RE: Scratch Build - 29" Balsa Stepped Cat
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - Electric >> RE: Scratch Build - 29" Balsa Stepped Cat Page: <<   < prev  1 [2] 3 4 5 6 7   next >   >>
Login
RE: Scratch Build - 29" Balsa Stepped Cat - 3/4/2008 4:09:16 AM
SV27dayton
Status: offline
Minor update: I cleaned up all the holes in the stringers with a barrel sander on the dremmel and then glued all the existing stuff together. I used CA and then did the seams with regular wood glue. I'm going to try to skin in the tunnel tomorrow night.
_____________________________
Scott Custom Graphics (vinyl graphics for your boat)
I error so that others may learn.
(in reply to alloutcustom)
       Post #: 26
RE: Scratch Build - 29" Balsa Stepped Cat - 3/8/2008 2:04:39 AM
alloutcustom
Status: offline
sv27dayton-Did you widen the tunnel, looks like it from the plans, could just be the picture tho.
If the boat doesnt fly, dont buy!!! ; )
       Post #: 27
RE: Scratch Build - 29" Balsa Stepped Cat - 3/8/2008 2:29:57 AM
SV27dayton
Status: offline
I up sized the boat 1:1 (uniformly) and then I added a full inch to the width of the tunnel. I meant I was adding the wood layers. Going slow but I do have the first layer of wood (skin) in there.
       Post #: 28
RE: Scratch Build - 29" Balsa Stepped Cat - 3/8/2008 1:04:40 PM
alloutcustom
Status: offline
cool, keep up the good work
(in reply to SV27dayton)
       Post #: 29
RE: Scratch Build - 29" Balsa Stepped Cat - 3/11/2008 3:37:36 PM
alloutcustom
Status: offline
Im building one too, i modded it a bit and its a bit smaller, ill post a pic of the modded plans
Click to see fullsize image.
Click for fullsize
< Message edited by alloutcustom -- 3/11/2008 3:40:22 PM >
       Post #: 30
RE: Scratch Build - 29" Balsa Stepped Cat - 3/11/2008 9:08:03 PM
rcmaster123
Status: offline
those look nice
T-maxx, Tc3, Blade CP ,MINI-T
       Post #: 31
RE: Scratch Build - 29" Balsa Stepped Cat - 3/11/2008 9:23:22 PM
SV27dayton
Status: offline
Remarkably similar to mine. Intresteing. I'd start a second thread when you begin building. I'm not kicking you out of mine but it would be really confusing. I'll be following closely whatever you post.
(in reply to rcmaster123)
       Post #: 32
RE: Scratch Build - 29" Balsa Stepped Cat - 3/11/2008 9:50:10 PM
alloutcustom
Status: offline
Ok ya i will start a new thread. It is your hull, just modded, There arent any steps in mine(Easier) and it has a widened tunnel and i also changed the back end and added and "h" bulkhead so it wont be rounded.
< Message edited by alloutcustom -- 3/11/2008 9:55:15 PM >
       Post #: 33
RE: Scratch Build - 29" Balsa Stepped Cat - 3/12/2008 9:43:29 AM
SV27dayton
Status: offline
I saw that H. I'm probaby taking the rounded corners out of mine too but in a differnet way. DId you modify the drawings?
       Post #: 34
RE: Scratch Build - 29" Balsa Stepped Cat - 3/12/2008 8:02:16 PM
alloutcustom
Status: offline
Not too much. The main parts are the same except no steps. Would you like me to send you some? pm me your e-mail if so.
       Post #: 35
RE: Scratch Build - 29" Balsa Stepped Cat - 3/14/2008 9:36:29 PM
alloutcustom
Status: offline
hows the build going?
       Post #: 36
RE: Scratch Build - 29" Balsa Stepped Cat - 3/14/2008 9:41:36 PM
ryan_t888
Status: offline
I'm placing my order for photos.
Ryan
A theory may be so rich in descriptive possibilities that it can be made to fit any data. - P.J.L.
       Post #: 37
RE: Scratch Build - 29" Balsa Stepped Cat - 3/14/2008 10:49:04 PM
SV27dayton
Status: offline
Been real slow. Got the steps in the hull. Need to do more this weekend. then mabye it'll be worth a pic or two. Thanks for motivation.
(in reply to ryan_t888)
       Post #: 38
RE: Scratch Build - 29" Balsa Stepped Cat - 3/14/2008 11:43:34 PM
alloutcustom
Status: offline
yup no problem . Can you get some pics of how you did the steps, They looked hard to do so i took them out of my plans, however, i am going to build another (26in) one later and will use the steps, Itl be the little ones Big Bro
       Post #: 39
RE: Scratch Build - 29" Balsa Stepped Cat - 3/15/2008 4:38:53 PM
SV27dayton
Status: offline
Little one? How big is the first one going to be? Plans suggested 26". I'll take picutre of where I'm at now and if it goes well I'll post the before and after. I have no idea what I'm doing.
       Post #: 40
RE: Scratch Build - 29" Balsa Stepped Cat - 3/15/2008 4:44:35 PM
alloutcustom
Status: offline
Im building one that is 15 in. long. I have about half the balsa cu tout right now.
