combatpigg
WA, USA Status: offline
Thanks for the reality check, Bruce. 3/4 oz would just either snap, crackle or pop. You sure don't want to land this thing nose heavy. I've got the option to make a fairly tough but light skin, then dig out all the foam.....this blue foam is heavy. After sizing up how to control this thing, it will get throttle, elevons and rudders. There will be 3 servos in each nacelle. It might be just as easy to do the nacelles with wood, and just use blue foam and glass to blend them into the surrounding area. The more I look at it, the more it looks like .061s will do the job, but the cut-off weight for .061s is going to be 32 ozs. That doesn't sound like much weight for a plane with 2 engines, 2 tanks, 6 servos, etc. I'm using throttle servos mainly just to have an engine kill, maybe that function can be accomplished with full down elevator instead? Time to go talk with some old C/L team race guys for shutoff ideas....
_____________________________
Led Zeppelin is NOT "old fogie" music.
