iron eagel
Joined: 7/15/2004 From: Middleboro, MA, USA Status: offline
Thanks Bruce! I was just curious as to what if any effect these type of design considerations had when weighed against overall performance. And if this was something that one should take a hard look at before just adding more surface without thinking about what other things it might do as well. If I do do a modification I want to as much as possible do so in a manner that it will enhance performance, rather than just be ok, to try to gain something even of that gain is small. Hence that is why as far as the tail group I am looking at increasing the root cord the most in adding some additional area to the overall control surfaces, although a small increase in span might be needed at least for the elevator. You must be able to read minds, because I have not really focused that much on the ailerons as of yet, and had thought this might be somewhere where the counterbalance idea might be used effectively. Although I am a bit concerned that by doing so it might be an invitation to flutter as far as the ailerons go, although I am using a pull/pull setup on this planes ailerons (so I can move the servos inboard to keep more of the mass closer to the roll axis) and that should be less prone to flutter. Regards, Paul
< Message edited by iron eagel -- 2/16/2008 4:14:52 AM >
_____________________________
The Wrights never crashed, they only had hard landings. I 've had some hard landings myself. AMA EAA AOPA revver #185
