done right to kept the weight down.
Tam Nguyen
Owner TamJets
(in reply to michaelrc)
       Post #: 57
RE: Tamjet EDF F-16 with P60SE DONE!!! - 5/21/2008 5:44:05 PM
michaelrc
Status: offline
Hey Good Reverend,
What kind of flight times are you getting these days with the 1:12 Turbine? Did you put additional 10oz tank in?
(in reply to tamjets)
       Post #: 58
RE: Tamjet EDF F-16 with P60SE DONE!!! - 5/21/2008 6:04:15 PM
Reverend Russ
Status: offline
For the prototype we used two main tanks from the 1/8 scale F-16. We cut them and joined them to make one 45 oz instead of one 30 oz. I am getting a 5 minute flight with plenty of time to land. The kits will come with 3 tanks just like the 1/8 scale. I think it's two 8 ounce saddle tanks and one 32 ounce main tank. They will be done this week and the turbine kits should be here very soon.
Russ
       Post #: 59
RE: Tamjet EDF F-16 with P60SE DONE!!! - 5/21/2008 7:05:05 PM
tamjets
Status: offline
I'm waiting for my passport and visa coming back before book the flight to china to QC this new batch. I had 1/2 of the container had the 1:12 scale F-16 done for turbine version.
The fuel tanks and wheels/brake should be done pretty soon.
Tam Nguyen
Owner TamJets
       Post #: 60
RE: Tamjet EDF F-16 with P60SE DONE!!! - 5/21/2008 8:03:26 PM
michaelrc
Status: offline
Can the EDF 1:12 version be configured to fly in any way like the turbine version (slow, high alpha, blasts to vertical?) Is thurst thurst and it's the same with the EDF version? What configuration would get you there? I have 10S 4250 so I was hoping to use those...
       Post #: 61
RE: Tamjet EDF F-16 with P60SE DONE!!! - 7/24/2008 5:26:07 PM
Ray Davis
Status: offline
Well....where have I been, then ? Nothing on the site re the turbine version...
So: Is it now ARF for a 44-Gold, now has gear/wheels up to the task/grass......there a Tam pipe for it...or should a Wren pipe be used? Apparently comes w/ tanks and rudder....how much $$$$? 44-Gold flying weight? Tx!
Ray
       Post #: 62
RE: Tamjet EDF F-16 with P60SE DONE!!! - 7/24/2008 5:50:53 PM
Reverend Russ
Status: offline
The P-60 prototype dry weight with full UAT is 8 3/4 lbs. It carries 45 ounces of fuel. The 44 gold weight is about 1/2 lb lighter than the P-60. That will give you a take off weight with fuel of around 10 1/4 lbs, almost 1 to 1! Tams pipe is a must as it only weighs a few ounces. No go on grass, the mains are only 1 3/4 inch.
Russ
(in reply to Ray Davis)
       Post #: 63
Jump to:
