RE: Thunder Tiger TS-4N upgrade
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: Thunder Tiger TS-4N upgrade
Page: <<   < prev  1 [2]
Login
RE: Thunder Tiger TS-4N upgrade - 5/10/2008 3:42:12 PM
max912
Status: offline
hi there i have a thunder tiger ts-n4 and i am upgrading it. I got some front knuckles but can not fit them is there any other parts i need as the drive shaft bits will not rotate. thanks chris
(in reply to matty2583)
       Post #: 26
RE: Thunder Tiger TS-4N upgrade - 5/10/2008 5:07:02 PM
snowbl!nd
Status: offline
The aluminium knuckles have a slightly narrower internal diameter and as a result the driveshafts rub (great design ). You can either grind away some material from the edge of the driveshafts, or buy the CVD kit.
_____________________________
RC obsession. The quest to discover just how deep those pockets really are...
Life is short - Drive fast.
(in reply to max912)
       Post #: 27
RE: Thunder Tiger TS-4N upgrade - 5/10/2008 6:52:59 PM
max912
Status: offline
ok mate thanks were would i get the cvd kit from.Also i wont a middle belt tightner dose any one no were to get them.thanks
(in reply to snowbl!nd)
       Post #: 28
RE: Thunder Tiger TS-4N upgrade - 5/10/2008 9:55:10 PM
snowbl!nd
Status: offline
I got mine from modelsport but they're out of stock of the front universals and seem to have discontinued the rears. Try giving them a call and asking if they could get some in stock for you, their customer service is usually quite good. Part numbers are PD1325 (fronts) and PD1326 (rears).
No need for a centre belt tensioner, the front bulkhead has one built in which moves the diff slightly forwards and backwards to adjust the tension of the belt. Adjusting it will be listed in the manual.
< Message edited by snowbl!nd -- 5/10/2008 10:14:27 PM >
       Post #: 29
RE: Thunder Tiger TS-4N upgrade - 5/11/2008 7:22:41 PM
matty2583
Status: offline
hi sorry for late reply, my net got cut off
the actual rotor start is 2.5cm and i think it is .5cm bigger than the original (i dont have the origanal as i threw it away so that is why i think)
hope this helps
please reply
many thanks
matty
(in reply to mrbonk)
       Post #: 30
RE: Thunder Tiger TS-4N upgrade - 5/19/2008 7:18:33 PM
matty2583
Status: offline
does anybody have any ideas? i really need a new one as it has droped to peices
please help
matty
       Post #: 31
RE: Thunder Tiger TS-4N upgrade - 6/7/2008 12:11:48 PM
matty2583
Status: offline
the actual rotor start is 2.5cm and it is half a cm bigger than the original. somebody please help me! i am desperatly in need of a new 1
please reply
many thanks
matty
       Post #: 32
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
