RE: Scratch Build - 29" Balsa Stepped Cat
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - Electric >> RE: Scratch Build - 29" Balsa Stepped Cat
Page: <<   < prev  1 2 3 4 [5] 6 7   next >   >>
Login
RE: Scratch Build - 29" Balsa Stepped Cat - 5/4/2008 8:17:42 PM
detox
Status: offline
Spraying the thin CA will take your breath away literally, so spray it outdoors. After applying your thin fiberglass cloth with 3M spray tack adhesive spray on the CA using your paint sprayer much like paint (CLEAN GUN WITH ACETONE AFTERWARDS). The capillary action of the superglue with make boats surface very hard so make sure surface is smooth because it will be hard to sand afterwards. Fill, prime, sand, then paint.
< Message edited by detox -- 5/4/2008 8:19:24 PM >
(in reply to SV27dayton)
       Post #: 101
RE: Scratch Build - 29" Balsa Stepped Cat - 5/19/2008 1:20:15 AM
SV27dayton
Status: offline
An up date: Armor plating is complete. The boat is ready for water proofing and then hardware. The rudder is going to run deep, and I think she'll like that. Any one know a good place to pick up some steering rod and bellows? I need to do this right as I expect the bellows to be 1/2 submerged when the boat is idle. I have the servo and reciever and will order the motor soon, and the SC when I get back from china.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Scott Custom Graphics (vinyl graphics for your boat)
I error so that others may learn.
(in reply to detox)
       Post #: 102
RE: Scratch Build - 29" Balsa Stepped Cat - 5/20/2008 1:39:00 AM
SV27dayton
Status: offline
Stopped by the UPS store today with the hull. It's 476 grams (just over a pound). It will be intresting how much weight the urithane will add. Funny thing: It was breazy out when I went in there and the wind came close to twisting it out of my hand I'm not too upset with the weight. I have a feeling the SV will doing some recovery duty.
       Post #: 103
RE: Scratch Build - 29" Balsa Stepped Cat - 5/20/2008 2:03:10 AM
SV27dayton
Status: offline
How big of a difference would i see between other wise identical setups between an 8XL and a 9XL. Looks like a 200rpm/volt difference, what else can I expect? I can get the 9XL for about 20 bucks cheaper.
       Post #: 104
RE: Scratch Build - 29" Balsa Stepped Cat - 5/20/2008 1:11:30 PM
ryan_t888
Status: offline
Run the 9XL on 5s and that hull will sing! No more NiMh right?!?!
Ryan
A theory may be so rich in descriptive possibilities that it can be made to fit any data. - P.J.L.
       Post #: 105
RE: Scratch Build - 29" Balsa Stepped Cat - 5/20/2008 2:01:15 PM
SV27dayton
Status: offline
No probably not. I'm thinking of making the jump to Lithium with this boat. I may run it on 12 cells for some testing but Lipo is the future. Why do you ask? 9XL going to hurt the Nimh batts for some reason? Saw OC's old mean machine doing 55mph with a 12XL so I'm a bit scared as to what I'm going to end up with here.
(in reply to ryan_t888)
       Post #: 106
RE: Scratch Build - 29" Balsa Stepped Cat - 6/4/2008 2:02:33 AM
wlrottge
Status: offline
Ok, so I'm soooooo going to ask a noobie question.
I got a copy of the originals for this boat (the original shockerman plans). They're in PDF. I have access to a plotter at work... how did you get them to print full size?
       Post #: 107
RE: Scratch Build - 29" Balsa Stepped Cat - 6/4/2008 3:27:27 AM
dicko
Status: offline
Set your page size to A0 and send it to the plotter. It works for me with our plotter. If you forget to reset the page size it comes out A4 though.
The answer is always more power.
(in reply to wlrottge)
       Post #: 108
RE: Scratch Build - 29" Balsa Stepped Cat - 6/4/2008 3:49:05 AM
wlrottge
Status: offline
THANK YOU!!!!
(in reply to dicko)
       Post #: 109
RE: Scratch Build - 29" Balsa Stepped Cat - 6/4/2008 4:08:14 AM
SV27dayton
Status: offline
I have a plotter at work too. I took the 8.5 x 11 to kinkos and had them upsize it until I was happy. Cost me $0.80. Then I physically modded the cross beams with scisors and glue. I know I'm slow but I am working on it.
(in reply to dicko)
       Post #: 110
RE: Scratch Build - 29" Balsa Stepped Cat - 6/5/2008 6:17:47 PM
wlrottge
Status: offline
I started the build last night. This is my first 100% scratch build and I've already got a second build planned (1/10th crackerbox).
I'm learning a LOT very quickly a/b how and how not to cut balsa. Any tips?
I'd love to find a scratch builder tutorial/primer out there.... too many little nuances...
       Post #: 111
RE: Scratch Build - 29" Balsa Stepped Cat - 6/5/2008 7:25:09 PM
jdoug
Status: offline
I use a scroll saw for cutting all the wood I use for boats. Works perfect. A little tip on cutting out your parts...I always cut a little oversize and sand the rest. Then, if there is a matching peice, clamp together and sand until it is the same.
       Post #: 112
RE: Scratch Build - 29" Balsa Stepped Cat - 6/6/2008 1:41:21 AM
SV27dayton
Status: offline
I probaby didn't do it the easiest way. I printed the drawings to size. I taped all the parts down and used a needle to make a dotted line to show me where to cut. Removed the prints and cut everything with a modelers knife. Like Jdoug said, cut oversizded and sand. Balsa sands very quickly with 220. I glued the whole frame together and then sanded all the intersections until everything was even. Another tip is to sand the angle on the stringers especially up front. I used alot of CA. I bought an oz of great planes Medium (any thiner and it will run too much). Anyway I had to get more. I'd take your time and finish this one before you start the next. You'll learnd soo much on the first one and the second will be better as a result. Later
(in reply to jdoug)
       Post #: 113
RE: Scratch Build - 29" Balsa Stepped Cat - 6/10/2008 6:08:01 PM
wlrottge
Status: offline
Yeah, I did it the hard way as well. I glued them to my balsa then cut them out with a dremmel.
I have started the skinning and will post some pics soon.
I think (not sure) that I'm going to put glass or carbon on it instead of ply.... carbon would look coolest
       Post #: 114
RE: Scratch Build - 29" Balsa Stepped Cat - 6/11/2008 6:54:22 AM
SV27dayton
Status: offline
Wow that would look cool.
       Post #: 115
RE: Scratch Build - 29" Balsa Stepped Cat - 6/23/2008 12:51:28 PM
