Charging VPX batteries
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> Charging VPX batteries
Page: [1]
Login
Charging VPX batteries - 2/11/2008 4:32:42 PM
P47Tbolt
Status: offline
I have did a search and have not come up with a definite answer.My question is can I charge
the Black and Decker VPX batteries with a Hobbico Accu-Cycle Elite.The battery package states they are
Lithium Ion batteries.The Elite states it can charge Li-Po or Li-Ion packs.So I should be able to.
Thinking about using these for ignition on a gasser and as receiver packs with 2 switched and 2 packs with
voltage regulators to drop voltage to 6 volts on both sysytems.
_____________________________
Today is the Tomorrow you worried
about Yesterday.
       Post #: 1
RE: Charging VPX batteries - 2/12/2008 1:27:56 AM
Panzlflyer
Status: offline
They are not the same as Lion/poly charge up to 8.4 and these 7.2v, no regs needed unless you have an ignition that needs 4.8v only
(in reply to P47Tbolt)
       Post #: 2
RE: Charging VPX batteries - 2/12/2008 4:57:48 PM
everydayflyer
Status: offline
There have been some reports of the 1100 mAh cells failing open. I have not experienced this myself but I have read several such post. The larger 2300 cells fail closed in all reports I have read.
You could use a Daptor and the charger you have.
http://www.infinity-hobby.com/main/product_info.php?cPath=30_77&products_id=1877
You could also just monitor the charge and stop it when 2S pack reaches 7.6 volts but once it reaches 7.2 it climbs very fast,depending on the charge rate of course.
Charles
< Message edited by everydayflyer -- 2/12/2008 5:01:10 PM >
(in reply to Panzlflyer)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
