DHG
CO, USA Status: offline
Dan, I hope Barry doesn't mind my jumping in here, but I think I understand your confusion. When the airplane is on its side, preparing to turn, the tank is indeed just a little below the venturi (in relation to gravity, i.e., the ground) with the cylinder sticking up vertically. And of course there's little or no perceptible change in the mixture ... as long as the plane keeps on flying steadily in knife-edge flight, relying on the fuselage for lift. It doesn't need much lift at that speed, and the forces on the airplane are rather mild. However, when you hit full elevator, the effect of ordinary gravity is overwhelmed by the artificial gravity (G-force) as the wing "lifts" the airplane hard in a [COLOR=orangered]horizontal[/COLOR] direction. Now the airplane is sustaining a force of 20 or 30 Gs perpendicular to the wing, which you'd consider an "upward" force if the airplane were parked stationary on the ground, sitting on its wheels. If the tank is 1 inch below the venturi when the airplane is parked stationary on the ground, sitting on its wheels, then in a full-up-elevator pylon turn it will [COLOR=blue]act[/COLOR] as though the tank were 20 or 30 inches below the venturi. That's why the tank position makes a difference to the engine mixture in the turns. Capisce? Dude the Obscure
