Hitec Optic 6 Aileron mixing with D/R
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Hitec Optic 6 Aileron mixing with D/R Page: [1]
Login
Hitec Optic 6 Aileron mixing with D/R - 2/17/2008 5:11:23 PM
export!
Status: offline
I'm trying to set up my first plane with dual aileron servos. I have a 6ch RX.
I set PMx1 and activated it as channel 1 master, channel 6 slave. I did manage to get proper aileron response. Problem is when I try to set dual rates for channel 1. When I flip the switch I lose all movement on channel 6.
I can verify during the setup that when I flip the DR switch the setting will show OFF. There must be a way to do this - what am I missing?
Thanks!
Scott
_____________________________
"We demand rigidly defined areas of doubt and uncertainty"
       Post #: 1
RE: Hitec Optic 6 Aileron mixing with D/R - 2/19/2008 4:55:54 PM
Brendan Lugo
Status: offline
You don't need to use the P-mix function for this. The Optic supports a dual aileron setup using channel 1 and 6. Just activate your FLPN mix for this and your D/R will control both channels.
Hitec RCD
Multiplex USA
(in reply to export!)
       Post #: 2
RE: Hitec Optic 6 Aileron mixing with D/R - 2/20/2008 2:08:19 AM
export!
Status: offline
Thank you very much.
(in reply to Brendan Lugo)
       Post #: 3
RE: Hitec Optic 6 Aileron mixing with D/R - 3/13/2008 2:33:30 PM
export!
Status: offline
Loving this radio but still learning; Another quick question.
I have a 3 channel delta with elevons enabled and added a bomb door. 3 servos total now. The RX in this model is a 4 channel. I really wanted to use my retract switch to drop the payload.
I slaved channel 4 off channel 5. Seemed to work at first.
But, as I switched to dual rates on SW-3 I lost the relationship in my programming and the bomb door servo centered. Hmm...
I tried the other slot, PMx2 and got the same behavior when I switched D/R SW-1.
I guess I'm just not grasping the relationship between the programmable mixes and the dual rate switches. Is there a way to slave ch4 RX off ch5 TX and have ch4 unaffected by either D/R switch?
Thanks again!
Scott
       Post #: 4
RE: Hitec Optic 6 Aileron mixing with D/R - 3/13/2008 6:17:35 PM
MikeMayberry
Status: offline
Unfortunatley, you are limited with your options here. Unless you want to get a 5+ channel receiver, this is your only option.
Mike.
< Message edited by MikeMayberry -- 3/14/2008 6:07:21 PM >
Hitec RCD Rep
http://www.hitecrcd.com
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
