4square
FL, USA Status: offline
] quote:
ORIGINAL: specialk1 quote:
ORIGINAL: 4square quote:
ORIGINAL: 4square Ok, here's the pictures, It just looks like the motor needs to be attached with a spacer or the bottom of the boat needs to be trimmed, I purchased this boat from someone that mounted a K&B to it with an adjustable mounting plate. There is a hole in the transom where at one time a previous owner mounted or tried to mount the adj. trim bracket. Any suggestions guys? /Users/williamladue/Desktop/Seebold transome.jpg /Users/williamladue/Desktop/Seebold full.jpg I must not be uploading these pics correctly??javascript:void(AddText('[\&o]','')) i saw one of these on eBay this week your going to need it Thanks, I picked that one up 3 weeks ago off eBay, I just fixed that broken-off set screw last night, and believe it or not, the SS center shaft is actually an old chrome plated steel shock shaft. Ha! I'll just replace it with an 1/8" rod after fitting everything to the hull. Just goes to show-- you really gotta LOOK closely at pictures. Thanks for all your help, it's really great having a forum like this to provide information on an almost lost product.
