FlyCamOne2 cold temperature solution
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Aerial Photography and Video >> FlyCamOne2 cold temperature solution
Page: [1]
Login
FlyCamOne2 cold temperature solution - 2/18/2008 10:25:31 PM
barryp
Status: offline
Here is a solution to cold temperature problems with the FlyCamOne2. Use the Rx batteries (glow-gas power) or power from your ESC-BEC (electric power) to power the FlyCamOne2. A simple tap made from two servo extensions will bring power to the FlyCamOne2 base. See the wiring diagram and photos. Pay close attention the the polarity reversal mentioned in the attached wiring diagram. Unplug the tap from the camera when not in use to avoid possible electrical leakage to the Rx circuit.
I've had 15 minute in flight videos at temperatures of -2C (28F)
http://www.youtube.com/watch?v=e-UALENHBOI
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: FlyCamOne2 cold temperature solution - 2/18/2008 11:25:59 PM
SON OF PALEFACE
Status: offline
Nothing like some 'grass' in your 'glass'
_____________________________
We must have had a BIG earthquake...the ground rose up and HIT my plane , Honest.
(in reply to barryp)
       Post #: 2
RE: FlyCamOne2 cold temperature solution - 2/23/2008 6:29:32 PM
TruBlu02
Status: offline
Great Idea! Quick question though. In your wiring diagram why is the harness you made going to the throttle channel? Can't you just tap into the battery lead going to your switch?
(in reply to SON OF PALEFACE)
       Post #: 3
RE: FlyCamOne2 cold temperature solution - 2/23/2008 7:05:37 PM
barryp
Status: offline
Yes, TruBlu02 that would be correct for a glow/gas powered aircraft. Thank you for catching this.
The wiring set-up I initially described was for an electric powered system where the power connection from the BEC must also carry the throttle signal from the Rx back to the ESC.
I am uploading a revised instruction diagram to the original post
Thanks again for your careful read of the posting
Barry
(in reply to TruBlu02)
       Post #: 4
RE: FlyCamOne2 cold temperature solution - 2/24/2008 5:39:18 AM
TruBlu02
Status: offline
Thanks for clearing that up Barry! I just got a Flycamone2 formy birthday from my wife so I am still in the learning prcess with it. What else can that adapter port be used for?
       Post #: 5
RE: FlyCamOne2 cold temperature solution - 2/25/2008 12:14:32 PM
barryp
Status: offline
Hi TruBlu02,
I don't know much more about the mounting base and it's connective functions beyond the information in the manual. In addition to power for the camera, it provides a channel for the recording on-off function. According to the manual, connecting pins 1 and 3 will activate recording or take a single still picture. Breaking the connection will stop the recording. I assume one would do this with an aux channel. There is a firmware update (issued January 20, 2008) that should be installed if you want to use the remote activation features. See the FlyCamOne2 web site for more information about that.
http://www.flycamone2.com/
Happy flying!
       Post #: 6
RE: FlyCamOne2 cold temperature solution - 2/25/2008 6:49:46 PM
TruBlu02
Status: offline
Thanks Barry. I really think the Flycam could come with a better manual but I am definately going to download the update. I have been wanting a way to remotely activate the camera and I have a spare retract channel that needs a purpose in life! I made my first video yesterday with my Reactor and I will post it up later in this forum.
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU1
