Tigger N. Bennie
Thanks for the earlier comments on the photo. quote:
ORIGINAL: Nick2618 Nice Pic!and But i have a question now. To get the best rc action shots would it be best to use Apature Priotrity and set it to the lowest apature setting yeilding fastests shutter speed? Here's what I wrote for another forum, but remember different people do different things. This is basically how I start off. By the way, since I also shoot R/C helis, planes, and jets, the settings are also dependant on the speed of the "prop" just as in the "tires" of an R/C car as well as the available quality light. quote:
My "starting set-up" is rather simple: 1. Shutter Priority: Shutter speed as low as possible to allow motion blur, yet fast enough to prevent subject blur. ISO as low as possible. The "event" and/or the potential speed of the subject is one factor I consider in addition to the lighting conditions. 2. Aperature Prioity: I use AP in low level lighting and ISO as low as possible. A grainy shot may be better than no shot at all. ISO Auto is OFF. 3. Manual: I may switch over in low level lighting and/or when using the trap focus technique. However, most of the time I am panning with the VR off. ____ Continuous High Shutter Mode - I paid for it and I want to have the option available. I very seldom shoot at full high speed, but I want the option on just in case I want to blast away to capture a specific event. Continuous Servo Focus - I'm usually on this setting though I usually use the AF-ON button instead of the shutter button to focus. Single area AF - This appears "faster" to me. ____ Metering - Matrix is usually my first choice since that is what helps make the camera and is more advanced than weighted metering. However, I may also use spot metering depending on how much the subject stands out from the background. ____ Composition - I may not compose action shots like still shots but I still consider the background. After all, I don't want a bunch of trash cans in the background or some other distracting object. I try to find a spot where I like the background and pan the subject until it reaches that spot. I'll also adjust the focus point to fit that spot as well as whether I want to shoot in landscape or portrait mode. Remember magazine covers are usually in portrait mode. Cropping - I try not to crop alot; however, I leave room to crop since I may not take the shot "level" and need to straighten it out in post processing. After all, I want to use and retain as many megapixels as possible. I also do have numerous 20x30s framed. RAW - I probably shoot RAW 99% of the time. The reason being is that I have been specifically asked for RAW files by publishers. Numerous sports shooters and/glamour photos that I have ran into shot in RAW+JPG since the review the JPGs first, then work on the RAW files if those shots are used.
_____________________________
Lots of RCs, two cats, and a Nikon.
