Ziroli P-40
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Ziroli P-40
Page: [1]
Login
Ziroli P-40 - 3/7/2002 8:27:35 AM
SECRET AGENT
Status: online
Has anyone built the Ziroli P-40 with the fiberglass fuelage? I was thinking of going that route but wanted to hear any comments good or bad. What engine fits the best both in power and cowl concealment? I have heard some favorable reports but wanted to get specifics. Thanks.
       Post #: 1
Ziroli P-40 - 3/7/2002 12:08:42 PM
mselby
Status: offline
I built one with the fiberglass fuse. I used a 3W70 engine which required modification of the firewall position. build was very easy, the plane has no bad habits, it flies much like a low wing trainer. I used a torque rod for the elevators to conceal the linkage.
Mike
(in reply to SECRET AGENT)
       Post #: 2
p-40 - 3/8/2002 5:50:20 PM
warbird_1
Status: offline
i built the wood version and mselby is right , they fly great . i don't see why the glass version wouldn't. can anyone double check the length on the ziroli p-40? the specs show it as 77" . sounds short to me . i have to watch the lenghts as i have a short box truck . thanks , ron p.s. mine flew scale on a q-50 but i wish i had a g-62
Click to see fullsize image.
Click for fullsize
       Post #: 3
Ziroli P-40 - 3/9/2002 1:13:00 AM
SECRET AGENT
Status: online
How do you transport the wings, are they one piece or do they break down for transport. 94" yikes, I'll need a bigger trailer.
Is the wing a bear to build with all those different tapers?
Is the G-62 the weapon of choice for this bird? Does it completely cowl? Is there a better choice as far as carb location, exhaust etc..?? I really appreciate the help from you warbird guys.
       Post #: 4
Ziroli P-40 - 3/9/2002 1:16:28 AM
warbird_1
Status: offline
G-62 WOULD WORK GOOD IN HER. IT IS A ONE PEICE WING. YOU SHOULD BE ABLE TO HIDE THE WHOLE ENGINE IN HER . IT'S GOT A HUGE COWEL.
       Post #: 5
Ziroli P-40 - 3/9/2002 2:22:55 AM
INJUN_EAR
Status: offline
You must cut a hole in the cheek of the cowl to accomodate the G62 carb in the stock engine configuration.
Horizon has an adapter that'll reduce the distance between engine and carb so it may fit without cutting a hole.
       Post #: 6
P-40 - 4/25/2002 10:59:19 PM
HAROLD
Status: offline
DOES THE CARB HAVE TO PRETRUDE OUT THE COWL FOR THE ENGINE TO RUN RIGHT.I SEE ALOT OF PLANES WITH A VELOCITY STACK OUT THE COWL OR JUST BELOW THE SURFACE.I THINK THE ENGINE WOULD RUN BETTER.PLEASE ADVICE.THANKS,HAROLD
       Post #: 7
Z P-40 - 4/25/2002 11:52:25 PM
AirRayInc
Status: offline
Now youre talking.....
Here is my die hard Warhawk, which I let go to aquire my P-38.
This plane is a total blast to fly, hands off is absolutely straight and true once you get it airborne. Take offs are as tough as your powerplant. G-62s are not so hard to get aloft, with minor right rudder inputs plenty of rudder authority.....of course yours truly had to go whole hog and drop in a Brisson 5.8, because the 4.2 that was initially installed just wasnt giving me the wow factor that I like in my warbirds. This now requires that I STAND on the rudder. If I so much as let light on the rudder, p-factor is gonna send it into a military efficient LEFT-FACE-MARCH. But once the speed gets up (I literally gun it and go) then you can start to relax a bit. Do not gradually bring up the power with an engine this size, with each new power point, p-factor changes, as does your rudder input requirement, and you chase the bad boy all the down the ramp, looking like a rookie the whole way. Granted, it aint flying no where near scale at full throttle, but I dont compete on fun flying days. When I do I change props to something bigger and with alot less pitch.
You can get most of either the exhaust or the carb concealed, both is a challenge, and with the 5.8 it aint gonna happen. If you look closely at the picture, Brison used to make a really cool blank, that I had a pipe welded to the end of, ran some copper tubes and elbows, then exited the hot stuff through the cowl flap openings.
A very easy plane to land as well, with acres of wing area. I ran a single glass rod to the elevator, also keeping it all inside, and a Hightec 700 series on the first, the a 705 metal gear on my current one.
