RE: Aquacraft Mini Rio
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - Electric >> RE: Aquacraft Mini Rio Page: <<   < prev  20 21 [22] 23 24 25 26 27 28 29   next >   >>
Login
RE: Aquacraft Mini Rio - 8/1/2008 2:08:45 AM
JonKBMW
Status: offline
quote:
ORIGINAL: Wheelnut
quote:
ORIGINAL: banzilla
Just a quick question. Whats the best way to waterproof an ESC? Like a mamba-25 for example. I have tried a few ways but havent been able to keep it dry. Thanks.
Have you been taping the hatch shut??
I don't undersand what you mean. The hatch as in the thing with the swivel clip, or the dual round jobbies? My boot went upside down today and no water got in with nothing taped!
(in reply to Wheelnut)
       Post #: 526
RE: Aquacraft Mini Rio - 8/1/2008 3:28:30 AM
Wheelnut
Status: offline
If no water gets in they why are you worried about water proffing the esc for?
_____________________________
Fly Like an Eagle
(in reply to JonKBMW)
       Post #: 527
RE: Aquacraft Mini Rio - 8/1/2008 11:40:33 AM
banzilla
Status: offline
No I havent been taping it shut. I just wanted to know a good method of waterproofing a esc. I'm looking into conformal coating, and a product called corrosionx. I get minimal water, but when esc gets wet, it acts up, then I have to wait for it to dry out for it to become normal.
       Post #: 528
RE: Aquacraft Mini Rio - 8/1/2008 1:02:17 PM
Wheelnut
Status: offline
One of the main goals of setting up a boat is to make sure water doesn't get in. Taping your hatch shut is one of the easiest ways to do that.
Corrosion X will work fine. But you will need to cut the plastic cover off the esc to do it.
Fly Like an Eagle
(in reply to banzilla)
       Post #: 529
RE: Aquacraft Mini Rio - 8/1/2008 7:22:48 PM
banzilla
Status: offline
TY sir
       Post #: 530
RE: Aquacraft Mini Rio - 8/3/2008 10:31:59 PM
pocketear
Status: offline
Hey guy i put a vr3 in my boat it way faster now but messed up my lipo its a 1050 mah 2 cell and it was swelled up and now it wont charge i dont know what to do i orderd a 3 cell 1500mah i also have a problem with the tx it wont work far away and when it does work it leeps it only happens sometimes but what can i do besides buy a new one anything would help
Thanks!!!!
       Post #: 531
RE: Aquacraft Mini Rio - 8/3/2008 11:42:43 PM
Kmot
Status: offline
The "leap frog" syndrome is typical of these boats. From what I can gather off the internet, it is a 50/50 chance we get crappy radios with this boat. I got one too! At first I thought it was weak transmitter batteries, but it is the Aquacraft (Futaba) radio:
http://www.youtube.com/watch?v=VDU-_tGCxxA
DRILL BABY DRILL!!!
(in reply to pocketear)
       Post #: 532
RE: Aquacraft Mini Rio - 8/4/2008 1:57:34 AM
pocketear
Status: offline
so you cant even take the crystal out of the tx so what can i do i have the blue boat its 26.something i have many transmitters so if i buy the right cyrstyle will that fix the problem
(in reply to Kmot)
       Post #: 533
RE: Aquacraft Mini Rio - 8/5/2008 6:21:48 AM
smaerd58
Status: offline
Chuck E. Cheese, can you use regular 2/3A Cells Nimh with the esc you gave link to? Or do you have to use LIPO? Thanks
< Message edited by smaerd58 -- 8/5/2008 8:05:30 PM >
FE Finatic
(in reply to Chuck E. Cheese)
       Post #: 534
RE: Aquacraft Mini Rio - 8/5/2008 6:53:02 PM
Wheelnut
Status: offline
I don't understand why you guys don't get it.
There is no esc that can only use lipo or nimh. They all can use either.
PS. that would be 2/3A cells
Fly Like an Eagle
(in reply to smaerd58)
       Post #: 535
RE: Aquacraft Mini Rio - 8/5/2008 7:57:56 PM
smaerd58
Status: offline
Easy there Wheel.... Some ESC says LIPO and don't give specs for NIMH so I asked the question. I have the Blue AQ MR and the junk radio antenna pulled apart and I have the leap frog affect. So I am going to gut out and go with "Chuck E. Cheese" recommendations of brushless set up with the. HXT 2835 (380S) 2700kv Brushless Inrunner and SuperSimple 30A ESC. My other question about the ESC and I hope I don't get blasted on this one either is do you have to have a pistix to use this on pistol grip radio's? I don't know if this is for airplanes or surface? Hopefully Chuck E. Cheese is watching and can shed some light on this. Thanks, Rick
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by smaerd58 -- 8/5/2008 8:07:15 PM >
FE Finatic
       Post #: 536
RE: Aquacraft Mini Rio - 8/5/2008 8:36:01 PM
Wheelnut
Status: offline
No harm meant.
For the record I would like to make a statement for anyone wondering.
7.2 Volts DC is 7.2V DC whether it comes from lipo or NIMH or NICD or anyother type of DC battery or powersupply. DC voltage is DC Voltage no matter where it comes from.
The esc does not care what type of battery the voltage is coming from, just as long as it is not too much or too less voltage. Most electronic equipment has enough tolerance to withstand slightly more voltage than it is rated for. For instance, an esc rated for 7.2V can more than likely withstand 8.4V with no problem. The trick here is that with NIMH batteries you can jump 1.2V easily by adding one cell, giving your model a pretty good boost in speed. But you can't do this with lipo because each cell is 3.7V wich by adding another cell will probably put the voltage out of range for the esc mentioned here and fry it.
Fly Like an Eagle
       Post #: 537
RE: Aquacraft Mini Rio - 8/7/2008 4:41:43 AM
dadyo39
Status: offline
Need some help I have mini rio with the v3 motor .047 piano wire shaft octura x 432 plastic prop. The boat runs fine except the battery get smokin hot have had some wire coatings melt. just using stock pack HELP
Mark
       Post #: 538
RE: Aquacraft Mini Rio - 8/7/2008 1:13:51 PM
Basstronics
Status: offline
Need new wires on the pack and deans connectors...
(in reply to dadyo39)
       Post #: 539
RE: Aquacraft Mini Rio - 8/13/2008 4:12:43 PM
Wheelnut
Status: offline
Do any of you guys know if the mini rio stock setup has reverse or not. I can't remember. Thanks
Fly Like an Eagle
(in reply to Basstronics)
