Thunder Tiger TS-4N upgrade
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> Thunder Tiger TS-4N upgrade
Page: [1] 2   next >   >>
Login
Thunder Tiger TS-4N upgrade - 2/18/2008 10:04:51 PM
matty2583
Status: offline
Hi All
I have a thunder tiger TS-4N with a pro 15 engine. i was wondering if it was possible to convert it from a single speed gear to a two speed gear? if yes then what do i need? is their any websites that stock the parts?
please reply
many thanks
matty
       Post #: 1
RE: Thunder Tiger TS-4N upgrade - 2/18/2008 10:55:17 PM
mrbonk
Status: offline
The TS-4N that I just got yesterday came with a 2-speed as standard equipment, but I see it's listed as an 'optional' part in the manual. Just looking at the 'close ratio' optional 2-speed in the hop-ups list, it looks like you need the spur gears and hubs, the clutch bell and pinions, 2 shafts, the clutch hub thing and various screws/washers. Might be cheaper to just buy the complete optional one. The part number listed in my manual for it is 'PD7675 2-speed, close ratio trans'.
I've found a load of TT parts at www.thundertiger4u.com
_____________________________
MrBonk
http://www.mrbonk.com
(in reply to matty2583)
       Post #: 2
RE: Thunder Tiger TS-4N upgrade - 2/18/2008 11:34:15 PM
snowbl!nd
Status: offline
Here is the complete two-speed conversion from Modelsport in the UK.
RC obsession. The quest to discover just how deep those pockets really are...
Life is short - Drive fast.
(in reply to mrbonk)
       Post #: 3
RE: Thunder Tiger TS-4N upgrade - 2/18/2008 11:36:11 PM
matty2583
Status: offline
thanks
i was wondering if anybody knows if it is dificult to install?
(in reply to snowbl!nd)
       Post #: 4
RE: Thunder Tiger TS-4N upgrade - 2/18/2008 11:39:35 PM
snowbl!nd
Status: offline
Not especially - i think the 2-speed assembly comes with instructions anyway
       Post #: 5
RE: Thunder Tiger TS-4N upgrade - 2/18/2008 11:43:20 PM
matty2583
Status: offline
thanks
one more thing....would you say that it is worth buying? does it improve it a lot or is their not much difference?
sorry for all the silly questions, im queriouse of these things
       Post #: 6
RE: Thunder Tiger TS-4N upgrade - 2/18/2008 11:46:10 PM
snowbl!nd
Status: offline
I'd say so, if only for the wow factor of hearing it shift gears. It'll boost the acceleration a fair bit as well.
       Post #: 7
RE: Thunder Tiger TS-4N upgrade - 2/18/2008 11:48:09 PM
mrbonk
Status: offline
If you set it correctly, it will allow you to have a lot more punch out of the corners and a better top speed on the straights. Because the shift point is adjustable, you can 'tune' it to your specific track, so you don't get it changing up half way through a corner etc.
MrBonk
       Post #: 8
RE: Thunder Tiger TS-4N upgrade - 2/18/2008 11:54:12 PM
matty2583
Status: offline
thanks for that
i think i'll decide to buy it when i get a bit more cash
what other upgrades could i get that would speed up my car?
do you know any other websites for thunder tiger products other than the ones you's have allready listed? i've found it hard to find products so far!
thanks both
       Post #: 9
RE: Thunder Tiger TS-4N upgrade - 2/19/2008 12:36:09 AM
mrbonk
Status: offline
Those are the only websites I've seen so far, but I must admit I didn't do a lot of looking after I found that US based one.
MrBonk
       Post #: 10
RE: Thunder Tiger TS-4N upgrade - 2/20/2008 8:50:55 PM
matty2583
Status: offline
hi,
it might sound sily but how do you know if your cluth shoes need replaceing? is it obviouse?
many thanks for you help guys, the other day
       Post #: 11
RE: Thunder Tiger TS-4N upgrade - 2/20/2008 10:12:28 PM
mrbonk
Status: offline
As your clutch shoes wear, it will need higher and higher revs to get the car moving. If you break a shoe or something else in the clutch, chances are it will lock against the bell and then it won't free-wheel like it should when the engine is idling or stopped.
MrBonk
       Post #: 12
RE: Thunder Tiger TS-4N upgrade - 2/20/2008 10:15:30 PM
matty2583
Status: offline
oh thanks for that, i was curiouse
i dont think they need replaceing yet
thanks
       Post #: 13
RE: Thunder Tiger TS-4N upgrade - 2/24/2008 11:43:29 AM
matty2583
Status: offline
hi
i was wondering if anybody could recomend a glow plug for my ts4n?
by upgading the glow plug to a decent one, would it help start my car easier?
thanks
       Post #: 14
RE: Thunder Tiger TS-4N upgrade - 2/24/2008 2:10:58 PM
snowbl!nd
Status: offline
What fuel are you running? Anything below 16% nitro i'd reccomend OS LC3s, above 16% then an OS 8 would probably run better.
Trouble getting the engine to start is usually down to tuning, although a damaged plug wouldn't help.
       Post #: 15
RE: Thunder Tiger TS-4N upgrade - 2/24/2008 6:54:59 PM
matty2583
Status: offline
im running it on 16% so i shall look for a OS 8.
it was workin fine but my pull start snaped and i replased it with a tiger drive electric starter tiger drive electric starter (different serial number to mine by one number)
this was recomended by my model shop as he cross referenced it.
it was still working with that for a few days but then my spur gear had to be replaced and after waiting a week for my replacement to come, my car wasnt started. i fitted the new spur gear and since then it has started taking a wile for it to fire up. i havnt changed a thing on the engine its self (ie. idler needle and the others)
i was wondering if it could have been with it not being started for a week and adding to that being left in the garage with no warmth
thanks
matty
       Post #: 16
RE: Thunder Tiger TS-4N upgrade - 2/29/2008 7:24:58 PM
matty2583
Status: offline
hey
it might sound daft but i was wondering, does it matter what percentage the nitro fuel is tht you use?
matty
(has anybody got anything to comment on my last post i made above?)
       Post #: 17
