RE: TWIN FEVER !!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: TWIN FEVER !!! Page: <<   < prev  1 2 3 4 5 6 [7] 8 9 10   next >   >>
Login
RE: TWIN FEVER !!! - 4/29/2008 3:36:10 AM
combatpigg
Status: online
Uhhh, there will be an engine in each engine mount.
_____________________________
Led Zeppelin is NOT "old fogie" music.
(in reply to General Lee Stupid)
       Post #: 151
RE: TWIN FEVER !!! - 4/29/2008 12:51:54 PM
Yuu
Status: offline
KidEpoxy...while I was visiting Destin, Fla, I found stainless wire fishing leader material at Wally-World. They had three sizes, marked in 'pounds test' ... so take your micrometer along and get the thin one and measure it. I think the 30# is more than .020". Other fishing stores may also have it, like Bass prop shop, etc. Some guys use it for Musky leaders too. And what's the diameter of that stainless safety wire they use on real planes?
(in reply to combatpigg)
       Post #: 152
RE: TWIN FEVER !!! - 4/29/2008 1:21:39 PM
RocketRob
Status: offline
spyderwire?
(in reply to Yuu)
       Post #: 153
RE: TWIN FEVER !!! - 4/29/2008 1:52:40 PM
ptulmer
Status: offline
At the coastline it is pretty easy to find SS leader wire marked with the diameter. Might be a saltwater item. Basspro link
HomeMachinist.net!
Ulmer-RC.com
(in reply to RocketRob)
       Post #: 154
RE: TWIN FEVER !!! - 4/29/2008 8:13:35 PM
KidEpoxy
Status: offline
Thanks for the heads up un where I can get the wire.
But an un-named benefactor came forth & volunteered to grant me a few feet of the magic metal.
Now I gotta figure out how to mail him a ThankYou 6pack.
Oh, for a change of pace,
I built two left wings.
Which is odd, because I normally build two right wings .
Fortunately, they are truely symetric, so I just need to cut the build alignment tabs off the ribs & flip it over to make a left into a right. The wee bit of dihedral balanced out to make a flat after I flipped it over, and I can live with that no problem.
I figure if I can make a couple bones wing panels in a day, CP is probably on his 3rd coat of dope on his finished plane by now
Optional MA is part of AMA history, we can go optional AGAIN if we just say so
(in reply to ptulmer)
       Post #: 155
RE: TWIN FEVER !!! - 4/30/2008 1:14:18 AM
combatpigg
Status: online
KE, I just saw where you had questions about hot wiring .
Some thoughts:
Perfectly smooth and defect free templates
You need absolute accuracy in set up, garbage in really does equal garbage out with hot wiring
Maintain good tension, don't hurry the cut, don't use too much heat.
Don't be discouraged easily, just try to learn from mistakes and take corrective action.
Home Depot white foam is full of hard spots the will cause defects. Just try to blast through them if the wire gets stalled, then sand off high spots later.
Try to find a supplier of virgin foam.
Use a fan when you cut white foam, use a respirator if cutting those urethane foams
If your cuts leave fine wispy hairs on the surface, the heat was perfect, knock them off with a sanding sponge
Vacuum your foam after sanding
Use scraps of plywood to keep your foam stationary and to keep it still while doing your cuts.
A fine line marking pen is a must
Use a paper towel to wipe the wire after making a cut
Don't ever let the wire get red hot, adjust the heat till you hear or feel the 60 cycle humm, then test on scrap foam
(in reply to KidEpoxy)
       Post #: 156
RE: TWIN FEVER !!! - 5/1/2008 5:16:35 AM
combatpigg
Status: online
Here's what the Russian bomber looks like. This wing is just about done, there will be a HS 65 to directly drive each aileron. There was a little mishap handling the wing during construction, so you could say the model has already crashed and been repaired.
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 157
RE: TWIN FEVER !!! - 5/1/2008 9:17:20 AM
digital_trucker
Status: offline
I'm lucky to have a supplier of virgin foam right up the street, a company that actually makes the stuff from the raw beads...door cores and the like. Oddly, I've never used it...balsa just flies better.
