RE: Nitro Planes A-10 Warthog for 95 dollars
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> RE: Nitro Planes A-10 Warthog for 95 dollars Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 6:20:26 AM
RysiuM
Status: offline
This means, I can cut the bad ESC and try to cure it. I will let you know if I find anything.
_____________________________
Mather Aerospace Modelers, Inc.
AMA Gold Leader Club, Charter #1243, Sacramento, CA
(in reply to vettster)
       Post #: 201
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 5:51:09 PM
swiggyj
Status: offline
hello everyone, just joined. I have a guanli (sorry) a-10. i am an intermediate flyer. i started with the parkzone cessna 210 micro - love it. great for any day flying as long as the wind is below 5 mph (18g plane). i have crashed the a-10 numerouse times - repairs pretty well. i upgraded to a 1100 lipo battery and wow! what a difference. i have had three really successful flights now with two of the landings not so hot. i do have to say i bought it for the looks, but with the battery upgrade, it flies really well. i live in Boulder, CO. even up here it flies well. i think i will try the parkzone t-28 next, then the f-15! boy, i feel the wallet shrinking already
jason
(in reply to RysiuM)
       Post #: 202
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 6:14:13 PM
RysiuM
Status: offline
quote:
ORIGINAL: swiggyj
How many cells?
(in reply to swiggyj)
       Post #: 203
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 6:15:28 PM
websterphreaky
Status: offline
quote:
ORIGINAL: swiggyj
jason
What voltage is the 1100 lipo battery? What is the "C" (discharge) rating and the weight of the battery? What brand? Did you change out the ESC; because the stock ESC does have a very low amperage rating, probably only 10C, which a 1100 mAh LiPO should fry quickly.
UH-1 Gunship and AH-1H jockey 1969 - 1971
       Post #: 204
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 7:09:02 PM
RysiuM
Status: offline
quote:
ORIGINAL: websterphreaky
What rating are you talking about? I flew stock ESC with 3 LiPo - no problem there. The FETS B414 used in stock ESC is rated 110A (by catalog), BEC is 2940 is rated 1.25A constant and 3.5Amax, and because it is in TO-263-3 case it can handle more power drop than most BEC used in brushless ESC. The only problem I can see in 3s is that motors will not last long. With 8V they take over 8A eachwhat is already quite hot for 370 size motor.
(in reply to websterphreaky)
       Post #: 205
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 7:36:21 PM
swiggyj
Status: offline
it says - common sense rc 11.1v 1250mAh, 10 amp continuous discharge. i get about 15 minutes flight time.
       Post #: 206
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 7:38:13 PM
swiggyj
Status: offline
sorry, it says 8c in the corner? i am pretty new to this so please be patient.
       Post #: 207
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 7:41:19 PM
RysiuM
Status: offline
quote:
ORIGINAL: swiggyj
Then you might have very strong thermals in Colorado - 15 minutes of 1250mAh is average 4C discharge = 5A, less then 2.5A for motor (there is something for the radio too). Congratulations. Unless you do a slope soaring you just invented "perpetuum mobile".
       Post #: 208
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 7:46:46 PM
swiggyj
Status: offline
lost me with all that jargon. what are you saying? temp is around 75, humidity 15-25%. please explain? First flight was about 5 min. second was two flights, same battery 7:00 pm 70 deg with 20% humidity total of 15 minutes, wind was calm to 3 mph. third flight was 10 minutes and i landed on a bush, lol - broke the tail stabilizer, glued and good to go.
< Message edited by swiggyj -- 6/19/2008 7:55:26 PM >
       Post #: 209
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 8:12:21 PM
RysiuM
Status: offline
quote:
ORIGINAL: swiggyj
Are we talking about Guanli A-10 EDF twin? This plane stock on the bench took 8.5A for each engine powered by 8V. On the field it hadrly flew with 11V battery (taking around 20A total). I am talking about the current taken from the battery to power both engines (stock brushed 370 size) on Guanli A-10. 1250mAh 10C battery can not handle such load, but even if it could, it should be empty in less than 3 minutes.
Modified for brushless setup Guanli A-10 performs well on 10V 27A (it is 270W !!!).
< Message edited by RysiuM -- 6/19/2008 8:13:53 PM >
       Post #: 210
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 8:39:28 PM
swiggyj
Status: offline
ok, i'm really confused now. it definitely flies for more than three minutes. and very well i might add. i will video it and send it in. please be patient again.
       Post #: 211
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 8:45:06 PM
websterphreaky
Status: offline
quote:
ORIGINAL: RysiuM
quote:
ORIGINAL: swiggyj
I agree, no way it should stay up in flight that long, something "fishy" in that claim. Besides, at 11.1v for the battery output, the 8v motors should be leaving a smoke trail after a couple minutes.
       Post #: 212
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 8:55:30 PM
swiggyj
Status: offline
it is what it is - video on the way
       Post #: 213
RE: Nitro Planes A-10 Warthog for 95 dollars - 6/19/2008 9:50:16 PM
websterphreaky
Status: offline
Richard,
Did you know about this RC supplier up in Nor Cal - South Bay Area? Has lots of DF supplies, lots of GWS parts, VG prices on NiMH batteries, pre-made packs, props, etc.. BL Motor prices are not that hot, but has a big selection.
Aero Micro - http://www.aeromicro.c
