RE: Tamiya DT-02MS build and discuss
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Tamiya DT-02MS build and discuss
Page: <<   < prev  7 8 9 10 11 12 13 14 15 [16]
Login
RE: Tamiya DT-02MS build and discuss - 5/26/2008 4:56:13 AM
astroboycp
Status: offline
How different is it from the DT-02 Neo Falcon.
_____________________________
Tamiya KingTiger-TigerI-Sturmtiger-Sherman-Pershing-LeopardA26-Jagdpanther-WSN T34-Stuart-Scania-KingHauler-Volvo-F350-& mor
(in reply to astroboycp)
       Post #: 376
RE: Tamiya DT-02MS build and discuss - 5/26/2008 6:04:40 AM
acevtwin
Status: offline
Iv'e got my 3 Racing shock towers and hubs on order. Iv'e broke 2 stock front shock towers. I also want the C/F stuff for a more "Racing" type look. They will be perfect for the DT-02 MS.
Tamiya TRF-501X MS / DT-02 MS / Dyna Storm / Desert Gator / Frog
Predator X10 / AE B4 Stealth / E MAXX / Twin Detonator
       Post #: 377
RE: Tamiya DT-02MS build and discuss - 5/26/2008 7:00:55 PM
mog ruith
Status: offline
quote:
ORIGINAL: []TEX[]
I hate to rain on the parade but the stock towers are more durable than the CF ones. The stock hubs are also better, they won't bend when you roll it.
All that is nice for bling effect, but not necessary.
tex i have to agree with you almost all the stock parts is durable
this is one tamiya kit that is very durable and im loving it for its durbility
(in reply to []TEX[])
       Post #: 378
RE: Tamiya DT-02MS build and discuss - 5/27/2008 12:51:54 AM
thecraze
Status: offline
Also, the 3racing shock towers have more mounting options for shocks and front turnbuckles.
< Message edited by thecraze -- 5/27/2008 12:53:42 AM >
DT-02 Sand Viper
(in reply to mog ruith)
       Post #: 379
RE: Tamiya DT-02MS build and discuss - 6/2/2008 1:24:04 PM
acevtwin
Status: offline
I got my 3 Racing stuff. When I was taking off the stock parts I discovered the front shock tower was cracked. That would be the 3rd one! I hope I have better luck with the Carbon Fiber. Also, I wanted to comment on the quality of the 3Racing parts. They are awesome! The fit and finish is perfect. I am very happy with them. I will post some pictures later.
(in reply to thecraze)
       Post #: 380
RE: Tamiya DT-02MS build and discuss - 6/2/2008 2:20:56 PM
thecraze
Status: offline
3racing items are better than I would expect for inexpensive ones, compared to the Square equivelants which are much more expensive. I actually have Square front c mounts (in pic mounted), and I like the look of the 3racing ones better, they appear more durable with thicker metal where the turnbuckles mount.
Click to see fullsize image.
Click for fullsize
Click for fullsize
DT-02 Sand Viper
(in reply to acevtwin)
       Post #: 381
RE: Tamiya DT-02MS build and discuss - 6/2/2008 7:01:59 PM
acevtwin
Status: offline
I do wish they would have put a 3rd mounting hole for the turnbuckle. I think if we could mount the turnbuckle 1 hole higher it would eliminate ALL the bump steer. (Im afrain to drill carbon fiber myself)
       Post #: 382
RE: Tamiya DT-02MS build and discuss - 6/3/2008 2:03:54 AM
acevtwin
Status: offline
Heres a couple pictures.
Click for fullsize
Click for fullsize
       Post #: 383
RE: Tamiya DT-02MS build and discuss - 6/4/2008 12:36:35 AM
[]TEX[]
Status: offline
quote:
ORIGINAL: acevtwin
It's easy, just use a new/sharp bit and trim any fibers. Use CA to seal it. You need to use a high speed drill and move through the material at a slow pace. Drill half way through one side, flip it over and drill the rest from the other side.
< Message edited by []TEX[] -- 6/4/2008 12:37:07 AM >
       Post #: 384
RE: Tamiya DT-02MS build and discuss - 7/14/2008 7:03:19 PM
lnc0321
Status: offline
Hey after reading this thread I purchased a dt02 to race it at my local track. I am racing in the stock class. I wanted something different and I love tamiya. Now my question is which tires and would you guys recomend for racing and would they fit the stock sand viper wheels. I will be using the stock tamiya esc with a C027 motor. Thanks
(in reply to Eman77)
       Post #: 385
RE: Tamiya DT-02MS build and discuss - 7/14/2008 8:49:54 PM
thecraze
Status: offline
Any 2.2 racing tire will fit. I currently have Pro Line Holeshot front and rear (the fronts are 4wd tires, and I like the grip) on my stock DT-02 rims.
DT-02 Sand Viper
(in reply to lnc0321)
       Post #: 386
RE: Tamiya DT-02MS build and discuss - 7/19/2008 4:17:06 AM
B44&501xRacerEX
Status: offline
This kit is nice but I heard that tamiya has a full trf 2wd buggy in development, oople has all that information.
Some of the pro drivers have been running the prototype chassis.
Just thought Id share it with you.
B44 FT/Tamiya 501x "WCE"/HPI E-firestorm/Yokomo YR4 M2/Losi DT/F-150/Blackfoot Xtreme/Twin Force/TXT-1
       Post #: 387
RE: Tamiya DT-02MS build and discuss - 7/19/2008 7:40:21 PM
thecraze
Status: offline
That would be great!
DT-02 Sand Viper
(in reply to B44&501xRacerEX)
       Post #: 388
RE: Tamiya DT-02MS build and discuss - 7/25/2008 3:35:39 PM
lnc0321
Status: offline
I want to put new shocks on my sand viper. My question is do df03 trfs shocks work on this chassis?
Here is the link of the ones that im talking about
http://images.google.com/imgres?imgurl=http://www.tamiyausa.com/images/product/720/53926/header_53926.jpg&imgrefurl=http://tamiyausa.com/product/item.php%3Fproduct-id%3D53926&h=300&w=450&sz=87&hl=en&start=1&um=1&tbnid=Im6JNtv5ngLvoM:&tbnh=85&tbnw=127&prev=/images%3Fq%3DTamiya%2B(%252353926)%26um%3D1%26hl%3Den%26sa%3DN
       Post #: 389
RE: Tamiya DT-02MS build and discuss - 7/25/2008 3:42:23 PM
Lunchboxer
Status: online
Those are the shocks used in DT-02 MS.. so should be a direct bolt on.. although the springs are different.. (but you can always get the optional spring sets later..)
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
       Post #: 390
RE: Tamiya DT-02MS build and discuss - 7/25/2008 4:09:46 PM
