RE: Humogous Problem    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Humogous Problem
Page: <<   < prev  1 [2]
Login
RE: Humogous Problem - 2/14/2008 8:10 AM
firebird78
Score: 105
Last Login: 12/8/2011
Status: offline
this is a tuffy....no room to really get on this thing...at first thought drilling it out seemed to be the only thing...but..and I dont know how much clearence is around the head screws...if u can get a 12point socket thats just smaller then the head of the screw tap it on lightly...might have enuff bite to get it out..dont think theres room..other then that all I can think is to drill it out..just looked at mine....I can see the head of the screw through the cooling fins from the side..might be able to hack the head off with a hacksaw blade..will leave somewhat a burr but might be able to tap off the head then remove whats left with visegrips..alls I know is drilling on that broken hex bit tip is gonna be tuff...
_____________________________
keep the shiney side up, the hammer down and the marshalls bored.....himoto rxb-1...himotoracingusa
Hide Signatures
(in reply to ehroof)
       Post #: 26
RE: Humogous Problem - 2/14/2008 8:16 AM
firebird78
Score: 105
Status: offline
ok the 12point socket isnt going to work..lol...noway ur gonna get a socket in there...not even a 1/4 inch drive....I dont even think I got a nut driver that will fit in there....lol
Hide Signatures
(in reply to firebird78)
       Post #: 27
RE: Humogous Problem - 2/14/2008 5:21 PM
zepena
Score: 100
Last Login: 8/10/2012
Status: offline
quote:
Original Message: Kemo
what kind of hex tool were you using? a ball point?
Those are common to snap... made for low torque applications.
I learned this the hard way once before... used a old knife and junk screw driver to pop out the end of it.
yess thats the same one im using. The tip broke off and is stuck now
< Message edited by MWRthebest -- 2/14/2008 5:30 PM >
Founder of Cool RC Hobbies
Hide Signatures
(in reply to Kemo)
       Post #: 28
RE: Humogous Problem - 2/14/2008 5:31 PM
zepena
Score: 100
Status: offline
yeah im screwed now. Theres nothing that can get it out.
Kemo how did you get yours out?
Hide Signatures
(in reply to zepena)
       Post #: 29
RE: Humogous Problem - 2/14/2008 5:54 PM
ranger4x4
Score: 103
Last Login: 9/17/2010
Status: offline
try using a pick from a mechanics pick set to see if you can get it to come loose. it looks something like a dentisits pick.you might be able to get it out or at least loose. i mean the broken allen wrench not the bolt. or try using a big cut off wheel for a dremel and just cut off the head of the bolt. once you get all the cooling head bolts out you can use vise grips to get the broken one out.
mxt 2-s mega e mt10 viper
Hide Signatures
       Post #: 30
codokas
Score: 100
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: MWRthebest
I didn't see what motor you had--but---if you look at the side of it--between the head and the block-can you see the head screw?
If so--and on my VX's-you can
Take a hacksaw blade-wrap electric tape around the end-to protect your hand and VERY VERY carefully cut through the head screw
There is space(very little,so that is why you have to go slow) between the end of the screw and the engine case
Anyhow-that's what I would try if I were in your place
DOUG
Hide Signatures
       Post #: 31
RE: Humogous Problem - 2/14/2008 5:56 PM
codokas
Score: 100
Status: offline
quote:
ORIGINAL: codokas
DOUG
Once you get the head off you can try to use needle nose pliers to remove the piece left in the block
If that doesn't work-use a dremel tool with a cutting disk in it and make a slice into the piece and use a regular screwdriver to remove it
good luck
DOUG
< Message edited by codokas -- 2/14/2008 6:16 PM >
Hide Signatures
(in reply to codokas)
       Post #: 32
RE: Humogous Problem - 2/14/2008 5:59 PM
zepena
Score: 100
Status: offline
okay im going to go to the store right now to buy a hacksaw blade.
Thank you Doug
Hide Signatures
       Post #: 33
RE: Humogous Problem - 2/14/2008 6:05 PM
codokas
Score: 100
Status: offline
Thank you Doug
Anytime--good luck-let us know how you make out
But remember--GO SLOW and cut in the middle of the screw that you can see
DOUG
Hide Signatures
       Post #: 34
RE: Humogous Problem - 2/14/2008 6:14 PM
codokas
Score: 100
Status: offline
quote:
ORIGINAL: codokas
Thank you Doug
DOUG
One more thing-then I'm gone----if you get almost thru the screw and you;re getting nervous about cutting into the engine--STOP------at that point there will be VERY little holding the screw together---take a drill bit and then try to drill out from the top-that will break in two what is left
Again--just take your time-go very slow doing all of this
DOUG
Hide Signatures
       Post #: 35
RE: Humogous Problem - 2/15/2008 7:47 AM
Kemo
Score: 105
Last Login: 10/19/2008
Status: offline
just pick away at it. It took me a few days, but I wasn't willing to cut off any part of my engine. If you can find pliers thin enough to fit in there, give it a shot.
There are only 10 types of people in this world: those that understand binary, and those that don''t.
AMA: 722748
Hide Signatures
       Post #: 36
RE: Humogous Problem - 2/15/2008 8:40 AM
zepena
Score: 100
Status: offline
no its okay now. I fixed it. It cut trough it and i just bought a 2 new engines so i wont be needing it.
Hide Signatures
(in reply to Kemo)
       Post #: 37
RE: Humogous Problem - 2/15/2008 6:34 PM
hrdcoreglf
Score: 100
Last Login: 12/10/2009
Status: offline
Easy Out screw removal kit ( home depot or auto parts store )
Wisdom is only as good as the person you give it to.
Hide Signatures
(in reply to Kemo)
       Post #: 38
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
