Wood props on SP series?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> RCV Engines Support >> Wood props on SP series?
Page: [1]
Login
Wood props on SP series? - 2/17/2008 4:52:42 PM
buzzard bait
Status: offline
Is it possible to use wood props on the 2:1 geared RCV engines? I want to be able to use near-scale props on WWI types, but unless they are wood it will defeat the purpose. I heard the SPs need the mass of a composite prop, but wanted to make sure.
Thanks in advance,
Jim
       Post #: 1
RE: Wood props on SP series? - 2/18/2008 8:53:45 PM
andi3142001
Status: offline
Hello,
I used the APC prop recommended by RCV for the first 2 hours. Thereafter switched to a much lighter scale-like carbon prop. Works fine.
regards
Andi
(in reply to buzzard bait)
       Post #: 2
RE: Wood props on SP series? - 2/19/2008 1:06:52 PM
RCV Engines
Status: offline
Hi Jim
We always use and recommend glass composite propellers, however wooden propellers can be used if necessary and have been used in some RCV testing. It is important however to use good quality/heavier wooden propellers because generally wooden ones are too light and do not produce the flywheel effect. A point to note is that RPM figures will be lower when using wooden propellers.
Best regards
Stephanie
_____________________________
Technical Support
RCV Engines - UK
(in reply to andi3142001)
       Post #: 3
RE: Wood props on SP series? - 2/20/2008 12:00:05 AM
buzzard bait
Status: offline
Thanks for the responses. I would use hard maple, not beech or any of the other lighter woods. Jim
(in reply to RCV Engines)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
