kahloq
CO, USA Status: offline
I've had the H9 Spitfire, Corsair, and Hellcat. The rotating mechanicals on the Corsair and hellcat are not bad at all if landing on pavment. Ove time, yes, they might need to be adjusted. On grass, well, they can get torqued and break a ball link pretty easily. Although, even if that does happen, they only cost $27 for an entire replacement set. A set of rotating pneumatic air retracts will cost $270+. I also am using the straight type non rotating Hangar Spitfire retracts on a Kyosho ME-109 and another set of the H9 Corsair rotating ones on a Kyosho Corsair. So far, no problems with breaking. For flying charactieristics, the Spitfire is great, especially since it does have flaps. However, the P47 and the Hellcat seem slightly easier to fly/land as they will float more then the Spitfire since the Spit will generally come out weighing a little more. The Spitfire looks a lot better then the Hellcat or P-47 though. The corsair flies great, but takeoffs can be a little hard to get used to as it has a shorter wheel base between the mains and the tail wheel then any of the other ones except maybe the Hellcat when built stock. The shorter wheel base can make the plane more prone to ground looping. I didnt have much trouble after the 1st or 2nd attempt...so its not near as bad as it might sound. The P-51 is a great flyer. Seems to take off well, but must be flown a little faster on landing then some of the other ones. I havent flown the P-40, so i dont know how it flies.
