RysiuM
Joined: 4/22/2003 From: Elk Grove, CA, USA Status: offline
quote:
ORIGINAL: websterphreaky Is this sim model of the Guanli A-10 exportable to use on the FMS Simulator program? If it is, can I get a download from you? Interesting results, should help decide which direction to go for updated motors and battery. No. Real Flight G2 in Add-Ons Volume 3 has giant scale turbine A-10 simulated (it's about 20lb model). I used this model (flying profile) and changed all parameters (measurements and weight) from Guanli Styro model, then I changed powerplant to EDF using similar to GWS EDF-55 (it was quite tricky to get the trust numbers right). Simulated model weight 1.6lb and depends on power (easy controlled by number of cells) it behaves like with stock motors or simulated brushless setup. I really like RF G2 because it gives the "feel" of the model and it is easy to check it the model "can do that" without breaking it into pieces. Real Flight has something in it (I don't know how it works) that the flying characteristics depends not only on measurements and profile, but it varies from one model to another. In example if you modify CAP 232 and put all measurements from GP Patty Wagstaff Extra it will not behave like the real model. But if you modify Extra 300 and put exactly the same numbers, it will fly like a real one. Something is telling me, that RF G2 has some "hidden" calculations that varies from model to model. This is why it is important to modify the same airplane type to achieve replication of your model. I did it for many of my models and results were amazing. Sorry for your messed up order at nitroplanes. I have read about them and theirs terrible customer service many times. If you get lucky and your order is not messed up, package is not damaged or factory did not screwed up, you can get good deal from them. If you have problems (and it happened many times) better take the loss and save yourself from frustration. I guess not having customer service is the reason for their low prices. Unlike Walmart, they don't get any returns from customers
_____________________________
Mather Aerospace Modelers, Inc. AMA Gold Leader Club, Charter #1243, Sacramento, CA
