Styrofoam covering
Tower Hobbies
Logged in as Guest
  Printable Version
BVM Bobcat - RTF
Seller:  Gordito Volador
Details:   $4,750.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Crash & Rebuild >> Styrofoam covering
Page: [1]
Login
Styrofoam covering - 2/11/2008 5:46:10 AM
RedGN
Status: offline
Hi.... i have been flying mostly foamies and i wanted to make a new wing for one of my planes, i am wondering if there is a plastic type coating, similar to monocoat or ultracoat that can be put on foam? Anything that wound stick to foam and give it a tougher finish. Even a clear coat type paint...anything really.
Just wondering.
       Post #: 1
RE: Styrofoam covering - 2/11/2008 10:57:06 AM
perttime
Status: offline
Yes
You can use plastic films, as long as they are of the low heat variety. Some people put lightweight glassfiber cloth on their foamies with, what's it called, Water Based PolyUrethane). I've heard that some combat guys use pantyhose (nylon) instead of glass.
Whatever you use, you need a smooth surface under it.
(in reply to RedGN)
       Post #: 2
RE: Styrofoam covering - 2/11/2008 3:54:14 PM
GmanBill
Status: offline
Hair spray and tissue paper works well for milled lightweight foam, low temp covering if you want to cover it.
_____________________________
The G-Ma
South West AMA Show Team Manager
(in reply to perttime)
       Post #: 3
RE: Styrofoam covering - 2/11/2008 9:34:50 PM
RedGN
Status: offline
Thanks for the help...i was looking for something in a peel-n-stick solution. The fibreglassing is nice idea but would it crack if it's too thin? and if it is thicker would it add too much weight? Remember this is a foamie parkflyer with a cheap brushed motor.
Thanks for all the help.
(in reply to GmanBill)
       Post #: 4
RE: Styrofoam covering - 2/12/2008 12:40:32 AM
Sessholvlaru
Status: offline
I would think regular self-stick trim sheets would be you best option. I guess it would add a small amount of extra strength, and you could also apply multiple layers.
When you stare into the abyss, sometimes the abyss stares right back into you.
(in reply to RedGN)
       Post #: 5
RE: Styrofoam covering - 2/12/2008 10:04:49 AM
perttime
Status: offline
I put some regular clear parcel tape on the leading edges and fuselage bottom of my GWS foamies. It did not really like to bend around compound curves, though.
(in reply to Sessholvlaru)
       Post #: 6
RE: Styrofoam covering - 2/12/2008 7:02:29 PM
Gravityisnotmyfriend
Status: offline
Packing tape adds strength and durability. It will shrink with heat to get around compound curves. If you have trouble with it sticking, spray the foam with some adhesive first. Be sure to use Elmer's spray adhesive - it's the only one I've found that is foam safe.
The mathematician sees the glass as twice as big as it needs to be. The engineer sees it as full with a Safety Factor of 2.
       Post #: 7
RE: Styrofoam covering - 2/12/2008 9:22:37 PM
cutaway
Status: offline
If you can find it...some stuff called Fascal 700 made by Fason corp (they were bought and are a division of Avery now). Clear peels off of a paper backing with a very sticky adhesive on it. Fascal 1200 is the same material with a less aggressive adhesive that is just kinda tacky.
With high heat, both shrink like crazy, but over foam you won't need to shrink it.
Fascal is much stronger than Monocote and significantly cheap...if you can find it.
(in reply to Gravityisnotmyfriend)
       Post #: 8
RE: Styrofoam covering - 2/12/2008 10:25:22 PM
RedGN
Status: offline
Thanks for all your help. I will try them and let you know how it goes.
Thanks again
(in reply to cutaway)
       Post #: 9
RE: Styrofoam covering - 2/20/2008 7:33:07 AM
RibTickler
Status: offline
Back in the day I had a small 15 sized trainer, can`t remember what it was, but I`m pretty sure it was Sig, anyway it had a foam wing which I just covered with I believe Monocoat or possibly econo coat, not sure if they make that anymore, more than likely it was econo coat as I didn`t have much money back then. It worked great and strengthend the wing unbelivably! I crashed that plane many times, even had to build a whole new fuse from scratch, but never damaged that wing.Hope that helps, just don`t keep the iron in one place too long, keep it moving. I don`t remember melting the foam at all.
Ron
(in reply to RedGN)
       Post #: 10
RE: Styrofoam covering - 2/20/2008 4:08:14 PM
Live Wire
Status: offline
RedGN
Top flight econocote, Solar film And Black Beron are all low temperature films and work on foam. And H-9 ultracote made a contact type of covering.
Larry K AMA 36417
WACO Brotherhood #34
(in reply to RedGN)
       Post #: 11
RE: Styrofoam covering - 2/21/2008 10:25:25 PM
RedGN
Status: offline
Thanks again. I really appreciate the help guys.
(in reply to Live Wire)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
