RE: Maj. Woody's Fei Bao L-39    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Mig 15 Global Jet Club with Jetcat p-80SE - RTF
Seller:  cessna172av
Details:   $5,000.00   |  5/4/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Maj. Woody's Fei Bao L-39
Page: <<   < prev  21 22 23 24 25 26 27 28 [29] 30   next >   >>
Login
RE: Maj. Woody's Fei Bao L-39 - 6/4/2012 7:39 PM
mikedenilin
Score: 114
Last Login: 5/18/2013
Status: offline
Yes, we upgrade some JL to our Global Jet ARF PRO version. We do inspection and request upgrades and improvements on FB jets. We only do inspection, test flights on new FB planes, and issue engineering change, construction improvements, to FB. FB is very good in following our requests. The specifications of FB jets that we sell to USA are different due to different customer's flying behaviors. Our USA version tends to be stronger and heavier while European version tends to be lighter. We have discovered that American pilots tend to put oversized turbines and fly much harder, so several key areas need to be reinforced. Regardless, FB has been stepping up to the plate and be very helpful in resolving some failure issues quickly.
I had also evaluated this L39 failure issue and concluded that it's a damage inside the fuselage during operation of this L39. FB won't be able to cover that warranty. Normally they will cover the warranty if there is a failure inside the wings, or tail fins where users can't get access to for inspection. In this case, it's a clear case that there must be a crack or pre-existing condition that caused the failure. I am sorry for the loss, but we must look it each case carefully and be neutral about each incident. I think we don't have conclusive evidence to suggest that It's the quality problem from the factory. There could be many factors, not just a hard handing, that could cause this failure. This L39 is one of our most popular jets sold around the world, and it's been proven reliable and well designed. The dynamic causes of any failure are too complex for us to really make a conclusive closure without full blown investigations. This is cost prohibited and only be doable for full size, not models.
Mike
_____________________________
Global Jet ARF PRO- Air-C-Race-Germany, CNC-Italy, Feibao, Gryphon/Redwings, Der Jet, Jet Legend, & more - globaljetclub.com
Hide Signatures
(in reply to Jim Cattanach)
       Post #: 701
RE: Maj. Woody's Fei Bao L-39 - 6/4/2012 11:59 PM
ausfester
Score: 100
Last Login: 2/4/2013
Status: offline
Just want to reinforce the value of buying through GJC as the service is top notch.
If anything isnt how it should be then they're prompt to organise the needful without delays.
You know how these chinese arf's are like, missing bits and pieces are the norm or lack of detail in instructions.
I would only buy another jet from GJC, i've dealt direct before.... what a nightmare.
Thanks guys!
Hide Signatures
(in reply to mikedenilin)
       Post #: 702
RE: Maj. Woody's Fei Bao L-39 - 6/5/2012 12:33 AM
afterburner
Score: 110
Status: offline
quote:
ORIGINAL: ausfester
Thanks guys!
I agree. Mike and Cindy are great to deal with.
Marty
Hide Signatures
(in reply to ausfester)
       Post #: 703
RE: Maj. Woody's Fei Bao L-39 - 6/5/2012 12:38 AM
kingair41
Score: 100
Status: offline
Couldn't be better. Just got my second jet from Mike and Cindy.
Never a problem and the first jet the L-39 is a top performer.
Very satisfied with my choices...
FB L-39, FB Hawk, FEJ Large Hawk.......
Hide Signatures
(in reply to afterburner)
       Post #: 704
RE: Maj. Woody's Fei Bao L-39 - 6/5/2012 2:59 PM
megafly
Score: 100
Last Login: 5/17/2013
Status: offline
Guys, I have the new stab design, and no instructions
Do I have to glue the stab in the fuse or just use the bolts ?
Thanks guys.
Hide Signatures
(in reply to kingair41)
       Post #: 705
RE: Maj. Woody's Fei Bao L-39 - 6/5/2012 3:13 PM
afterburner
Score: 110
Status: offline
Just the bolts are fine besides if you put the servos in there, you may need to get to them in the future.
Marty
Hide Signatures
(in reply to megafly)
       Post #: 706
RE: Maj. Woody's Fei Bao L-39 - 6/5/2012 3:37 PM
megafly
Score: 100
Status: offline
Thanks afterburner!
Hide Signatures
       Post #: 707
RE: Maj. Woody's Fei Bao L-39 - 6/6/2012 11:35 AM
ausfester
Score: 100
Status: offline
i just used the bolts, they lined up perfect.
I used JR DS 3401 servos in the elevators. Let us know what you plan to use, they're small enough and expensive enough but at 4.6kg each i think, I'm concerned they're not enough. Anyhow i've had a few successful flights and they seem fine but i didn't try anything spectacular.
Hide Signatures
       Post #: 708
RE: Maj. Woody's Fei Bao L-39 - 6/7/2012 4:52 PM
megafly
Score: 100
Status: offline
I'm using 2 JR DS3421 "6.0V:75.0 oz-in (5.40 kg-cm)"
Hide Signatures
       Post #: 709
RE: Maj. Woody's Fei Bao L-39 - 6/27/2012 10:49 PM
gamalierlozada
Score: 100
Last Login: 4/7/2013
Status: offline
Got mine today!!
I guess mine is the latest version. The ducting is 120mm diameter to accommodate the new larger diameter EDF units. I ordered a Schuebeler DS-77-6745-700 (120mm) and it fits like a globe. I'll post a link to the build thread soon.
