EVERYTHING YOU WANT TO KNOW ABOUT ELECTRIC FLIGHT
Tower Hobbies
Logged in as Guest
Users viewing this topic: hawkman-RCU
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Training >> EVERYTHING YOU WANT TO KNOW ABOUT ELECTRIC FLIGHT
Page: [1] 2   next >   >>
Login
EVERYTHING YOU WANT TO KNOW ABOUT ELECTRIC FLIGHT - 2/19/2008 2:03:40 PM
aeajr
Status: offline
EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
An E-Book by Ed Anderson
PREFACE
A number of people have suggested I write a book on the topic of electric flight. I would, but I find the electric field is changing too fast. Paper based books go out of date too quickly. Instead I am going to create a thread that is my version of an e-book on the subject of electric powered flight. This e-format allows me to provide updates and to answer questions, things I can't do in paper form.
Whether you are a new flyer, a wet fuel pilot, or a glider pilot who wants to add an electric motor to your glider, I hope you find value here. Of course, I will fail to live up to the title as you can't know everything, but I will try to hit the essentials. I am also going to provide an index for your convenience.
The principals of weigt, lift, drag, stall and all the other things we know about flying apply the same regardless of what motor or engine the plane may have. The power systems may differ, and each has its unique benefits and quirks, but the principles of flight remain the same.
For new pilots who have no background, just relax, breath deeply and read. I have tried to put it all in one place for you. Don't expect to know it all in one reading. After you take your early flights, come back and read again as you will now have some real life experience to compare to what is contained here.
If you are starting with an RTF electric airplane, you really don't need to know all this stuff. However be sure to look at the articles on RTFs and the Six Keys to Success for New Pilots. I think you will find them helpful.
For wet fuel pilots coming into electric, the first problem is terms and their meanings. The first two articles are specifically focused on this need.
I want to change your question from "What is the electric equivalent of a .40 glow engine?” to "What electric power system would be right for a 40 size glow plane?" The first question is VERY hard to answer, the second is not. I am going to ask you to put aside what you know of wet fuel systems and look at electric power with a fresh mind.
Electric motor systems are both simpler and more complex than wet fuel systems. It is just a matter of looking at them in terms that make sense for electric power and not trying to make them fit the wet fuel framework.
What about batteries? How do I choose between NiCd, NiMh, Lipo, and others? We will cover that.
Battery chargers are a mystery too, yet they are an integral part of electric flight. We will cover those.
What about tools to tell what is going on in your electric power system? Yes, we will cover that also.
I will be adding new chapters and topics, so visit again, you might see a new topic that interests you. And don't hesitate to suggest topics that need to be covered.
I invite others who have experience in this area to add their knowledge and become co-authors of this e-book. If you have an area of expertise, share it with us. If you come across a good discussion or a reference source somewhere, post a link to it and tell us why you found it helpful.
You will find my articles and posts rich in links to other resources. Be sure to take a look.
If you have a question, by all means ask as others will have the same question.
I hope you find this helpful. I hope you will contribute your knowledge as well.
TABLE OF CONTENTS
Post# ..... Topic
1 ............Preface
2 ............Amps vs Volts vs C
3 ............Sizing Power Systems
4.............Props vs. Amps
5 ............What is an Electronic Speed Control?
6 ............The LVC, Low Voltage Cut-off
7 ............Who Needs a Wattmeter?
8 ............Why Use a Gearbox?
9 ............Extended Flight Times and Balance
10 ...........Battery Basics
11 ...........Lithium Batteries, Chargers and Balancers
12 ...........Six Keys to Success for New Pilots
13 ...........Things to Check on an RTF
14 ...........Now its Your Turn!
15 ...........The Role of the BEC in Your ESC
16 ...........The Mythical Best First Plane
17 ...........What You Need to Know About Receivers
18 & 19 ... Radio System Basics
20 ...........The AMA Park Pilot Program
26 ...........What Goes on Which Stick?
54 ...........What Do Motor KV Ratings Mean?
As the book progresses, I have expanded the range of the discussion beyond stricly electric topics but I have tried to stay within those topics that I feel are are relevent to electric flyers. For example the electric "parkflyer" class of planes has a large number of rudder/elevator/throttle planes. Sometimes people get confused as to were the rudder should reside on the radio. The article at post 26 addresses this question.
Looking back, I would have organized the chapters/articles in a different order, but I am not going to trash the thread to do it, so I hope you will not find it too confusing as it appers here.
< Message edited by aeajr -- 8/28/2008 1:32:09 PM >
_____________________________
Clear Skies and Safe Flying!
Ed Anderson
Moderator
Park Pilot Program Partner
       Post #: 1
RE: EVERYTHING YOU WANT TO KNOW ABOUT ELECTRIC FLIGHT - 2/19/2008 2:04:26 PM
aeajr
Status: offline
AMPS vs. VOLTS vs. C
By Ed Anderson
aeajr on the forums
This brief discussion is intended to clear up a few terms and concepts
around electricity as it applies to electric airplanes.
