mclina
MA, USA Status: offline
No, it wasn't a loop. It just went up a little bit, then nosed into the ground about 50' from me. If I had thrown it without the engine running, it would probably have done about the same thing. The CG is forward of that was called for on the Cororoo plan, by about 1/2", maybe closer to 1". I have hand launched my combat SPAD, which weighed the same, and used the same engine, and it climbs like crazy. There must be a trick to getting a flat wing to fly. Perhaps it is just way underpowered, like I was told by GreenSpeed way back in Post #4 .
< Message edited by mclina -- 2/26/2008 10:46:08 PM >
_____________________________
If all of your friends were named Cliff, would you jump off them? - Hugh Neutron
