Landing Gear on the Fusion
Tower Hobbies
Logged in as Guest
  Printable Version
Ohio Model Products Fusion X3D - 90
Seller:  cdp2buck
Details:   $525.00   |  10/7/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> Landing Gear on the Fusion
Page: [1]
Login
Landing Gear on the Fusion - 2/18/2008 10:14:46 PM
skukreja
Status: offline
Hey guys.. thinking of picking up a fusion and was wondering about the landing gear. .On my Katana, I installed tetherite gear as the factory gear flexed and bent.. How is the factory gear on the fusion? Is the base wide enough to drill another hole for wheel pants?
Sachin
       Post #: 1
RE: Landing Gear on the Fusion - 2/18/2008 10:59:10 PM
wind junkie
Status: offline
You're asking about the Fusion 90, right?
A friend used the glass tetherite gear and it was too flexy. He needed to brace it with a wire.
I use the Jeff Williams gear on mine and it works great. I have 2 sets -- one with pants for the "muddy season." I don't intall pants the way you describe. Instead I use Sullivan mounts which allow the pants to twist if I bump them:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFV63&P=7
Dubro makes a similar setup that is easier to install and works like a wheel collar, but it's heavier and mounts outside the pant. The Sullivan one is easily glassed to the inside.
Not sure if these are the same set I have:
http://www.williamsrc.com/accessories.html
Jeff may have changed the mold, or offer a different set now, but the ones listed say they're good for a 5.5 lb plane. My fusion weighs 7lbs 4 oz.
_____________________________
Arguing with an engineer is like wrestling a pig. Everyone gets dirty and the pig likes it.
(in reply to skukreja)
       Post #: 2
RE: Landing Gear on the Fusion - 2/18/2008 11:52:40 PM
skukreja
Status: offline
oops.. meant to add the 52 sized fusion.. Thanks!
(in reply to wind junkie)
       Post #: 3
RE: Landing Gear on the Fusion - 2/19/2008 1:11:46 PM
AFSalmon
Status: offline
You want the small or 40 sized Tetherite gear for the 52"Fusion. What I tell folks is fly the plane with the stock gear and if you wear it out by landing hard and bending it a lot then you can replace it with the tetherite.
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