Think of electricity like water. Volts = pressure Amps = flow
Volts is like pounds per square inch, psi. Says nothing about how much
water is flowing, just how hard it is being pushed. You can have 100 psi
with zero water flow.
Amps is flow, like gallons per hour. You can have flow at low pressure and
you can have flow at high pressure.
Amp hours is how much flow can be sustained for how long. It is used as a
way of measuring how much electricity is in the battery. Like how many
gallons of gas in your tank. It is a capacity number. Says nothing about
flow or pressure, it is about capacity.
Amps and mili amps? We are just moving the decimal point around.
1 amp (short for ampere) = 1000 miliamps (mili means 1/1000 amps)
Examples
So a 7 cell NIMH or NICD pack provides 8.4V (pressure).
The motor will draw electricity from the pack at a certain flow rate, or
amps.
If you have a have a 650 mili amp hour pack, it can deliver a flow of .650
amps (650 miliamps) for one hour. If you draw it out faster, it
doesn't last as long. So your motor might pull 6.5 amps for 1/10 of an
hour, or about 6 minutes.
A 1100 mah pack has double the capacity of the 650 mah pack, so it should
last "about" twice as long.
What is C in relation to batteries?
C ratings are simply a way of talking about charge and discharge rates for
batteries.
1C, = 1 time the rated mah capacity of the battery. So if you charge your
650 mah pack at 1C, you charge it a 650 miliamps, or .650 amps.
1C on a 1100 pack would be 1.1 amps.
2 C on your 1100 pack would be 2.2 amps
Motor batteries are often rated in Discharge C and charge C.
So a 1100 mah pack (1.1 amp hour) might be rated for 10C discharge, so you
can pull 11 amps ( flow ) without damaging the battery.
Then it might be rated at 2C charge rate (flow), so you charge it at 2.2
amps (2200 mah)
How did I do? Things clearing up?
If you have a 500 mah pack - any kind - and it is rated at 16C that means it
can deliver 8 amps.
If you have a 1000 mah pack - any kind - and it is rated at 8C that means it
can deliver 8 amps.
If you have a 1000 mah pack - any kind - and it is rated at 12C that means
it can deliver 12 amps
If you have a 1500 mah pack - any kind - and it is rate at 8C that means it
can deliver 12 amps
If you have a 1500 mah pack - any kind - and it is rated at 20 C that means
it can deliver 30 amps.
If you have a 3000 mah pack - any kind - and it is rated at 10 C that means
So, if you need 12 amps you can use a pack with a higher C rating or a pack
with a higher mah rating to get to needed amp delivery level.
One last point. Motor batteries vs. receiver batteries
Some batteries can sustain high discharge rates. Others can not.
Those used as transmitter/receiver packs typically are made for low flow/amp
rates while those made for motor packs can sustain higher rates.
Having a 600 mah pack does not tell you if it is a motor pack that can put
out 6 amps, or if it is a transmitter/receiver pack that would be damaged if
you tried to pull power at 6 amps. It is enough to say that they are
different.
Clearly a motor pack could be used for a transmitter/receiver job, but a
transmitter/receiver pack should not generally be used as a motor pack.
It is best to size your battery packs so they run somewhat below their
maximum C rating. You will stress them less and they will last longer. For
example, if your motor needs a pack that can deliver 10 amps, getting a 1000
mah pack that is rated for 10C ( 10 amps ) will meet the spec, but it is
running at its limit. A 15 C rated 1000 mah pack would be better, or
perhaps a 1300 mah 10 C pack. In either of these cases, the pack will be
less stressed and should handle the load much better over the long term.
Other Resources
Basics:
http://www.modelaircraft.org/mag/FTGU/Part8/index.html
Lithium Batteries
http://www.rchobbies.org/lithium_battery_breakthrough.htm
Lithium Balancers and Balancing Chargers
http://www.rcgroups.com/forums/showthread.php?t=599287
New Electric Flyer FAQs
http://www.ezonemag.com/pages/faq/a105.shtml
A series of posts on electric power system basics
http://www.wattflyer.com/forums/showthread.php?t=1933
http://www.rcgroups.com/forums/showthread.php?t=417868
MotoCalc
MotoCalc will tell you everything you need to know: Amps, Volts, Watts, RPM,
Thrust, Rate of Climb, and much more! It is a popular tool for predicting
the proper motor, prop, battery pack for electric planes.
http://www.motocalc.com/
The Great Electric Motor Test
http://www.flyingmodels.org/motortest/index_e.htm
Electric Motors Described
http://adamone.rchomepage.com/guide5.htm
< Message edited by aeajr -- 2/19/2008 2:44:08 PM >
Ed Anderson
Moderator
(in reply to aeajr)
       Post #: 2
RE: EVERYTHING YOU WANT TO KNOW ABOUT ELECTRIC FLIGHT - 2/19/2008 2:05:34 PM
aeajr
Status: offline
SIZING POWER SYSTEMS FOR ELECTRIC AIRPLANES
by Ed Anderson
aeajr on the forums
Revised 9/8/07
This may get a little technical but I will try to keep it as simple as I
can. I will draw parallels to cars and bicycles in many places as most
people can relate to these and know at least a little about how they work.
