greybucket
Joined: 1/15/2008 From: Jasonville, IN, USA Status: offline
- I am currently in the process of taking the covering off an old plane and plan to recover it. I am finding that is it a long, slow process of taking the old covering off but it gives me something to do while it is around 10 degrees outside. Anyways, using my heatgun, I peel off the old covering (the plastic film on top) but I am finding that the adhesive is left in some areas. At this point, I have been taking a spoon and scraping off the adhesive left being extra careful not to damage the wood. Is it ok to leave what I can't get off even after a light sanding to smooth everything out? Will it be ok when I go to recover?
- Secondly, is there a really effective way to remove paint from balsa wood? This plane was bought from a flea market type place and I figured it would be something to tinker with and learn how to do some repairs, esp covering. The previous owner really painted things up from the firewall out, and where the gas tank goes. Some tight spaces in there and it would not look the slightest bit good to repaint over it.
This isn't my only plane but since I don't feel comfortable building one by myself yet, I am in no hurry to see this done and in the air. It is just one I am using as a learning experience. All my other planes and equipment I received as a gift from my grandfather not long ago. Most all the planes are in some need of repair and I am using this one to practice with. Any help would be greatly appreciated!
_____________________________
If practice makes perfect, and nobody is perfect... why practice? - AMA #910567 - http://www.greybucket.com
