Nina Roses Dad
Joined: 2/12/2008 From: San Francisco, CA, USA Status: offline
I used a 7/64 bit to bore out the holes for the setscrews on the replacement rudder arm. If you do that, they screw in easily and you won't strip them. You'll also need to bore out the holes in the rudder arms where the link between the two rudders slips in (not sure which bit to use, as I used a #0 phillips to ream them out). Use a 1/8 bit to bore out the hole on the starboard control arm where it connects to the pushrod that comes from the steering servo. That way you work around the sticky balljoint at the end of the pushrod and it won't break the rudder arm. Took the boat back to the pond and ran it 4x. Only a few drops of water inside. If you nail the throttle wide open from a standstill it takes awhile for the boat to accelerate and get on plane, up and out of the water, partly exposing the prop, taking some of the load off the motor, and getting the RPMs up. I'm not sure how much of this is cavitation and how much of it is a big, fully-submerged-until-things-get-moving prop (much bigger than the prop on the RR2) putting a heavy load on the motor. So since this may be unnecessarily heating up the motor, draining the battery, and reducing your runtime, don't just nail the throttle wide open with this boat when it's sitting still - give it a slow, gentle squeeze (or tell your kid that's the way to do it). In the M-R the motor definitely runs hotter than the RR2, which is no surprise with the bigger prop and also since in the RR2 the water cooling coil wraps around the motor and the MR just has that little tube attached to that motor mount/heatsink plate. Probably ok running on the stock pack, but it will run hotter on a 2S lipo. At the end of the first two runs I couldn't keep my little finger on the motor can for more than 5 seconds, but once I figured out how to finesse the throttle, the motor was barely warm at the end of the 3rd & 4th runs. I wasn't running on a new pack, but on two used packs from our RR2s (bought on eBay used), as I am going to eBay the still-sealed pack & charger that came with the boat (and put the $ toward LiPos). I should be able to use the Lipos for this boat in the Sky Fly airplane that I just bought as well as in my Hammer EP (connected in parallel) and in a helicopter (someday) so they'll get plenty of use and I won't need to have a lot of money tied up in 3-4 packs for each one of our toys.
_____________________________
I liek yer cents of hummer!