I will use round numbers where I can and will use some high level examples.
If you are an engineer you will see that I am taking some liberties here for
the sake of simplicity. I will go through the parts of the power system,
then, toward the end, I will show you how we tie these all together to come
up with a complete power system.
POWER = WATTS
I will be using the terms Volts, Amps and Watts throughout this discussion.
Let me define them.
Volts = the pressure at which the electric energy is being delivered - like
pounds per square inch or PSI in a fuel system or water from a garden hose.
Volts is about pressure, it says nothing about flow. You will see volts
abbreviated as V.
Amps = the quantity or flow of electricity being delivered, like gallons per
minute in a fuel system or that same garden hose. Amps is about flow, it
says nothing about pressure. You will see amps abbreviated as A.
Watts = V X A. This is a measure of the energy or power being delivered.
This is how we measure the ability of that electricity to do work, in our
case the work of turning a propeller to move our airplane through the air.
Watts is about both pressure and flow. This serves the same purpose as
the horsepower rating of your car's engine. In fact 746 watts = 1
horsepower. So if you had an electric car, the strength of its motor could
be reported in either watts or horsepower. You will see watts abbreviated as
W.
If you want more depth on this, visit this thread.
MOTOR EFFICIENCY - Brushed vs. Brushless
Whether brushed or brushless, the motor's job is to convert electricity into
mechanical motion to turn the propeller to move air. Efficiency is how we
measure how much of the power, the watts, that our battery delivers to the
motor is actually turned into useful work and how much is wasted as heat.
A higher efficiency motor delivers more energy to the prop, and wastes
less.
A typical brushed motor, say a speed 400, is only about 40-50% efficient.
Only about half the watts delivered to the motor actually end up as useful
work turning the propeller. The rest is wasted. Motors that have a "speed"
designation, like speed 400, are brushed motors. There are other names for
brushed motors but the "speed" term is a common one. They are inexpensive
and they work. For example, you can buy a speed 400 motor and electronic
speed control, ESC, for $30. A comparable brushless motor/ESC combination
would
typically cost 2 to 4 times that much.
Brushless motors tend to be more efficient. They typically deliver 70-90%
of that input power to the propeller, Thus you get better performance per
watt with brushless motors. Seen a different way, if you use a brushless
motor, then, for the same flying performance you will use less energy which
means your battery will last longer. Or you can use a similar size and
weight brushless motor.battery combo to get comparable performance
because the motor turns more of the watts from the battery into useful work
of turning the propeller.
As with many decisions we make, this is a cost benefit decision. Am I
willing to pay more to get more? That is up to you.
THE BATTERY IS MORE THAN JUST THE FUEL TANK
Think of the battery as the fuel tank plus the fuel pump and a supercharger
all rolled into one. It feeds/pushes energy to the motor. So you have to
look at the battery and the motor as one unit when you are sizing power
systems for electric planes. In many cases we start with the battery when
we size our systems because the motor can't deliver the power to the prop if
the battery can't deliver the power to the motor.
The higher the voltage rating of the battery, the higher the pressure, like
a supercharger on a car engine. More pressure delivers more air/fuel
mixture to the engine which allows the engine to produce more power to turn
the wheels of the car.
Higher voltage pushes more electricity into the motor to produce more power,
IF AND ONLY IF, the battery has the ability to deliver more electricity.
Again using the car analogy, if you put a big motor in a car and put a tiny
fuel line and a weak fuel pump, the motor will never develop full power. In
fact the motor might starve and stall once you got past idle. Such is the
same with batteries. We need voltage, we need capacity, but we also need to
know how many amps the battery is capable of delivering at peak.
If we compare an 8 cell AAA battery pack to an 8 cell C battery pack we get
9.6 V for both packs. However the AAA pack may only be able to deliver 6
amps. After that the cells will heat up and either be damaged or the
voltage will start to drop fast. The C pack, also 9.6 V, might be able to
deliver 60 amps without damage. So we have to size not only by voltage, but
by the ability to deliver amps to the motor. Again, think of the fuel line
and the fuel pump as your image of what I am trying to explain. If the
motor needs 12 ounces per minute to run but the fuel line can only deliver
8, the engine will starve and die.
Using our electric motors, a given motor may take 10 amps ( the quantity of
electricity flowing ) at 8.4 volts ( the pressure at which the electricity
is being delivered) to spin a certain propeller. We would say that the
battery is delivering, or that the motor is drawing 84 watts, i.e.: 8.4V x
10A. If you bump up the voltage to 9.6 volts, the battery can ram in more
amps into the motor, more energy to the motor, which will produce more power
to the propeller. In this example, if we move from an 8.4V battery pack to a
9.6V battery pack the motor may now take 12 amps. This will typically spin
the motor faster with any given propeller or allow it to turn a larger
propeller at the same speed.
