Tamiya DT-02MS build and discuss
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> Tamiya DT-02MS build and discuss
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Tamiya DT-02MS build and discuss - 2/12/2008 2:08:47 AM
[]TEX[]
Status: offline
Tamiya's popular DT-02 2WD off-road buggies featured a simple, user-friendly chassis and exciting performance. this kit is now available with a load of special Option Parts to bring out every ounce of hidden potential to this chassis. This limited edition DT-02 MS comes with a body that is finished in TRF Driver Satoshi Maezumi's personal colors.
About the Model
# Sand Viper body is made from lightweight polycarbonate and features TRF Driver Satoshi Maezumi's stylish colors, mounted on the easy to assemble 2WD DT-02 chassis.
# Equipped with front Astral Dish Wheels (ITEM 51205) and rear Large Dish Wheels (ITEM 53881).
# 4-wheel double wishbone suspension provides stable all-terrain driving performance.
# Gearbox is sealed to prevent interference by dust and debris.
# Full ball bearings ensures smooth and efficient operation.
# Loaded with performance-enhancing Option Parts, such as:
# ITEM 53926 DF-03 Aluminum Damper Set
# ITEM 53863 DT-02 Ball Differential Set
# ITEM 53791 DF-02 Assembly Universal Shaft
# ITEM 53831 DT-02 Aluminum Motor Heat Sink
# Steering Tie-Rod from ITEM 53828
# Hard Turnbuckle Shaft from ITEM 53942/53943
# ITEM 51000 High Torque Servo Saver (Black)
# R/C system, motor, tires, ESC, and running battery w/charger separately required.
ELECTRIC KITS REQUIRE:
(unless stated differently above)
* Radio: 2-Channel with servo(s)
* Battery: 6-cell flat with standard Tamiya connector
* Charger: AC/DC timed or peak for 6-cell battery
* Paint: PS for Polycarbonate/TS for ABS
* Misc. Items: Building and track equipment
_____________________________
T-Rex 600N Pro | T-Rex GF600E
       Post #: 1
RE: Tamiya DT-02MS build and discuss - 2/12/2008 2:10:34 AM
CustomTamiyas4Life
Status: offline
This should be a good build. Not many have the dt02 platform never mind one with trf accessories!
TNX / E-firestorm / Tamiya Rising Storm / mod pede-for sale / walkera 4 / mini-t
(in reply to []TEX[])
       Post #: 2
RE: Tamiya DT-02MS build and discuss - 2/12/2008 2:13:59 AM
Checkpointracer
Status: offline
This will be good. I use to have a DT-02 but I sold it since it just wasn't quite cutting it for me race wise.
Keep them behind you or crash hard trying.
(in reply to CustomTamiyas4Life)
       Post #: 3
RE: Tamiya DT-02MS build and discuss - 2/12/2008 2:16:36 AM
[]TEX[]
Status: offline
Front suspension assembly, note the TRF turnbuckles. Standard suspension assembly, with some FRP material.
Click to see fullsize image.
Click for fullsize
       Post #: 4
RE: Tamiya DT-02MS build and discuss - 2/12/2008 2:18:41 AM
[]TEX[]
Status: offline
Interesting ball diff assembly, typical spring washer/thrust bearing design.
Click for fullsize
Click for fullsize
       Post #: 5
RE: Tamiya DT-02MS build and discuss - 2/12/2008 2:19:58 AM
[]TEX[]
Status: offline
quote:
ORIGINAL: CustomTamiyas4Life
Hey, haven't seen you in a while Matt!
       Post #: 6
RE: Tamiya DT-02MS build and discuss - 2/12/2008 2:21:03 AM
[]TEX[]
Status: offline
quote:
ORIGINAL: Checkpointracer
So far, this one seems worth the extra $$.
(in reply to Checkpointracer)
       Post #: 7
RE: Tamiya DT-02MS build and discuss - 2/12/2008 2:22:21 AM
Checkpointracer
Status: offline
quote:
ORIGINAL: []TEX[]
Yeah probably, the ready to run sand viper is really junk.
       Post #: 8
RE: Tamiya DT-02MS build and discuss - 2/12/2008 2:24:31 AM
[]TEX[]
Status: offline
I usually use brushless, but decided to get this since I have an ESC for it. TRF motor heat sink included with the kit.
Click for fullsize
       Post #: 9
RE: Tamiya DT-02MS build and discuss - 2/12/2008 2:26:55 AM
[]TEX[]
Status: offline
Looks like Tamiya changed their grease tubes and supply more grease.
Click for fullsize
       Post #: 10
RE: Tamiya DT-02MS build and discuss - 2/12/2008 2:31:20 AM
[]TEX[]
Status: offline
Standard Tamiya style gear case assembly, no slipper, would have been a nice touch though.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 11
RE: Tamiya DT-02MS build and discuss - 2/12/2008 2:34:47 AM
[]TEX[]
Status: offline
Now this part I like a lot, Tamiya CVDs. Nicely done.
Click for fullsize
       Post #: 12
RE: Tamiya DT-02MS build and discuss - 2/12/2008 2:36:50 AM
[]TEX[]
Status: offline
Rear suspension/gear case assembly...
Click for fullsize
Click for fullsize
       Post #: 13
RE: Tamiya DT-02MS build and discuss - 2/12/2008 2:37:42 AM
