aginzu
CA, USA Status: offline
Well, I made the maiden flight on the A-10 this morning using the stock motors but with a TP 1320 mah 3S battery. I had previously measured the full throttle current at about 15 amps. As predicted by others on this forum, it flew, but just barely. After taking off in about 100 feet, I managed to get around the pattern and the right landing gear came off upon touchdown. The landing was a little rough, but not too bad. It seems that there wasn't much glue holding the gear attachment block on. I also noticed that the fans made some "clicking noise" at lower rpms. There is plenty of gap between the rotors and the fan housing so I don't know where the noise was coming from. If one or both of the fans was contacting something while spinning, that could have contributed to the reduced thrust and poor performance. I had to stay at full throttle for the entire flight (until landing) and the battery was pretty warm when I removed it. On the positive front, the plane handled pretty well once it was airborne, it just felt very underpowered. I now believe that the reports of it being a pretty good flier with more power are correct. It's all academic, however, since I have already ordered a couple of the Hobby City 4400KV motors to do the brushless conversion. I was hoping that I could fly it in the meantime on the brushed motors with reduced performance, but it's so bad that I will wait until the BL's arrive before trying to fly it again. I plan to use two 1320 3S batteries each attached to one of two speed controllers. Overall, one needs to consider this a pretty good looking foam ARF with partially pre-installed servos. The speed controller, battery, charger and motors are pretty useless. The radio, I guess, might work, however I replaced the receiver with a 72mhz version so I can't comment on how well the 27mhz am system would work. Anyone want to buy a brand new 27mhz radio system... cheap? The servos seem to work o.k., for one flight anyway. Had I known what I now know I probably would not have purchased this model, however, it's not a terrible deal for $95 even with the additional cost of the upgraded motors and fans. I recently crashed my Alfa Mig-15 and that one was over $150 without any servos but with a nice 60mm fan assembly. It flew very well with a brushless motor setup. I look at the A-10 as similar to the Mig-15 as a way to get into DF flying. If the A-10 crashes it will only cost $95 to replace, versus $150 for the Mig so it's not really too bad a deal, but it's also not the bargain that a $95 RTF would be.
< Message edited by aginzu -- 7/23/2008 2:04:07 AM >
