fizzwater2
KS, USA Status: offline
I've got one of those RS orange drivers, and like it. In the last couple of weeks, I've put new batteries in my old Globee "fireplug" units. It's hard to get a lot more simple and reliable than they are. Simple is good, less to go wrong. Daven, the clip in your post (magnum) looks a lot like the ones I picked up the other day at a swap meet from a guy that sells a lot of control line supplies. I use the Deans 2-pin Ultra connector on both the orange RS and the globee fireplugs. Put the female connectors on a short wire to the driver, and the male connectors on the glow plug clip, alligator clips, etc. That way you can use whatever clip you like, and even carry a spare in your things in case the "clothespin" clip gives up on you in the middle of a weekend. By using the female on the battery end, you run less risk of shorting them out when unplugged. You can cut the magnum clip wire in half, put a male on both ends, and have both the clip type and the alligator clips out of one.
_____________________________
no matter where you go, there you are..
