Global Ultimate ARF
Tower Hobbies
Logged in as Guest
  Printable Version
HPI Racing E10 Lamborghini Touring RTR 4WD Car
Seller:  Erick Royer
Details:   $150.00   |  7/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> User Product Reviews >> Global Ultimate ARF
Page: [1]
Login
Global Ultimate ARF - 3/7/2002 6:45:48 AM
jimcork1
Status: offline
Info.. I have the Global Ult. flying with Saito .91 4stk, 14x6 prop and built w/0 incident Bottom wing, +1 on the top. I think the l/gear is too short for the prob clearance and will make an extension. The landing attitude is too nose low and results in higher than normal landing speed,, but this does prevent tip stall. The plane is set with max. throws and for me it could use a little more on the ail. to suit me. It is a vertical plane and flys very well. If I built this again, I would leave a 1/16" gap in the ailerons to keep them from binding at high throws. This is why I am limited. Plane is great,, balanced on the cg and will do great flat spins. Fun to fly and do aero. I built it with the 2deg right thrust and flew it,, then set the engine to zero/zero,, for better t/o and landings. Good plane.. Jim
I did not use the pushrods in the kit,, metric and had difficult getting threaded rod to fight right so switched inners to nyrod.
       Post #: 1
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
