Nina Roses Dad
Joined: 2/12/2008 From: San Francisco, CA, USA Status: offline
quote:
ORIGINAL: sussur Ey guys, has anyone tried running the Mini Rio with 8.4V 1100mAh 2/3A NiMH battery? can the stock ESC handle the extra volts? Thanks Richard In the mod thread for the Reef Racer (which has the same electrics) I've heard it works great. Even a 2000mah AA 6-cell makes a difference in the RR over the stock pack (in my own experience) though the 2x3 one I have won't fit inside the MR. The motor in the Reef Racer runs cool because it has a cooling coil wrapped around the motor, but the MR doesn't, it just has that plate and a short piece of tubing (even though Aquacraft's website would still have you beleive that "The factory-installed 380 motor features a water-cooling jacket for efficient performance even at high speeds." But, those 7 little cells are going to overheat because the motor will draw more current because it's turning the prop faster against the resistance of the water. Runtime will be reduced. I've decided to go with LiPo in my MR and install a cooling coil around the motor's can. I was thinking about 7 cells or LiPo myself and so I took some amps readings in the bathtub from a Reef Racer just to get an idea of what the difference might be with the extra cell (same electrics, subsuface drive, different prop (the MR is surface drive and I'd have to fool around too much with whether the boat was on plane, how much the prop was submerged and all that BS). On the 6 cell stock pack the draw was about 4.75, on 7 sub-c cells, it was close to 10 (and the ReefRacer wanted to take off like a raped ape). Of course, you'd never fit 7 sub-c cells into either boat, but I was more interested in what the motor might draw and how much more thrust it could deliver rather than explore the limits of what a 2/3A pack could deliver. So, my next trip to the LHS will be to get a piece of 3/16" tubing so I can make a cooling coil like the one in the RR. When I install that, I'm going to rotate the motor can 90 degrees so the oval-shaped holes next to the brushes are at 12 and 6'oclock so the brushes can run a little cooler (there's no fan in the can but warm air rises and if the holes are at the top & bottom of the can instead of at the sides it can only help). Next comes a bracket (to hold a 2000mah LiPo over the driveline) that I'll attach to the cooling plate on the motor (using the holes that used to hold the little cooling tube). I'll probably put heavier wires on the ESC's battery lead and change over to Deans mini plugs. I keep thinking that if I go LiPo I might as well go brushless too. Not so much for all-out speed that's going to give me driveline headaches, but for just enough speed to get the boat on plane quickly, and the higher efficiency that's going to give more runtime. So I'm thinking a lower Kv brushless motor on 2C would make the boat more fun for my 7yo daughter and then I could put in a 3C pack and have my fun almost like having 2 boats in 1...
_____________________________
I liek yer cents of hummer!
