blk822
WA, USA Status: offline
quote:
ORIGINAL: Gittle HS 55s are Hitec servos you can see them in the pic. Go to the LHS and pick up a set of push rods for the Trex. They should also have the balls, ball links and screws in another package. You can build a set or rods for the King II with these packs. You need 3 balls, 6 ball links in which you already have 3, and 3 screws to attach the balls to the servo arms. Your linkages need to be the same length as the ones on there now from z bend to center of the ball link. You need to set the length of the new ones from center to center fo the ball links. A little research and some measuring and you can get rid of those z bends. Gittle Buying a trex pack dosn't work. The servos are in a different position on a trex and the packs don't come with enough links long enough to do it, you would have to buy 3 packs of the links to get the right ones. I have tried it. And the balls come with the screws but in a pack of 20, same with the link ends. It can be done but not with one pack of trex links.
_____________________________
I never crash.....I just land reaallllyyyy fast
