Will the 977 work for parallel setup?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> MRC Charger Product Support (i.e. Super Brain, etc) >> Will the 977 work for parallel setup?
Page: [1]
Login
Will the 977 work for parallel setup? - 2/19/2008 3:01:19 AM
philipat
Status: online
I'm planning to install two 7.2V 5000 mAh batteries (each is a 6 cell battery) into my RC and wire them in parallel, essentially giving myself a single 7.2V 10,000 mAh battery for very long run times. But before I do, I want to make sure that I get the right charger. I really like the Super Brain 977's ability to charge two batteries at a time (could do two sets at once), but I noticed that it's rated capacity is 8000 mAh batteries. Does that mean that I would need to step up to the 989 to charge this setup?
Thanks.
       Post #: 1
RE: Will the 977 work for parallel setup? - 2/19/2008 3:33:36 PM
Tim@MRC
Status: offline
Did you want to charge them individually as 5000 mah, or charge two sets in parallel as 2-10000 mah?
(in reply to philipat)
       Post #: 2
RE: Will the 977 work for parallel setup? - 2/19/2008 10:22:53 PM
philipat
Status: online
They would charge in parallel. Attached is a wiring diagram that someone else did with smaller (lower capacity) batteries, but that I plan to copy.
Click to see fullsize image.
Click for fullsize
(in reply to Tim@MRC)
       Post #: 3
RE: Will the 977 work for parallel setup? - 2/20/2008 10:54:29 PM
Tim@MRC
Status: offline
You're pretty much just showing me the arrangement of the batteries, right? Or is this the exact circuit you'll be using?
       Post #: 4
RE: Will the 977 work for parallel setup? - 2/21/2008 1:32:12 PM
philipat
Status: online
That's the circuit that I'll be using. The only thing it doesn't show is the wiring from the control board to the various components (motors and LEDs). The batteries will be laid physically next to each other...but, that's only a function of the available space. I do plan to follow the circuit diagram and join their positive and negative leads just like is shown in the diagram.
       Post #: 5
RE: Will the 977 work for parallel setup? - 2/25/2008 4:20:17 PM
Tim@MRC
Status: offline
Will the batteries be removed from the circuit in order to charge them? You can do it, it's just going to take along time to charge them.
       Post #: 6
RE: Will the 977 work for parallel setup? - 2/26/2008 2:23:18 AM
philipat
Status: online
No, the batteries will be left inside of the vehicle. They'll be charged in parallel via the single charge jack mounted to the vehicle. The idea is to be able to charge them without having to remove them from the vehicle.
       Post #: 7
RE: Will the 977 work for parallel setup? - 2/26/2008 2:44:47 PM
Tim@MRC
Status: offline
It should be alright then, just be careful not to overheat the batteries.
Tim
       Post #: 8
RE: Will the 977 work for parallel setup? - 2/26/2008 8:49:09 PM
philipat
Status: online
The two 5000 mAh batteries in parallel would like one 10,000 mAh battery, I think. The 977 charger literature says that it only supports 8000 mAh batteries. If it will work to charge the 10,000 battery, what does the rating mean? Does it have a timer that shuts down the charger after certain time? Would I have to restart the timer to get last 2000 mAh to "top off" the batteries?
I'm glad to hear that it will work. Just a little confused by what the rating means.
Thanks.
       Post #: 9
RE: Will the 977 work for parallel setup? - 2/26/2008 10:00:28 PM
Tim@MRC
Status: offline
You may have to hit it twice to get a full charge. Otherwise, the mah screen will roll over after 8000mah.
       Post #: 10
RE: Will the 977 work for parallel setup? - 2/27/2008 1:22:47 AM
philipat
Status: online
roll over?
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.607RCU1