However, if you bump up the pressure too much, you can break something.
Putting a big supercharger on an engine that is not designed for it will
break parts of the engine. Too much voltage can over power your electric
motor and damage it. So there is a balance that has to be struck.
Different motors can take different amounts of power, watts, volts X amps,
without damage. For example, a speed 400 motor might be fine taking 10 amps
at 9.6 volts or 96 watts. However bump it up to 12 volts and ram 15 amps
down its throat and you will likely burn it out.
Our goal is a balanced power system. If you match the right battery with
the right motor, you get good performance without damage to the motor. In
many cases airplane designers will design planes around a specific
motor/battery combination so that they match the size and weight of the
plane to the power system for good
performance.
PROPELLERS
Propellers are sized by diameter and pitch.
The diameter of the propeller determines the volume of air the propeller
will move, producing thrust, or pushing force. Roughly speaking the
diameter of the propeller will have the biggest impact on the size and
weight of the plane that we can fly. Larger, heavier planes will typically
fly better with larger diameter propellers.
Pitch refers to the angle of the propeller blade and refers to the distance
the propeller would move forward if there were no slippage in the air. So a
7 inch pitch propeller would move forward 7 inches per rotation, if there
were no slippage in the air. If we combine pitch with the rotational speed
of the propeller we can calculate the pitch "speed" of the propeller. So,
at 10000 revolutions per minute, that prop would move forward
70,000 inches per minute. If we do the math, that comes out to a little
over 66 miles per hour.
By changing the diameter and the pitch of the propeller we can have a
similar effect to changing the gears in your car or a bicycle. It will be
harder for your motor to turn a 9X7 propeller than an 8X7 propeller. And
it would be harder to turn a 9X7 propeller than a 9X6 propeller. The
larger or steeper pitched propellers will require more energy, more watts,
more horsepower, to turn them. Therefore we need to balance the diameter
and pitch with the power or wattage of the motor/battery system.
Fortunately we don't actually have to do this as motor manufacturers will
often publish suggested
propellers to use with a given motor/battery combination. We can use these
as our starting point. If we want we can try different propellers that are
near these specifications to see how they work with our airplane.
GEARBOXES
While unusual on glow or gas planes, gearboxes are common on electric
planes. Their primary function is similar to the transmission on a car. The
greater the gear ratio, the higher the numerical value, the slower the
propeller will turn but the larger the propeller we can turn. So you can
use a gearbox to help provide more thrust so you can fly larger planes with
a given motor. However you will be turning the propeller slower so the
plane will not go as fast.
With direct drive, that is when the propeller is directly attached to the
motor shaft, we are running in high gear ( no gear reduction). Like pulling
your car away from the light in high gear. Assuming the motor doesn't stall,
acceleration will be slow, but over time you will hit a high top end!
Typically direct drive propellers on a given motor will have a smaller
diameter.
With the geared motor, it would be like pulling away from the green light in
first gear - tons of low end power and lots of acceleration, but your top
speed is reduced.
So, by matching up the right gear ratios made up of the propeller and,
optionally, a gearbox we can adjust the kind of performance we can get out
of a given battery/motor combination. How this is done is beyond the scope
of this article.
NOW WE CAN START TO MATCH UP THE PIECES!
The simplest approach I have seen to figuring power systems in electrics is
input watts per pound of "all up" airplane weight. The following guidelines
were developed before brushless motors were common but it seems to hold
pretty well so we will use it regardless of what kind of motor is being
used.
50 watts per pound = Casual/scale flying
75 watts per pound = Sport flying and sport aerobatics
100 watts per pound = aggressive aerobatics and perhaps mild 3D
150 watts per pound = all out performance.
Remember that Watts = Volts X Amps. This is a power measurement.
In case you were wondering, 746 watts equals 1 horsepower.
AN EXAMPLE!
This should be fun. Let's see where these formulas take us! We will use a
24 ounce, 1.5 pound plane as our example. If we want basic flight you will
need 50 watts per pound or about 75 watts input to your motor for this 1.5
pound plane. That is, 50 watts per pound X 1.5 pounds = 75 watts needed
for basic flying performance. If you want a little more spirited plane, we
could use 75 watts X 1.5 pounds which is about 112.5 watts.
Lets use 100 watts as the total target, just to be simple, shall we? I am
going to use a lot of round numbers here. I hope you can follow.
The Battery:
If we use an 8 cell NiMh battery pack at 9.6 V it will have to deliver 10.4
amps to hit our 100 watts input target ( 100/9.6 = 10.41amps) If my
battery pack cells are NiMh cells that are rated at 10C then I need an 8
cell pack rated at 1100 mah to be able to deliver 11 amps. Sounds about
right.
Now I select a motor that can handle 100 watts or about 10.4 amps at 9.6
Volts. From experience we know this could be a speed 400, a speed 480 or
some kind of a brushless motor.
