Revo 2.5R NOT SHIFTING    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> Revo 2.5R NOT SHIFTING Page: [1]
Login
Revo 2.5R NOT SHIFTING - 2/18/2008 12:27 AM
superman11
Score: 100
Last Login: 8/8/2010
Status: offline
I have my Revo tuned properly, and it is running really good, it will get going very fast, but it won't shift. Not only will it no shift in drive into second gear but it will not shift into reverse either. Does anyone know what is going on, I really need some help.
_____________________________
T-Maxx 2.5 W/Pull Start, Nova Cooling Head, RPM Arms, Big Bore Shocks, VG Cage, Motor Saver Filter and High Torque Servos
Hide Signatures
       Post #: 1
RE: Revo 2.5R NOT SHIFTING - 2/18/2008 7:04 AM
beer=food
Score: 100
Last Login: 8/10/2008
Status: offline
Re- set the opti drive first, make sure its all working fine, its a failsafe for reverse.
Second gear can be adjusted with a HEX at the top of the gear box, it may be set to change to late, dont turn the hex much, it can fall out and end up at the bottom of gearbox, requiring a full pulldown to fix, adjust a little, 1/8 of a turnish then run it see if it changes.
If its set right and wont change in any position your top end is probably rich and it cant get the revs up, or you have low compression and ie, the revs wont get high enough for a second change.
Re- set OPTI drive FIRST.
my revo is a bird, my baja a brick,
when l get em airbourne, its really quite sick,
all fun and games till they come back down,
and l land em like a frootloop backwards-arss clown !
Hide Signatures
(in reply to superman11)
       Post #: 2
RE: Revo 2.5R NOT SHIFTING - 2/18/2008 2:33 PM
RCCanuck
Score: 100
Last Login: 7/8/2011
Status: offline
it won't shift into reverse if the RPMs are still too high...it needs to be at dead idle to shift into reverse..
2.5 Tmaxx// T Maxx-Picco.26//2.5 Race Spec maxx//Savage SS//Brushless Micro T's//Micro DT ...all controlled by Spektrum
Hide Signatures
(in reply to beer=food)
       Post #: 3
RE: Revo 2.5R NOT SHIFTING - 2/19/2008 10:00 PM
superman11
Score: 100
Status: offline
Oh no it should definitely shift, it halls ass. And even when I stop like I hit a wall or something it still won't go into reverse.
Any more suggestions?
Hide Signatures
(in reply to RCCanuck)
       Post #: 4
RE: Revo 2.5R NOT SHIFTING - 2/19/2008 10:50 PM
RCCanuck
Score: 100
Status: offline
what is your idle doing? is it idling a little high? it won't go into reverese if the idle is too high.
Hide Signatures
       Post #: 5
RE: Revo 2.5R NOT SHIFTING - 2/19/2008 10:55 PM
superman11
Score: 100
Status: offline
I don't know how it idles. I am new at this, how would I know?
Hide Signatures
       Post #: 6
beer=food
Score: 100
Status: offline
What have you done, did you adjust the HEX nut in the gear box ?
idle to fast, blublublublublublkubkkbu
idle good, blub blub blub blub blub blub blub blub blub .
idle to slow blub blub blu puff stall.
< Message edited by beer=food -- 2/19/2008 10:56 PM >
Hide Signatures
       Post #: 7
RE: Revo 2.5R NOT SHIFTING - 2/19/2008 11:01 PM
superman11
Score: 100
Status: offline
SOmetimes it stalls out but most of the time it will run and idle fine
Hide Signatures
       Post #: 8
RE: Revo 2.5R NOT SHIFTING - 2/20/2008 12:00 AM
RCCanuck
Score: 100
Status: offline
ok try shifting into reverse with the truck on but not running......if it shifts and it is in reverse when you start it then its your idle being too high that is not letting it go into reverse
Hide Signatures
       Post #: 9
RE: Revo 2.5R NOT SHIFTING - 2/20/2008 1:36 AM
superman11
Score: 100
Status: offline
It wont shift at all, when the car is on or off!
I have no idea what is going on, is the servo dead?
Hide Signatures
       Post #: 10
RE: Revo 2.5R NOT SHIFTING - 2/20/2008 2:26 AM
RCCanuck
Score: 100
Status: offline
check the plug going into the reciever it may have come loose...can you manually shift it with your fingers?
Hide Signatures
       Post #: 11
RE: Revo 2.5R NOT SHIFTING - 2/20/2008 5:50 AM
Soppy
Score: 100
Last Login: 4/25/2011
Status: offline
Ok, it is actually my truck. My brother posted for me since I was busy. It probably has something to do with the servo or Opti-Drive rather than not getting enough revs, etc. because I have gotten it to top speed and kept it there for a few seconds without it shifting... The plug is fine and I can't shift it manually. I have to push really really hard which I don't want to do because I don't want to break the servo. I haven't actually shifted it by hand but I assume with enough force it would go.
Hide Signatures
       Post #: 12
RE: Revo 2.5R NOT SHIFTING - 2/20/2008 12:17 PM
revo-nation
Score: 100
Last Login: 12/4/2009
Status: offline
set the gearbox transmission shift screw to shift a little sooner for second gear if you swear your not running too rich.
reset the optidrive sensor. It takes like 5 seconds. if nothing then check your tq3 servo switch numbers at the bottom of the remote and check the manual for factory settings. if that doesnt work try taking the servo out and making sure it isn't seized. if nothing still then you might have a toased receiver plug.
if you didnt bust then u didnt bash-3.3 revo 90% alum hitec tm523 dx3-3.3 revo sirio .23 futaba dx3-3.3 revo tekno mod dx3
Hide Signatures
(in reply to Soppy)
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.559RCU1
