RE: 1/4 Scale F4U-1A Don Smith Plans Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: 1/4 Scale F4U-1A Don Smith Plans Build
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: 1/4 Scale F4U-1A Don Smith Plans Build - 3/20/2008 3:51:12 AM
Riddle4U
Status: offline
..and the crowd goes wild [clapping in the gallery]! NCIS, with all of us staring intently at your tailwheel, I must say all this scrutiny was worthwhile. To me, the location of the whole assembly when down is the most noticeable improvement (with hinge point's relative location). Nice change! Now with this over with..get to work so we can pick on something else . I think this has been a good example of how this RCU benefits us all. Looking forward to future progress!
(in reply to NCIS)
       Post #: 76
RE: 1/4 Scale F4U-1A Don Smith Plans Build - 3/20/2008 2:05:30 PM
rwright142
Status: offline
quote:
ORIGINAL: kkozy
RWRIGHT, Thans for the info, I`m sure it`ll come in handy. As for me though, I`m planning a trip up to my home town ( Michigan City In ). That`s only about 20 miles from Volpo. As i said, I know the owner, and I`ll be in the area. I plan on putting the long version on mine just because i like the way it sets. Just like the difference between a `68 and `69 camero, same body, just sets a little different. I would like to see whatever pictures you took of the Cincinati bird though.
I know Jim too. I visited his -5 when it was here for service. I took a lot of pictures and video of it too. He's a regular at the Mt. Comfort airshows and always puts on a demonstration. I'll get more pictures of the FG-1D up there for you.
NCIS,
LOVE the TW! I must have missed where you got it or if you made it - I'll go back and check. Also, the position now looks great!
< Message edited by rwright142 -- 3/20/2008 2:09:45 PM >
_____________________________
In the works: 1/6 Scale F4U Corsair
(in reply to kkozy)
       Post #: 77
RE: 1/4 Scale F4U-1A Don Smith Plans Build - 3/20/2008 6:29:48 PM
NCIS
Status: offline
rwright124,
I got it from the Man of retracts. Darrell at Seirra. I can't wait to see what the mains are going to look like if this TW looks so great. He knows his stuff and is an excellent craftsman and machinist.
Thanks for the compliment Luke I appreciate it more than you know. Now it's onto where to put the air tanks. Any sugesstions from the crowd. I just don't know where they would be best located. I'm thinking right behind the cockpit wall up high. They will be out of the way and I can service them if need be.
Gibbs
(in reply to rwright142)
       Post #: 78
RE: 1/4 Scale F4U-1A Don Smith Plans Build - 3/20/2008 6:59:56 PM
Riddle4U
Status: offline
Gibbs, I saw an 82" Brian Taylor Corsair on the Scalercbuilder site. It put one tank parallel to the leading edge on each inner gull panel. I thought that was kind of novel; it frees up room in the fuse and puts the weight in front of CG. It is a nice use of otherwise wasted space, but i'm not sure how handy the air lines would be. I think you could put the valve and servo in the wing and then you only need to connect the servo (if your tail retract isn't air)! Glad your stickin in here I forget how darn big your plane is, you might be able to fit them in the cockpit's map pocket
< Message edited by Riddle4U -- 3/20/2008 7:02:29 PM >
(in reply to NCIS)
       Post #: 79
RE: 1/4 Scale F4U-1A Don Smith Plans Build - 3/20/2008 7:51:56 PM
NCIS
Status: offline
Riddle4U,
It's big enough that I keep hitting the tail on the ceiling joists when I go to turn it around to work on the other side and visa versa. Plus it doesn't even have the 5 1/4" tailcone on it yet. Anyway I cut out the bellypan for the wing and also revealed the wing saddle. The plan doesn't call for putting anything on the formers from the front to the back of the saddle. I'm putting on 1/32" plywood. That way I can use resin and microballoons if the wing doesn't fit perfectly. And they never do. At least for me anyway.