We now need a propeller that will cause the motor to draw about 100 watts. I
don't know off the top of my head what that would be. I would go to some mfg
chart as a starting point. GWS has good charts!
http://www.gwsus.com/english/product/powersystem/edp400.htm
I see that if I use a direct drive speed 400 with a 5X4.3 prop at 9.6V then
the motor will draw about 12.4 amps or about 119 watts. This would be a
good candidate motor/prop for the plane using a 9.6V pack that can put out
12.4 or more amps. This would be a set-up for a fast plane as that motor
will spin that small prop very fast.
However maybe I don't want such a fast plane but one with a really good
climb and lots of low end pull to help out a new pilot who is in training or
to do more low speed aerobatics
I can also use a speed 400 with a 2.38 gearbox and run it at 9.6V spinning a
9X7 prop and run at about 12.8 amps for 120 watts.
http://www.gwsus.com/english/product/powersystem/eps400c.htm
The larger prop will give this plane a strong climb, but since the prop
speed has been reduced by 2.38 times, it won't be as fast. Spinning a
bigger prop gives me more thrust but a lower top speed typically. This is a
common strategy for 3D planes.
Back to battery packs and motors
So if I shop for a 9.6V pack to be able to handle about 15-20 amps, I should
do just fine and not over stress the batteries. In NiMh that would probably
be a 2/3 or 4/5 A pack of about 1000 -1300 mah capacity. Some examples here:
http://www.cheapbatterypacks.com/mai...ells&chem=NIMH
We view the battery and motor as a linked unit with a target power profile,
in this case about 100 watts. We use the prop and gearbox, if any, to
produce the manner in which we want to deliver that power to the air to
pull/push the plane.
If this is a pusher, I may not have clearance to spin that big prop so I
may have to go for the smaller but faster prop combo.
If this is a puller, then I can choose my prop by ground clearance or some
other criteria and match a gear box to it.
See, that was easy, right? ( well sorta but ....)
But we are not done! Oh no!
I could try to do it with a 2 cell lithium pack rated 7.4V. To get 100 watts
I now need a pack that can deliver 13.5 amps and a motor/prop combination
that will draw that much. So if I have 10 C rated lithiums, then the pack
better be at least 1350 mah. Probably use a 1500 mah pack to be safe.
Well, when I look at the chart for the geared speed 400 I see that,
regardless of prop, at 7.4V I am not going to have enough voltage (
pressure) to push 13 amps into this motor. So the 2 cell lithium won't meet
my performance goal of 100 watts+ per pound using this gear box.
If I go back to the charts and look at a different gear boxes. I can't hit my
power goals using 7.4V. Maybe we go back to direct drive.
http://www.gwsus.com/english/product...tem/edp400.htm
We see that the best I can get this speed 400 to do is a total of 70 watts
at 7.2V ( close enough ) so I can't hit my power goals using a speed 400 at
this voltage. but 70 watts would be about 48 watts per pound so I could have
a flyable plane, but not an aerobatic plane using this two cell pack.
REALITY CHECK!
Now, in fact that is NOT how I would do this. I would decide on the watt
target, go to the chart, find a combo that meets my goals, then select a
battery that will meet the demand and see if my weight comes up at the
target I set. A little tuning and I come up with a workable combo.
I often use the MaxxProd combos for reference. If you read the details on each
package they have wonderful information. And, the fact is that I generally go
with brushelss motors these days. Costs are reasonable and their higher
efficency
gives me more performance and longer flight times.
http://www.maxxprod.com/mpi/mpi-264.html
Following the example above, the combo 10 on that page would be an excellent
fit for my 1.5 pound plane for sport flying.
The Combo 049 might be a good fit for a slow flyer. Either way the package
has all I need.
If I wanted the plane to have all out performance, the 15A or 19A package would
be my pick. Note that these would need either higher voltage or higher amperage
battery packs. The flyers/PDF for the packages make recommendations.
For those who like to be even more analytical about it, there are packages
like MotoCalc that will allow me to play with all sorts of combinations and
make suggestions on what I should use. There is a link for MotoCalc below.
SUMMARY
So, in these few paragraphs you have taken in a basic knowledge of how electric
power systems are sized, the factors that are considered an how to predict
the outcome. Simple, right?
Of course there is a lot more to know and time and experience will teach
you plenty, but with this basic understanding you are better prepared to
begin playing with the power systems you put in your planes.
Here are some additional resources that may be helpful.
Good luck e-pilot!
