can773
AB, CANADA Status: online
[QUOTE]Originally posted by Coulter_Dean Ok, now I understand the pressure idea. The engine is pressurizing both fue, and smoke tank. The smoke tank leads to an open hole in the muffler. When the smoke oil is gone, the pressure goes right out of the system via the smoke hole in the muffler, thus removing any pressure from the tank, and killing engine.(not good). Heres a thought! If we install a check valve right after the tee for the smoke line, the engine would run for about 8 seconds with whatever pressure was left in the fuel tank, (meanwhile were venting pressure through the muffler). That will give us enough time to shut off the smoke valve. Does this make sense to anyone other than myself? Thanks [/QUOTE] Ever pulled the pressure line on a YS?? Well then you know that the INSTANT the tank is vented the pressure is gone. A YS is not pumping 1500 scfm gas it wont have enough to pressure up both tanks while the smoke is on, once you open that smoke valve your pressure will be gone. I wouldnt be trying it
_____________________________
Chad Northeast