Gibbs
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Riddle4U)
       Post #: 80
RE: 1/4 Scale F4U-1A Don Smith Plans Build - 3/20/2008 11:30:37 PM
cimara
Status: offline
Looks great Barry .How s the great planes pro glue working ? is it a big pain wating on it to dry .Looking at options on mine
Winston
Corsair BrotherHood #6
(in reply to NCIS)
       Post #: 81
RE: 1/4 Scale F4U-1A Don Smith Plans Build - 3/22/2008 1:15:05 AM
NCIS
Status: offline
Winston,
I only use the wood glue when it's something that can be clamped. Otherwise it's CA and accelerator. When I was framing I used almost all the wood glue for that. I wanted time to fix any thing that seemed twisted or uneven. I am leveling everything I glue onto this bird so it better fly level. I can't wait til you get yours going. How's the TF Giant doing? Right now I'm working with the kit cutter Pat and trying to figue a way to hold the wing to the fuselage. In the plan it only shows wing hold down bolts but nothing for them to screw into. Don must of had a brain fart when he drew that section. Anyway you will see what I mean when you get this kit and start to try and make it match the plan. I is mostly guess work. I got one of my wing saddles finished today and found out when I checked the front brace on the fuse that the engine box that extends back to former #4 was to high and the wing brace sat on it instead of the saddle. You might see the engine brace dremeled down in this picture. of the saddle. Out came the dremel and that problem is solved. Now on to the next problem.
Good luck,
Barry
Click for fullsize
(in reply to cimara)
       Post #: 82
RE: 1/4 Scale F4U-1A Don Smith Plans Build - 3/22/2008 2:05:04 AM
cimara
Status: offline
I have heard that about all his plans (not being complete ).You have got a great scale guy (Luke )watching your thread to help with that part of the build .On the TF giant i am looking for a good warm day to get the color coats on then cover the control surfaces wich is the part i despise to do then put it all back together
Winston
(in reply to NCIS)
       Post #: 83
RE: 1/4 Scale F4U-1A Don Smith Plans Build - 3/22/2008 3:31:29 AM
tessex
Status: offline
Gibbs,
Just wanted to say great looking project so far. Sure would love to start working one along side of you, but it'll have to be a few years before I start building something that large. Anyway, keep up the good work. I love to see the craftmanship!
I'll be posting photos of my 1/8th scale in the other thread sometime tomorrow, or Sunday.
Tom
       Post #: 84
RE: 1/4 Scale F4U-1A Don Smith Plans Build - 3/22/2008 3:41:54 AM
David Jackson
Status: offline
Hi NCIS,
To mount the wing, I am using 1/4" ply as a wing mounting plate and two 1/4x 20x 4 1/4 nylon screws to hold the wing in place. It not pretty, but it is functional. I had initial thought about gluing hardwood blocks to the inside of the wing saddle, but decided the area was not strong enough.
Also, I mounted the TW today. I realized that once that section of the fuse is completely sheeted, there is no way to service the air cylinder if there is a problem. The pictures below show where the air cylinder is mounted and also the wing mounting plate. I would certainly be interested in your method for mounting the air cylinder for the TW.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by David Jackson -- 4/13/2008 2:48:08 AM >
(in reply to NCIS)
       Post #: 85
RE: 1/4 Scale F4U-1A Don Smith Plans Build - 3/23/2008 12:44:32 AM
NCIS
Status: offline
David,
Darrell said there is no need to worry about the air cylinder. It will work as long as you have the plane. I might make a hatch to get to the air line and that's about it. You just solved two of my problems and I'm copying both your hold down plate and air cylinder ideas. Here are my air tanks installed all tucked up nice and neat in front of the main spar and cockpit. I used two 1/8" pieces of balsa and glued them together and made two of them. I dremeled out the holes to the exact size of the tanks and glued them to the formers. They follow the curve of the formers. Nice and neat and out of the way. What's nice is they are easy to get to from the open wing saddle area. Heres a couple pic's.
Barry
Click for fullsize
Click for fullsize
(in reply to David Jackson)
       Post #: 86
RE: 1/4 Scale F4U-1A Don Smith Plans Build - 3/23/2008 1:20:28 AM
Riddle4U
Status: offline
Looks good NCIS, that wing mount idea (for the tanks) didn't sound attractive? I am planning for my 1/6th Corsair for Reapergrims group build. Keep it up, that sure is a biggun!
(in reply to NCIS)
       Post #: 87
RE: 1/4 Scale F4U-1A Don Smith Plans Build - 3/23/2008 7:15:54 PM
NCIS
Status: offline
David,
As you can see from this picture your method just went bye-bye. Do you think if I were to put the piece of plywood just above the frame work of the cockpit floor held with epoxy and traingular stock that it would be sufficient to hold the wing down. I can't move the floor or I can throw the $200.00 custom cockpit out the window. This is the problem with custom work where everything is not taken into account. If the designer of the cockpit would of realized there had to be a wing hold down plate he would of made the cockpit differently. It's not his fault, it is just that it wasn't on the plan and he only built the planes area surrounding the cockpit. Help me out with this one. Would the wing hit the plywood before making contact with the wing saddle if I did what I intend on doing? I'm asking because you already have the wing built and have attached it to the plane. How much space is there between the top of the wing and the bottom of you plywood hold down pl