Ed Anderson
Brushed Motors
http://www.hobby-lobby.com/elecmot.htm
Brushless Motors
http://www.hobby-lobby.com/brushless-motors.htm
Brushless outrunners explained
http://www.diynetwork.com/diy/rc_planes_aircraft/article/0,2033,DIY_14224_4320834_02,00.html
Battery Packs - NIMH
http://www.cheapbatterypacks.com/main.asp?pgid=packs&pid=AIR&sid=445976&ctype=
http://www.hobby-lobby.com/hydride.htm
Battery Packs - LiPo
http://www.cheapbatterypacks.com/main.asp?sid=445976&pgid=tp&sort=PL
http://www.hobby-lobby.com/lithium-polymer.htm
Gearboxes - Speed 400 & 480 examples
http://www.hobby-lobby.com/gear400.htm
http://www.hobby-lobby.com/gear480.htm
Maxx Products has a pretty good tip sheet on coming up
with a glow to electric power comparison. You can find it here:
http://www.maxxprod.com/mpi/tips3.html
This reader says Keith Shaw originated the watts per pound rule
http://www.rcgroups.com/forums/showpost.php?p=6156600&postcount=39
MotoCalc
This program will tell you everything you need to know: Amps, Volts, Watts, RPM,
This club has some interesting links on their home page that may be helpful
in planning props and power systems.
http://www.srcmc.co.uk/
Drive Calculator Version 2.21
Based around a Microsoft Excel spreadsheet This includes a propeller thrust
and power database, in a similar form to MotorXL, a motor database, and
tools for predicting home made motor performance. With these tools it is
possible to predict the performance of motor and prop combinations - even
with custom motors!
http://www.badcock.net/motorcalc/
Ed Anderson
Moderator
(in reply to aeajr)
       Post #: 3
RE: EVERYTHING YOU WANT TO KNOW ABOUT ELECTRIC FLIGHT - 2/19/2008 2:12:41 PM
aeajr
Status: offline
PROP vs. AMPS
Your electric motor draws a certain amount of energy to do its job, which is to turn the propeller. With no prop attached it draws very little energy. If you put a big prop on the motor it draws a lot of energy.
This is similar to pulling a boat trailer behind your car. The car might get 20 mpg normally, but put a boat on a trailer behind the car and mileage will drop off to perhaps 15 mpg because the motor is using more energy just to maintain the same speed and travel the same distance. However as long as the boat and trailer are not too heavy, no real damage occurs, you just use more gas.
If you put too big a trailer behind your car, something will break. The motor may fail, the transmission may fail or something else. That is because you are asking the drive train to produce more work, use more energy then it was built to handle. Fuel mileage goes way down and then something breaks. You have over stressed things.
Back to your plane.
Your electric motor needs to "draw" a certain amount of energy in order to turn a given propeller at a given speed. Let's use a speed 400 motor as an example and let's say you have a 6X5 prop on it. That means the propeller is 6" across and has a pitch of 5" per revolution. Pitch indicates how far the prop would move forward through the air if there was no slippage. As either of these numbers go up, the motor is asked to do more work.
Now let's apply some numbers. These are made up numbers for illustration only. Don't assume that these are accurate for your motor in your plane turning your prop.
Let's say that, to turn that 6X5 prop your speed 400 motor draws 6 amps of electricity using a battery that delivers 10 volts, just to make the math simple. That would be 60 watts of energy that the motor consumes to turn that prop. (6 amps X 10 Volts)
If we go to a larger prop, say 7 inches and keep the pitch the same 5 inches, the draw might go up to 8 amps at 10 volts or 80 watts.
Likewise if we went to a 7X6 prop, the draw would go up again, say to 9 amps or 90 watts.
In each case we are increasing the amount of work the motor has to do to turn the prop. The harder it works the more electricity it draws. This is also placing an increasing amount of stress on the motor causing it to generate heat and placing more pressure on the bearings. If we push it too far, the motor will be unable to turn the prop fast enough to be useful in flying the plane and/or it will fail from stress, just like the car example above with the trailer that is too big.
What we are try to do is to get the best balance of propeller and amp draw so that the motor operates efficiently without being over stressed.
Likewise if you have that same speed 400 motor and keep the prop at 6X5 but increase the electric pressure, volts, to 12 volts it will force more amps into the motor. This would be like putting a supercharger on your car's motor which forces more fuel/air mix into the car's engine. It will produce more power so it can do more work. However if we exceed the amount of power it was designed to handle, it will fail. It might not fail right away, but over a very short time it will start to degrade, perform badly and perhaps suddenly fail all together.
If we push the voltage up too high or the amp draw too high, we will over stress the motor and damage it.
The goal is get a good balance of propeller and power draw.
OTHER RESOURCES
A comparison of Glow vs. Electric power
MotoCalc
MotoCalc will tell you everything you need to know: Amps, Volts, Watts, RPM, Thrust, Rate of Climb, and much more! It is a popular tool for predicting the proper motor, prop, battery pack for electric planes.
< Message edited by aeajr -- 2/19/2008 2:45:42 PM >
Ed Anderson
Moderator
(in reply to aeajr)
       Post #: 4
RE: EVERYTHING YOU WANT TO KNOW ABOUT ELECTRIC FLIGHT - 2/19/2008 2:14:11 PM
aeajr
Status: offline
Understanding the Electronic Speed Control
By Ed Anderson
When we look at model airplanes that have electric motors as opposed to liquid fuels, the things we notice first are the quiet electric motor and the battery. However there is a component that sits between them called the electronic speed control that is really the master control point for all power in the plane. We are going to look at its make-up and how it does its job.