Hide Signatures
       Post #: 710
RE: Maj. Woody's Fei Bao L-39 - 7/13/2012 8:15 PM
mstanden
Score: 100
Last Login: 4/17/2013
Status: offline
Hello I currently own Woody's L-39!
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to frizlot)
       Post #: 711
RE: Maj. Woody's Fei Bao L-39 - 7/13/2012 9:06 PM
megafly
Score: 100
Status: offline
quote:
ORIGINAL: mstanden
Mstanden, can you tell your throws? I'm almost done my L39.
Thank you very much.
Sergio.
Hide Signatures
(in reply to mstanden)
       Post #: 712
RE: Maj. Woody's Fei Bao L-39 - 7/14/2012 12:22 PM
ausfester
Score: 100
Status: offline
has anyone else had cracking of the gelcoat paint on the top side of the wing above the retract.
I have a hairline crack in the paint but the underneath carbon fiber looks ok.
I've only had a handful of landings in this jet, all have been fairly good nothing that one would think was rough or hard.
Debating wether to cut a big hole in the undernearth to review further and repair or if im just going to make a big mess.
Perhaps the wooden structure which the retract is mounted too has seperated from the carbon fibre supports inside.
At most this is all i can see, perhaps it just made the paint felx and crack.
Any ideas guys, thanks
Hide Signatures
       Post #: 713
RE: Maj. Woody's Fei Bao L-39 - 7/14/2012 1:09 PM
gamalierlozada
Score: 100
Status: offline
Mine still in the building process and I noticed a bump in the same area you mention. I need to take a closer look to see what's the deal. Specially if is like that now I know after a couple landings it will start cracking the paint. I believe is the landing gear formers pushing the fiberglass a little bit. Is more noticeable in the right wing. As a precaution I will reinforce the area anyway.
Hide Signatures
       Post #: 714
RE: Maj. Woody's Fei Bao L-39 - 7/14/2012 6:04 PM
frizlot
Score: 100
Last Login: 3/4/2013
Status: offline
I reinforced an ran extra epoxy on all the woodwork on the mains before assembly. I had the same problem on my first set of wings and ended yp with the woodwork separating
Hide Signatures
       Post #: 715
RE: Maj. Woody's Fei Bao L-39 - 9/9/2012 10:05 AM
tarts
Score: 100
Last Login: 12/23/2012
Status: offline
Where do you guys place your refueling connectors? I have a quick-connect style connector and I taught if I placed it inside the jet, some fuel would spill into the fuse.
I'm thinking placing it on the side of the jet but in case of a leak the fuel might be sucked straight into the turbine through intakes?
Here are some pictures of my build so far. Coming together slowly but surely.
http://gallery.pistik.com/view_album.php?set_albumName=Feibao-L39
Hide Signatures
       Post #: 716
RE: Maj. Woody's Fei Bao L-39 - 11/23/2012 6:20 PM
Justflying1
Score: 105
Status: online
 Hello everyone,
Can you please tell me the length of the tail pipe that is supplied with this kit.
Thank you
Ivan
If you have to borrow, you cant afford it
Hide Signatures
(in reply to MaJ. Woody)
       Post #: 717
RE: Maj. Woody's Fei Bao L-39 - 3/2/2013 10:20 PM
megafly
Score: 100
Status: offline
I love this plane it flys really well! Mine is powered by a Kingtech k80.
I justt add wing tip lights.
Its a 3watt led system.
Regards!
Hide Signatures
(in reply to Justflying1)
       Post #: 718
RE: Maj. Woody's Fei Bao L-39 - 3/3/2013 1:22 AM
gamalierlozada
Score: 100
Status: offline
Any video? Mine has a EDF with 14s but if I can sell the unit I will strap a Jets Munt VT 80 in it. Properly set up they fly like a dream.
Hide Signatures
       Post #: 719
RE: Maj. Woody's Fei Bao L-39 - 3/3/2013 2:03 AM
megafly
Score: 100
Status: offline
I only have a Takeoff video... Need a cameraman!
http://www.youtube.com/watch?v=yaHmnSjpBF8&list=UURvlTPnTEYGq7Uwm6QvZJKw&index=1
Hide Signatures
(in reply to gamalierlozada)
       Post #: 720
RE: Maj. Woody's Fei Bao L-39 - 3/3/2013 2:19 AM
afterburner
Score: 110
Status: offline
Megafly,
Glad to see you are having success with L-39. It looks great. Mine flew great as well. The landings....not so much
Marty
Hide Signatures
       Post #: 721
RE: Maj. Woody's Fei Bao L-39 - 3/3/2013 5:47 AM
mstanden
Score: 100
Status: offline
Where did you get that lighting system? I have been looking for a scale lighting system like that for my 10Ft Hostetler Cessna 152!
Hide Signatures
       Post #: 722
RE: Maj. Woody's Fei Bao L-39 - 3/3/2013 3:00 PM
afterburner
Score: 110
Status: offline
Not sure if you are asking me or Megafly about the lights. My lights were Luxeon emitters and the control board was custom designed by a local flying buddy.
Marty
Hide Signatures
       Post #: 723
RE: Maj. Woody's Fei Bao L-39 - 3/3/2013 4:36 PM
mstanden
Score: 100
Status: offline
Mega fly but where are pics of your lights?
Hide Signatures
       Post #: 724
RE: Maj. Woody's Fei Bao L-39 - 3/3/2013 8:32 PM
megafly
Score: 100
Status: offline
These are the 3 watts leds I'm using .
And how do I made it.
Hope this helps.
Hide Signatures
       Post #: 725
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
