New RCV SP engine?
Tower Hobbies
Logged in as Guest
  Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> RCV Engines Support >> New RCV SP engine?
Page: [1]
Login
New RCV SP engine? - 2/12/2008 4:19:59 PM
Juice
Status: offline
When are you releasing this?...
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: New RCV SP engine? - 2/12/2008 4:48:34 PM
saramos
Status: offline
With a setup like that, you have the opportunity to create custom gear ratios as you combine the output of the 3 cylinders to one prop shaft. You could probably turn a 32" 5 blade at 3800 to 5800 rpm depending on which gearset you choose! Perfect for that 1/4 scale SeaFury project.
Scott
(in reply to Juice)
       Post #: 2
RE: New RCV SP engine? - 2/12/2008 7:51:30 PM
mboland
Status: offline
Its bad enough trying to keep one cool, but 3
_____________________________
It's the quality of life that counts, not the quantity.
(in reply to saramos)
       Post #: 3
RE: New RCV SP engine? - 2/12/2008 8:13:36 PM
LeeHop
Status: offline
I wonder if RCV ever considered designing the cooling fins to run lengthwise - or at an angle - more in line with the airflow over the engine.
LeeH
puzzled in Portland
< Message edited by LeeHop -- 2/12/2008 8:14:17 PM >
(in reply to mboland)
       Post #: 4
RE: New RCV SP engine? - 2/14/2008 4:47:18 AM
Michael211
Status: offline
It's been discussed before, Leehop. You'll have to search thru the theads in this forum to find the discussion. Result was, the machining requires the fins to be the way they are and RCV didn't believe changing the orientation would signifcantly change the cooling rate. It's just important in a cowled installation to make sure and add an air scoop inside the cowl to "drive" the airflow up over and the engine fins, as per their instruction booklet.
Regards!
- Michael
(in reply to LeeHop)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.283RCU1