On the surface we can see that the electronic speed control, the ESC, takes over the function of the throttle servo that would operate the carburetor in a glow or gas powerd plane. Just as the throttle servo controls the speed of these wet fuel motors, the ESC controls the speed of the electric motor. But there is more to it than that.
The first thing that we want to recognize is that there are two different kinds of ESCs that are specific to the type of motor they control. There are brushed motors, such as the speed series or the Mabuchi motors, and then there are the brushless motors. Each type of motor needs a different electronic speed control.
Understanding the Wires
When you look at an electronic speed control, you notice that you have three sets of wires. Typically two sets of thick wires and one set that looks like a servo wire.
Two of the thick wires, typically black and red, connect to the battery. The ESC will usually be marked to tell you which are the battery wires. They would connect to the battery as red to red and black to black.
A second set of wires, typically thinner than the battery connection wires, has a plug on the end that looks like a servo plug. This will be connected to the receiver and will serve two purposes as it sends power to the receiver and gets signals from the receiver.
If we look at the wires on this plug they usually run from a dark or black wire on one side to a light or white wire on the other side. I am going to use black, red and white for this discussion. Yours may be dark brown, orange, yellow or something similar.
The black and red wires feed power to the receiver which in turn distributes power out to the servos and other accessories that are plugged into the receiver. Note that the red wire is in the center. This is the power wire. Since it is in the center you can insert the plug into the receiver either way and nothing bad will happen. You won’t get any response from the servos if you put it in wrong, but you won’t damage anything. Note that, on some older systems, particularly Airtronics radio systems, the red wire was on the end. If you plugged it in the wrong way it could damage the receiver and possibly the servos. However the center red design has been fairly universal for many years.
The third wire, the white wire is the signal wire that sends commands from the receiver to the ESC to tell it how to control the motor. As you move the throttle control on your transmitter, the receiver gets the command and passes it up the white wire to the ESC so it knows how much speed you want from the motor.
There is a third set of wires that go to the motor. The ESC is usually marked to show which wires are the motor wires. If this is a brushed motor ESC then there will be two wires, typically red and black.
On a brushed motor ESC, if we connect red to red on the motor, and black to black, the motor will turn in the expected direction. If we reverse them the motor will spin in the opposite direction.
On a brushless ESC, you match color to color as well. However if the colors don’t match then you need to observe the direction of the motor. If it is spinning in the wrong direction, reversing any two wires will correct this.
Note that on some older brushless motors there were additional wires that attached to a sensor in the motor. However, unless you have an old motor and ESC combination you won’t see that on any of the current designs.
Some ESCs have an integrated switch. In most cases this will allow or prevent the motor from running and pass or block power to the receiver. However it typically does not stop the flow of current from the battery to the ESC. In fact, even if there is no switch there is always current flowing to the ESC which will drain the battery.
It is for this reason that you should never leave your battery connected when you store your plane. This small current drain will take your battery to zero charge over time. If you are using NiCd or NiMh, the damage may be minor. If you are using Lithium batteries, you lithium battery pack will likely be ruined. So, don’t leave your battery connected unless you are preparing to fly.
Connectors
The connector/plug that goes to the receiver is standardized. It is the same wire scheme and plug type as is used for the servos. Today all makers, except Futaba, use the universal plug.
On the Futaba J plug you have the same wiring scheme but there is an extra tab on the plug that insures the connector is inserted properly into the receiver. If you have a receiver that accepts this slotted plug it will also accept universal plugs. However if you have a receiver that expects the universal plug, then you will need to trim off this tab with a hobby knife or you can sand it off. Once trimmed, the plug will work fine.
Battery and motor connectors are not as simple.
There is an emerging standard for motor/ESC connection on brushless motors. The connectors are round and are called bullet connectors. Most brushless motor/ESC makers seem to be using these now, so on brushless motors this connector standard seems to be established. However, for brushed motor connections there is no standard.
On the motor side we have the option of not using a connector as we can solder the motor and ESC wires together. This works fine if you don’t plan to remove the motor or the ESC and it gives the best connection. However if you do have to remove one of them for service, you will need the soldering iron in order to take the connection apart.
On the battery side we always use a connector so that we can remove the battery for charging and storage. When flying electric planes it is common to have several battery packs so the connector allows us to remove one pack and insert a fresh one while the first is charging.
Whatever batter or motor connector you use, make sure that is has a current, amp, rating that is larger than what the motor is likely to pull. The reason the wires for these links are thicker is that the battery has to deliver high current to the motor as opposed to the relatively small current that goes to the receiver. If the connector can’t handle the flow, it will heat up and potentially be damaged. Likewise, if the connector can’t handle the current the motor will never develop full power. Too light a connector can also cause a serious voltage drop.
This lack of standards leads to situations where you buy a motor that has one connector, your battery has a different connector and your ESC has a third type. Or, as seems to becoming more common, none of them have connectors and you have to add your own.