Ray
Click for fullsize
< Message edited by AirRayInc.Com -- Apr 25 2002 7:07PM >
_____________________________
My Blog
http://www.rcgroups.com/forums/member.php?u=9311
http://airrayinc.com
       Post #: 8
Ziroli P-40 - 4/25/2002 11:59:28 PM
AirRayInc
Status: offline
I got so excited that I didnt pay attention to some of the questions.
Harold, the carb does not have to stick out of the cowl. My carb did not on the 4.2, the 5.8 of the old one, nor the 5.8 of my current one either.
Transport the wing, get a surf board rack for your car. Or let hang out the back of your 8 foot bed truck, like me.
Engines are a matter of tastes, you can do some really "scale" flights with an engine as small as a g62. I wouldnt personally go any smaller than a 4.2 electronic ignition. I used be bummed as how long it took to get off the ground, (ok so the original weighed close to 51lbs, thats beside the point) but once the 5.8 went in, it was hang on mommma. I now dont buy warbirds unless I can cram one of these beauties in it.
Talk Brisson into making that Blank exhaust again, its a gem. Very low profile and undrilled so that you can do whatever you want to with it, clean and rugged.... hello Brison, you listening...I will take two.
Ray
Click for fullsize
My Blog
       Post #: 9
Ziroli P-40 - 4/26/2002 1:21:39 AM
k_sonn
Status: offline
I just purchased a G62 and they are now coming with the short carb manifold and a straight shot throttle lever arm. I had also purchased the shorter carb manifold but sent it back because it was not needed.
       Post #: 10
Ziroli P-40 - 4/26/2002 5:11:31 AM
INJUN_EAR
Status: offline
[QUOTE]Originally posted by AirRayInc.Com
Ray
[/QUOTE]
Holy moley Ray, 51 #????? Mine weighed 21 lbs with a G62......
Where the heck did all that weight come from?
       Post #: 11
Ziroli P-40 - 4/26/2002 8:08:10 AM
AirRayInc
Status: offline
Hey Injun, before I actually took ownership of the plane, it was owned by Vic, Mr Fw190, way back when. An intermittant elevator had it pancaked on its maiden flight. I bought it, got a new fuse, and began to build it as if it were one of my slope gliders, with no regard for weight what so ever. I sanded the wings, but instead of going all the way to the wood, I went to the glass cloth, and then glassed again with 4oz weight. Yeah yeah I know. Then I went and added a tail wheel retract, and paint it so thick, that you could have troweled the stuff on. That brought the plane to 43lbs. Then one day out at mail square park (RIP) I got a radio hit while flying over some rc cars, and put the thing into a tree at at golf course. Thank god for the tree. Another major repair of the wing, and yet another fuse later, and now I am up to 50 plus pounds. The cool thing is that the plane was balanced right on the cg, and even at that weight, once you got up, and on step, it was easy to handle. Never mushed in the corners, slowed down well for approaches, and with about 20 degrees of flaps, it still was able to slow down enough to handle a short field landing. Yeup, its a winner, I will always have one in my stable, heck I would even buy back the original, if I knew where it was, just for sentimental reasons, and I dont get sentimental. Unles you are talking Bearcats and Lightenings.
Ray
My Blog
       Post #: 12
don't forget about the wing walk - 4/26/2002 10:24:15 AM
fw190
Status: offline
I mean the car tire wing walk.... eeeeeek! that really added more weight, about 2,000 lbs devide by 4 ( could only get one wheel on the wing)
The spec when I original built it was at 33lbs with a Sachs 4.2. Learned a lesson from a single elevator servo. I cut the foam wing. Foam wings build a little heavier than built up, but it is a lot stronger. When the elevator failed, the fuse was totalled but the wing was in perfect condition. If you want cores, balsa dynamics now cary a set.
Glass fuse and foam cores is a good combo, and seeing Ray burn up the sky with his on a Brisson 5.8 takes the cake.
fw190
www.VicRC.com
       Post #: 13
Ziroli P-40 - 4/26/2002 5:40:27 PM
INJUN_EAR
Status: offline
I know about the foam wing cores, I'm using a set on my "NEW" P40 which is to replace my "OLD" P40 that had a wing failure in flight!
Only the stab and rudder survived the crash....... Mine had a G62 in it and seemed to have more than enough power but I was wondering if maybe a Sachs 4.2 would fit without having to mangle the cowl up???? Anyone know?
Click for fullsize
       Post #: 14
Ziroli P-40 - 4/26/2002 7:30:12 PM
AirRayInc