I feel I can speak for 90% of humanity when I say 'durrrr'
Skype digital_trucker
       Post #: 158
RE: TWIN FEVER !!! - 5/1/2008 2:55:46 PM
KidEpoxy
Status: offline
Nice wing CP.
What is the final span & cords, and did you settle on a nice Nike-Y(shoe trace) foil or something more official?
I joined my 2 panels while still ribby to lay full span sheet, but got scared at just how small a 3" Tip makes a wing. 8" root to 3 tip dont leave much area, so I shelfed that set & started cutting a 5' with 11root 4tip.
If you are making your bird with not a lot of wing, maybe I could get away with it too. You said about 4' span earlier, and your IL4 has small tips too, so maybe I dont have to shelf the first wing.
Of course, in classic CP fashion, you are thinking twin Norvels where I am thinking of 7x3 on SureStarts for bomber-like flight rather than CP Bullet-like flight
(in reply to digital_trucker)
       Post #: 159
RE: TWIN FEVER !!! - 5/2/2008 12:40:55 AM
combatpigg
Status: online
KE, I would never waste my time with a real airfoil for a 40 mph 1/2A plane! Arguably, the best all around flying models for extreme speed and agility are AMA fast combat planes. Get a load of those airfoils....go to the river and look for a smooth rock that looks like it would be good for skipping across the river and there you go .
This wing is 11"x4.75"x 52".....I would not fret over 3 inch tips if you build the plane light enough. I looked at the plane you suggested and sneered at those pointed tips, but there is enough useful wing area there for a pair of .049s.
Even with a pair of .074s, the performance gain is with climbing ability, the speed is roughly 40 mph all day with 3 pitch props.
Press on with your project. You'll learn a lot from it and even if it isn't 100% of what your expectations are, there is no substitute for hands on experience.
Your idea for a 5 foot span plane sounds good if you stick build it and keep it light. I just decided on 4 feet for this one because I wanted to try something a little bit hot.
       Post #: 160
RE: TWIN FEVER !!! - 5/5/2008 6:28:49 AM
combatpigg
Status: online
Today was a good progress day, [didn't do anything real stupid] just forward progress.
The bulkheads are made from 1/16" balsa sheet glued cross grain with 3M77 The center keel is a piece of 3/16" "iron wood" balsa that I've been saving for a job like this. The stringers are 3/16 square balsa. The fuselage is glued to the wing to save some weight. What you see so far weighs 8.6 ozs.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by combatpigg -- 5/5/2008 6:48:03 AM >
       Post #: 161
RE: TWIN FEVER !!! - 5/5/2008 4:34:40 PM
KidEpoxy
Status: offline
CP,
You could probably mail the styro core slices to some electric guy as a "Foamie Kit".
I'm sure a lot of them would be aghast that you have already made a foam wing & fuse, just to be cut up... watch out for them rummaging thru your trash for a plane they just need to stack, glue, & put guts in
Looks good.
I was going to build a coffe table out of some of that IronWood Balsa I have, but I like your plan better. Actually, mine is 1/16 and gets used up as bulletproof wing centersheeting... anit no saddle gonna dig into that
Speaking of saddles:
I see you sharp-tapered down the front of your saddle stock past the leading former,
but let the tail end run to the next former. uh, why?
       Post #: 162
RE: TWIN FEVER !!! - 5/5/2008 5:10:51 PM
rainedave
Status: offline
Very cool subject, cp. It looks to have the right proportions and moments.
Here's an old Ziroli design that I've been mulling over for about two years. I think it could be easily scaled down, simplified and lightened up.
David
Click for fullsize
Click for fullsize
       Post #: 163
RE: TWIN FEVER !!! - 5/5/2008 8:38:27 PM
Andrew
Status: offline
CP
This is a first for me. I've seen lots of templates cut in order to shape foam wings and fuselages, but I've never seen foam wings and fuselages cut in order to shape templates. That's a pretty slick idea, especially if you don't have software to loft all the ribs and formers.
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
(in reply to rainedave)
       Post #: 164
RE: TWIN FEVER !!! - 5/5/2008 11:18:26 PM
