Compatible clearcoat for epoxy
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Compatible clearcoat for epoxy Page: [1]
Login
Compatible clearcoat for epoxy - 2/14/2008 12:06:07 AM
c-cat
Status: offline
Was wondering if transtar acrylic urethane clearcoat would be ok to use (as clear gel) with epoxy layup?
       Post #: 1
RE: Compatible clearcoat for epoxy - 2/14/2008 12:15:06 AM
majortom-RCU
Status: offline
I've used water-based polyurethane as a finish clearcoat over epoxy, stood up to 30% nitro, weathered well, nice finish.
(in reply to c-cat)
       Post #: 2
RE: Compatible clearcoat for epoxy - 2/14/2008 1:27:17 AM
seanreit
Status: offline
I use urethane clearcoats no problem on Epoxy fuse's. PPG 2021 and 2060 are my favorites.
(in reply to majortom-RCU)
       Post #: 3
RE: Compatible clearcoat for epoxy - 2/14/2008 6:40:55 PM
TeamSeacats
Status: offline
you guys are talking about the clear coats after molding - right? I think the question was for in the mold.
_____________________________
Jake Kohl
http://www.teamseacats.com
(in reply to seanreit)
       Post #: 4
RE: Compatible clearcoat for epoxy - 2/14/2008 7:00:04 PM
TrueScale
Status: offline
You can use the transtar in the mold or out.
Chuck
(in reply to TeamSeacats)
       Post #: 5
RE: Compatible clearcoat for epoxy - 2/14/2008 7:08:32 PM
daven
Status: offline
www.klasskote.com
epoxy clear cote, works great. Just sprayed this one this past weekend..
Click to see fullsize image.
Click for fullsize
Dave Norman
klasskote.com
supertrc.com
(in reply to TrueScale)
       Post #: 6
RE: Compatible clearcoat for epoxy - 2/14/2008 11:25:52 PM
c-cat
Status: offline
Thanks for the reply's. I'm more concerned about uv protection on my 84in. offshore cat. as well as compatability with epoxy and release wax.. Any suggestions on when to lay up? After full cure or post (flash or tack). Iv'e used polyester primer in the past with v-ester resin but havent gone the epoxy route untill now. Figure the acrylic urethane is the way to go so my carbon/kevlar doesn't go gold in a year.Any more info would be awsome!
(in reply to daven)
       Post #: 7
RE: Compatible clearcoat for epoxy - 2/15/2008 12:32:29 AM
daven
Status: offline
The KlassKote Epoxy Clear will slightly yellow over time.
Dave Norman
klasskote.com
supertrc.com
(in reply to c-cat)
       Post #: 8
RE: Compatible clearcoat for epoxy - 2/15/2008 12:41:13 AM
TrueScale
Status: offline
c-cat,
Here is what I do and it works well for me.
The afternoon before I do my layup I wax the molds with Collinite (good stuff) then tape
off the flanges and shoot a couple of coats of urethane primer (use your clear coat), let it
tac off which is less than 10 min. your clear will be longer, you will have to feel it out. Pull
off the tape and leave for the day.
The next morning do my normal layup and your good to go. You should not go over 24 hrs.
to do the layup after shooting the paint.
Chuck
Click for fullsize
(in reply to c-cat)
       Post #: 9
RE: Compatible clearcoat for epoxy - 2/15/2008 1:22:45 AM
c-cat
Status: offline
Thanks everyone, this forum is incredible. I'll post some pics soon after 1st. hull out of mold. thanks again.
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU1
