RE: Delta
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> RE: Delta
Page: <<   < prev  1 2 [3]
Login
RE: Delta - 3/8/2008 8:32:20 PM
mclina
Status: offline
Thanks Microsprint, but it's done. I did have the elevons working correctly. It is possible there wasn't enough throw, but I don't know. The engine, radio, and servos have already been removed and I have started on the next SPAD.
I'll start a thread when I get further into the build, but here's a preview. I have a 36" pvc fuse, and I have built a wing. The wing is made from 4mm coro, using the Defender plan, except, I have built it with a 48" wingspan. I am going to build it as a tail dragger.
Thanks for all the help on the Delta. Maybe one day I'll try to rebuild it.
_____________________________
If all of your friends were named Cliff, would you jump off them? - Hugh Neutron
(in reply to microsprint9)
       Post #: 51
RE: Delta - 3/8/2008 8:52:04 PM
microsprint9
Status: offline
Or i can send you the plans for the delta i made, it is actually a crazyherb cheap delta, i will see if i can find the link to his website if you are interested.
(in reply to mclina)
       Post #: 52
RE: Delta - 3/9/2008 12:58:48 PM
mustangman177
Status: offline
Mocrospring9
Could you post the plans on your delta design ? I too would be interested in seeing them.
Cary
       Post #: 53
RE: Delta - 3/10/2008 3:14:35 AM
microsprint9
Status: offline
Like i said they were crazyherbs plans not mine, i just made it out of coro instead of foam, here is the link, it is the CHEAP DELTA http://www.flybyphotography.com/CrazyHerb/index.htm
(in reply to mustangman177)
       Post #: 54
RE: Delta - 3/11/2008 2:00:54 AM
mclina
Status: offline
That's a great site. He makes it look so easy, I feel like a complete idiot.
       Post #: 55
RE: Delta - 3/11/2008 2:52:06 AM
microsprint9
Status: offline
I've always found delta's to be very easy to build and fly, that is why i'm confused that your delta did not fly, i've never had one nose in from launch, only do backflips ( way too tail heavy ).
       Post #: 56
RE: Delta - 3/11/2008 2:58:19 AM
microsprint9
Status: offline
Here's one more link to a SPAD i built a while back http://www.rcuniverse.com/forum/m_4247028/tm.htm If your going to build one i would cut 2-3" off the nose as CG was an issue and i had to add too much lead in the tail to balance it, and it was just too heavy for my .40LA, but adding a bigger engine would only hurt my CG issues. On the second one i built i extened the LE to a point ( no nose ) and this was much better and that one flew for a long time until i finally retired it.
       Post #: 57
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.484RCU1