My suggestion is to standardize connectors. Once standardized, any motor or battery connection that doesn’t have your standard connector gets a connector replacement. It takes time and soldering but with one standard, all of your batteries will work in any plane for which they are appropriate and you can move motors and ESC around as you desire.
This will also simplify your battery to charger connections. One or two adapters for your charger will handle all of your batteries. Just make sure the connector you use can handle the current.
I have three standards. For brushlesss motors, I use the bullet connectors. For brushed motors and batteries in very small light planes where the current will typically be under 5 amps, I use the red BEC connectors. These are sometimes called GWS connectors as they are common on GWS motors, batteries and ESC. They are small and light and are well suited for small light planes.
For my high current applications I use the Deans Ultra connectors. They can handle up very high currents, are easy to solder and can be easily removed and reused. However there are many other high current connector that are equally as good. As long as it can handle the current flow, it will be fine.
Sizing an ESC
Electronic Speed Controls are sized according to how many amps they can control and the voltage that they can handle. So you may see an ESC marked as 20 amps and 7-10 NiXXcells or 2-3 cell Lipo. That says it can handle a 20 amp flow using a battery pack that ranges between 7.4V and 12 volts. If you use it with a motor/battery system that is outside this range it will likely fail. When it fails it may simply not run the motor or it may also cut power to the receiver, which will lead to a crash.
You size your ESC according to the motor and the battery you are using. I won’t go into how we determine what the motor and battery will need. That is covered in another article. It is enough to say that, if your motor is going to draw 20 amps you will need an ESC that is rated for at least 20 amps. There is no problem having an ESC that is rated for more amps than you need, but and ESC that is rated below the expected current load will likely lead to a failed ESC.
The same goes for the voltage. Use your ESC outside the voltage it is designed for and you can expect it to fail.
Your ESC will likely have an integrated battery elimination circuit, a BEC. This is the part that delivers the power to the receiver. Always check the specs for the BEC. While the ESC might be able to handle 14.4 volts, the instructions may say that for uses above 11.1V you may have to disable the BEC. There is a complete article on the BEC, so I won’t go into it here. Let’s just say you need to check this.
I recommend that you always have at least a 20% margin between the amp requirements of your motor and the rating of your ESC. This way you will know you will not be overloading the ESC. A bigger margin is also fine.
How the ESC controls the Motor
Motors are rated by Kv, which means the number of revelations the motor will turn when you apply 1 volt of electricity. So a 1200 Kv motor will spin at 12,000 rpm if you apply 10 volts.
From this you might imply that the ESC changes the voltage to the motor in order to change the speed of the motor, but that is not the case. If you look at the specifications for your ESC you will probably see a frequency number. This might range from 2 KHz to 12 KHz or higher. This is related to how fast the ESC can pulse power to the motor. You see your ESC is not a variable resistor that adjusts the voltage to the motor, it is a fast switch that pulses power to the motor.
You can think of this as a duty cycle control. How long will the ESC leave the power on till it turns it off? Then, how long will it be off before it turns it back on? There is no need for you to know this cycle time, only that on every on cycle your motor is getting the full voltage of your battery.
I take the time to explain this because people mistakenly believe that if they run their motor at partial throttle they are sending reduced voltage to the motor. If the motor is not supposed to get more than 7.4 volts and you put in an 11.1V battery, running the motor at ½ throttle does not reduce the voltage to the motor. It is getting 11.1V hits every time the ESC switches on. On a brushed motor that is receiving too much voltage, this will typically produce arcing which will burn up the brushes on the motor. In addition to this arcing on brushed motors, this higher electric pressure may push too much current that will overheat the motor.
If you have had a motor “burn up” even thought you usually ran it at a partial throttle setting, this may be the reason. Understanding how the ESC controls your motor will help you diagnose problems.
Note also that, since the ESC is switching power on and off it is also producing electromagnetic pulses, or radio waves. The electronics in the ESC will typically be designed to reduce or shield some of this radio wave noise, but it can’t block it all. This is why we recommend keeping the ESC and the receiver as far apart as possible as this ESC noise can interfere with the receiver. If you are getting “glitching” or odd pulses to your servos, these may be coming from ESC noise bothering the receiver. Try moving things around.
Other Components in the ESC
I am going to address these in later articles, but there are typically two other components that are integrated into your ESC. We already mentioned the BEC. The other is the LVC, the low voltage cutoff. These are not directly involved in controlling the speed of your motor, but as you will see in the articles that are focused on these that they are very valuable parts of your ESC that you will want to understand.
Summary
The electronics speed control is the power system controller for your airplane. Its various components distribute power to the receiver and control the speed of the motor. Understanding how it works will give you the ability to properly size and install the ESC and to diagnose problems in the system.
< Message edited by aeajr -- 2/24/2008 1:27:14 PM >
Ed Anderson
Moderator
(in reply to aeajr)
       Post #: 5
RE: EVERYTHING YOU WANT TO KNOW ABOUT ELECTRIC FLIGHT - 2/19/2008 2:15:08 PM
aeajr
